Results 11 to 20 of 28
Thread: 720p screens?
  1. #11
    Jan 2008
    check the fine print--it depends on the model of the screen you want to use.
    this thread also recommends njytouch:
    http://www.mp3car.com/lcd-display/14...seriously.html
  2. #12
    Newbie Sicarius123's Avatar
    Mar 2010
    Australia
    Says to enquire about other models, so just sent them an enquiry.
  3. #13
    Mar 2010
    Australia
  4. #14
    Variable Bitrate hailrazer's Avatar
    Mar 2008
    Columbus, Georgia
    Quote Originally Posted by Sicarius123 View Post
    Would a controller like this be all you need to plug this screen into DVI?
    http://cgi.ebay.com/Compatible-R-RM5...ht_7688wt_1139
    Basically , yes.
    You will need to let the seller know which screen you have and they will reply back if they can program that controller for your screen.
    It will take around 6-8 weeks to get it , sometimes longer.
  5. #15
    Mar 2008
    Columbus, Georgia
    You will still need it programmed for the lcd, then you will need to make an lvds cable and add an inverter and wiring for the backlight.
  6. #16
    Mod - iPad Forums RipplingHurst's Avatar
    Dec 2007
    Danville, CA
    As for the debate on high resolution 7" screens. I agree with the OP, the more the better. I was a skeptical and I used to agree with HT magazines claiming you "don't need/won't notice" 1080p below 40", and now I believe it's BS. Why? Well, since I bough an iPhone 4 with a ultra high resolution display, where I can actually see the difference in a 3.5" screen (960x740). I have seen Android phones, I have Android Tablets, and I'm supposed to not notice much difference, after all at 7" 640x480 should be good enough. Not true AT ALL. My galaxy tab has a 1024x600 screen, and I can definitely wish for more. It's clearly inferior to the iPhone screen resolution wise, maps, text, pictures, the zoom in better and look sharper at any size on the iPhone.
    So YES, I would definitely see a difference in a 7" with 1080p, and I completely understand the need for it. BTW, not only while reading, but when zooming in/out you can clearly see more detail. So while it's not necessary at all, I can see the need in a quality install.
  7. #17
    Mar 2010
    Australia
    Has anyone found a higher res 7" screen with controller? I still haven't found anything smaller than the 8.9" above which will require a custom dash piece to fit.
    The controller I linked to lists the 720p 8.9" Toshiba screen specifically in the instructions for which jumpers are required to get it working.
  8. #18
    Sep 2011
    can you guys stop bringing up the IPhone 4 and its high resolution
    a small screen with a resolution too high is just a waste of money, requires more cpu power and is a waste of power
    I get tired when I hear people say "I want my LCD to have a retina display"
    NO YOU DON'T
    The reason the iPhone 4 high resolution works is because 1) you can quickly enlarge/shrink items and... drumroll 2) you can easily move your phone closer or farther away from your face
    This doesn't work for displays that are stationary.. can you imagine being 6-12 inches away from your laptop monitor ?
  9. #19
    Mar 2010
    Australia
    Windows 8 is already going to limit what it can do with less than 720p. Give up on harping for awful resolution screens, soon they'll be in the past where they belong.
  10. #20
    Dec 2007
    Danville, CA
    Really? Didn't know about that. Sad news for Xenarc and the likes.
    I think 720p should be the standard for 7". Or at least 1024x600 like on the Galaxy tab tablet (which is low for a tablet, IMHO).
    It maybe a waste of power, but then again so it's a 1000W subwoofer. I'd love to get at least 1/10 of the number of options I get from the aftermarket car sound market - and nobody is concerned about "wasting" power there, why should we? It's not like we're have to rely on batterie power all the time.
  1. Replies: 14
    Last Post: 10-12-2006, 07:20 PM
  2. using 2 screens ?
    By shade9 in forum LCD/Display
    Last Post: 07-19-2006, 09:10 AM
  3. Multiple Screens? Larger Screens?
    By Atom_Bomb in forum LCD/Display
    Last Post: 03-31-2004, 07:24 PM
  4. Replies: 5
    Last Post: 07-01-2003, 09:25 PM
  5. lcd screens From $50 AUD!!!!!!
    By TDMP3 in forum Classified Archive
    Last Post: 01-03-2003, 11:07 PM
