Results 1 to 7 of 7
Thread: HDMI and reverse wire Lilliput
    Jul 2007
    Australia
    I have the new HB Liiliput double din 4 wire touchscreen and have the video connected via HDMI and the reverse sensing wire connected. The problem is when the reverse is detected the monitor changes inputs as expected however the loss of handshake on the HDMI connection causes my windows drivers to reset. Would changing to a DVI connection solve this problem? If I do change would it be as simple as putting an DVI to HDMI adapter on the end of the HDMI cable ( I don't want to re run the HDMI cable in the car) any other solutions that you guys can think of would be great as well.
    Many thanks
    James
    Variable Bitrate FPeter's Avatar
    May 2008
    Hungary
    Quote Originally Posted by jdmagoo1 View Post
    Many thanks
    James
    i think there is no solution for it - but why is it a problem for You ? i hear the connect - disconnect sound every time when i switch the monitor, but there is no problem, works well after then as before
    "case": Skoda Superb Elegance 1.8T
    Asrock G41MH-GE, E2180 2GHz dualcore, 1024MB DDR2/800, Samsung F1 750GB/7200RPM/32MB, M4-ATX, Lilliput FA1011 HDMI touchscreen, ASUS Xonar DG PCI, homemade Quectel L10 USB GPS
    Jul 2007
    Australia
    It resets my drivers then I have to restart the computer for everything to work properly
    May 2008
    Hungary
    strange, is it problemous with integrated intel graphics? good to know, i planned a system with similar configuration...
    Jul 2007
    Australia
    Ok I have fixed the issue by placing a DVI adapter on the end of the HDMI cable which is good no need to re run another cable.
    Of note, I don't know whether I will be able to play blu ray using this configuration because of HDCP issues? Does anyone know if HDCP will be a problem over a DVI to HDMI connection? I am unable to test due to XP not able to play blu ray using the i5 CPU as the graphics card. Now I have to install Win 7 to test.
    May 2008
    Hungary
    are You really sure, is the DVI>HDMI adapter solved it? can You please check it again with direct HDMI connection? if its really the adapter, then its very strange, the HDMI and DVI is absolutely same way, the DVI>HDMI adapter is a simple wire to wire passive adapter and the transfer protocol on the cable is the same...
    XP is enough for HDCP based playing! i checked my FA1011 with CyberLink BD & 3D Advisor on my desktop pc with HD4850 and WinXP SP3, and reports it as digital monitor with HDCP
    Jul 2007
    Australia
    Quote Originally Posted by FPeter View Post
    That correct your graphics card will do it, im saying the i5 cpu needs win vista or 7. It wont play blu ray on xp.
    http://www.intel.com/support/graphic...00.htm#whichOS
    The DVI adapter defiantly solved it under XP, Im in the process of installing 7 so will let you know
  1. Replies: 59
    Last Post: 10-22-2015, 12:21 PM
