if its meant for 12Volt aplication, then you would just run it 12volts from the car battery......with a fuse inline ofcourse.
~Mong
http://cgi.ebay.com/ws/ebayISAPI.dll...oDisplayType=2
doesnt list voltage but granted it is correct voltage for a car how would i power it?
edit: found out its 12V 3.75A
could i run it straight off the 12v line of say....an opus psu?
would i just cut the end off of the thing and strip off some insulation and attach? would i use the small rectangular ac adapter thing or ditch that (i think that gets discarded)
thanks
~Mong
America...
just a nation of two hundred million used car salesmen with all the money we need to buy guns and no qualms about killing anybody else in the world who tries to make us uncomfortable.
Hunter s. Thompson
You shouldn't wire it directly to your car. It may work, but given that your cars standard running alternator voltage will be about 13.8 volts that won't help it any (but you'll have to check the tolerances of the specific unit).
However you also have to think of alternator dumps, you can easily get upwards of 300 volts in certain circumstances, which should be protected with a transient surpressor.
I power a 12v 5.6" screen in my car from a reg circuit I built (you can see the circuit on www.stuffandting.com). This circuit protects my computer as well, but given your screen is 3.x amps already you won't power both off the one reg.
is there anything i can buy to support it?
i doubt i could construct any circuits on my own
Go to the Elo web site....see if the have the voltages there...
it's probably 12v and a 5v
both of which your computer power supply will have....
it's not to hard....and I don't know **** about ****
BossTone74
would the nearly 4 amps max out the 12v line on an opus though?
(i already found its 12v 3.75A)
...but does the Opus regulate the 12v line??? Most of the other DC-DCs don't (Lex, Morex etc) and just pass the raw 12v feed straight through, so you're still giving 13.8 volts (or more) to your screen.Originally posted by aoLhaTer
I know with my money I wouldn't risk it...
http://www.opussolutions.com/150watt.html
lists 2% regulation
Sweet, then you're fine with that one. Obviously you may struggle with the screen and other 12v devices running off the same unit, but in terms of protection okay.
But then this is uber expensive, uber-clever PSU designed for in-car use, not like the Lex/Morex that most people use.
alright, so say i got the opus and this psu
how would it be connected?
just stripped on the end without the ac adapter and connected via molex or whatever to the opus 12v line?
