Results 1 to 10 of 12
Thread: How do I connect laptop monitor to another pc?
    Apr 2005
    I got a hp laptop dv9000 and it's good for nothing but parts. I want to keep the screen, so is there anyway to connect it to a desktop? Or make it vga?
    This is what the connector looks like.
    North of the land of Hey Huns
    Jun 2004
    Westminster, MD
    Short answer: No.
    Long answer:
    If you can find a controller board compatible with that screen (They run between $50-$500), then it is remotely possible that you can hook it up and run it, but you will likely have to re-solder all those wires onto a new connection if it's a non standard connection that it uses. You're better off buying a screen with VGA input.
    RevFE
    My Shop
    Jan 2008
    your only hope is in this thread:
    http://www.mp3car.com/lcd-display/14...seriously.html
    My 2001 Mitsubishi Eclipse GT:
    "The Project That Never Ends"
    more projects then time!
    Led Skyline Tail Lights--100%
    High Power Led Reverse Lights--100%
    Led third brake light--100%
    Led front turn signals--0%
    HID retro--100%
    May 2005
    Denmark
    The connector on that plug is DV-9000 only.
    The connector in the other end in the LCD panel is pretty standard 30-pins Single channel LVDS. You need a pretty expensive controller board to convert DVI or VGA to control this panel, and the controller needs to be programmed to support this particularly LCD-panel.
    Not worth doing if you ask me. A desktop monitor is cheaper and has better viewing angles and brightness...
    // Per.
    Jan 2008
    agreed, but many times, laptop monitors are thinner, and are easier to adapt for in-car use..
    HID retro--100%
    Apr 2005
    Can I use anything from this? Maybe the webcam?
    May 2005
    Denmark
    The harddrive, RAM and Webcam (standard USB interface) can be re-used.
    The optical drive can be used with an adaptor.
    // Per.
    Mar 2007
    Barbados
    It's not difficult at all if you are willing to put in the work. This is the controller you need: http://cgi.ebay.com/5451-Audio-LCD-C...item4157253058
    Just email them the model number of your screen (top right corner of the screen) and they will program the timing. Then you cut off the end that connects to the motherboard and solder it to the cable they sent you. Read this post on how I built mine. http://www.mp3car.com/lcd-display/10...-lp150x04.html
    PM if you need any other help. Its sweet when they are up and running. Enjoy learning
    May 2005
    Denmark
    Quote Originally Posted by wired48 View Post
    Remember, that connector is not only supplying the LVDS but also the Backlight inverter in the monitor.
    And the small coaxial or triaxial cable there's in this HP cable is next to impossible to strip and solder onto, so i'd suggest getting another cable with a 30 pin LVDS connector and some humane wires (that you can solder to) and plug that straight into the LCD panel....
    Apr 2005
    Those are too small to solder for me.
  1. Need 6 pin s-video cable to connect headrest monitor
    By Blinginbu in forum LCD/Display
    Last Post: 01-20-2011, 07:57 AM
  2. Wanting to connect laptop to LCD monitor
    By 2jzlex in forum Newbie
    Last Post: 06-25-2008, 10:29 AM
  3. How to connect PSU to battery & monitor question
    By a-ten in forum Power Supplies
    Last Post: 12-21-2006, 01:17 AM
  4. Replies: 1
    Last Post: 12-01-2004, 12:17 AM
  5. PSOne monitor (again) how to connect to TV-Out
    By Daninino in forum LCD/Display
    Last Post: 09-23-2003, 01:32 AM
