Well my main point really was, how hard is it to take a
laptop replacement OEM screen such as the Toshiba, and hook it up to regular PC connections such as DVI??
As for a HD capable PC, I'm tossing up either building an atom D525 system with ION2, which is 1080p capable, or an i5 sandy bridge mini ITX system, which would be more than capable and in even the Atom's case should be pretty snappy with an SSD.
I also have no interest in using the carpc
software setups that emulate a touch screen headunit. I think touchscreen headunits are absolutely awful and about 10 years out of date in interface. I'd rather use Win7 MCE as it is EXTREMELY touch friendly and intuitive compared to todays touch screen headunits and will handle multimedia far better, I'll just miss out on
navigation which doesn't bother me.
As you can see I'm really not after a traditional build at all, and with what I want the crisper higher res a screen I can source, the better. At the end of the day if I look at a regular 8.9" screen and don't think the resolution is good enough, I don't see why I wouldn't benefit from a 720p screen?
This argument really seems along the same lines as some people on here not seeing the point of capacitive screens, and others not seeing the benefits of multi touch.
