Page 10 of 175 FirstFirst 123456789101112131415161718192060110 ... LastLast
Results 91 to 100 of 1747
Like Tree13Likes
Thread: "Transflective" LCD panel with res touch+controler for $101+$36 S+H
  1. #91
    May 2010
    Australia
    Hmm I wonder if there is a way to disable auto config..
    Did it work with another computer?
  2. #92
    Newbie bmassey96's Avatar
    Jul 2007
    Michigan
    I'm able to get 640x480@60hz to work without the corruption or "auto-config" issues as mentioned above. I'm not sure if it's the GPU/driver or the display. I'll try it on a different machine this weekend.
  3. #93
    May 2010
    Australia
    Yeah tft thought maybe it was drivers..
    Would be interested to see if you just need to get the display profile exactly right or if there is something you can set on the monitor to make it work..
    But yeah try a few different computers if possible to check that.
  4. #94
    Maximum Bitrate tft_lcd_org's Avatar
    May 2010
    Detroit, MI
    Quote Originally Posted by bmassey96 View Post
    Note: my display didn't come with a power supply so I'm using a 5v supply from a router rated @ 2.5 watts, if that matters.
    On the Samsung? That is a 12v DC display.
  5. #95
    May 2010
    Australia
    I did see one reference to 5v in the documentation but that could make a difference..
  6. #96
    May 2010
    Detroit, MI
    Quote Originally Posted by stretch4x4 View Post
    Are you referring to the data sheets for the LCD panel?
  7. #97
    May 2010
    Australia
    Yeah that's the one, I think it might have been in reference to the backlight though..
  8. #98
    Mar 2011
    Can you confirm that the 800x640 resolution works? I just want to make sure before I take the plunge!
    Thanks!
  9. #99
    May 2010
    Detroit, MI
    The voltages in that document are only for the LCD panel. The LCD controller data is not provided by the seller, but the power input for the controller is 12v DC.
    The LCD panel uses 3.3v DC, and it looks like the back light LED is 5v DC.
    The controller then provides the 3.3v, 5v, etc to the LCD.
  10. #100
    Jul 2007
    Michigan
    I was going off the data sheet, and the reference to the 5v supply was all I could find. I'll dig up a 12v supply and see if that makes a difference.
  1. FS: 10.2" LCD Touch kit w/transflective enhancement
    By Motorcity in forum Classified Archive
    Last Post: 03-14-2007, 03:20 PM
  2. Replacement 4:3 8" Touch Panel For "Super"
    By gsd_racing in forum Input Devices
    Last Post: 01-25-2006, 06:28 PM
  3. Replies: 146
    Last Post: 08-19-2004, 04:39 AM
  4. Replies: 2
    Last Post: 12-11-2003, 11:36 PM
  5. Can I use an 8" touch panel with a 6" lcd?
    By Odie in forum LCD/Display
    Last Post: 10-30-2002, 12:28 AM
