Like Tree12Likes
Thread: "Transflective" LCD panel with res touch+controler for $101+$36 S+H
  1. #1051
    May 2011
    Quote Originally Posted by DaveDog View Post
    It would give me the ability to use USB3 that my motherboard has. Just thinking of future proofing.
    Dimming is kinda tricky, my frontend controls it for me, don't even need the headlight input for auto dimming, but it's a nice add on.
    Then again, a button to black out the LCD, that's a good thought, press it once, blackout, press and hold, adjust brightness.
    I agree that menu controls could be on a remote, just don't lose it.
    Absolutely need to be able to switch video inputs, this should not be only accessible via a remote.
    Again, buttons are tricky, you need some to control the LCD (source) , some to control the PC (power, volume) and you can't really have them share.
    Our plan is, left side for customize keys, and the right side for hardware control for the monitor
    Any questions, please email to derrick.ny@gmail.com :)
  2. #1052
    May 2011
    Hmmm,
    Here is what I'd like to see, button-wise:
    power button - for PC power on/off
    input button - for LCD control - single press goes through different sources, have a 'source' with no input for a blank screen - press and hold to adjust brightness
    rotary knob with click - for PC control, would look like a mouse to the PC
    That's it!
    Yes, it will works almost like that, only lack the knob
  3. #1053
    May 2011
    Quote Originally Posted by miraclemaker View Post
    That sounds spot on to me.
    I also like Hdale85's suggestion of an IR remote. These come bundled with a lot of small LCD screens, and could be used for the LCD adjustment type tasks that you rarely need to perform. Skip it if it's going to significantly increase cost though.
    We will try our best to put a remote with this monitor, if the space is not a problem
  4. #1054
    May 2011
    Quote Originally Posted by ninja6o4 View Post
    Derrick,
    You won't be able to please everyone, I think you've figured that out by now.. Have you considered moving some inputs to the rear of the unit? A multi-purpose rotating knob would be more useful to me than front facing USB/SD/AUX inputs. These could all be moved to the back and let the user run cable wherever they want.
    With a knob with click push, you can control a lot of things. Besides the usual volume up/down/mute, you could click hold to bring up a new set of menu options - Equalizer, Input settings, LCD control for example. Then use the knob as left/right or up/down and click select. Brings up your eq/lcd settings and so on, you get the idea. It's very intuitive vs trying to cram several single use buttons where they normally wouldn't make sense. This is the way BMW & Lexus (and prob others) are going - more features, less buttons.
    You are right, but we will work our best to fulfill as many people as we can
    This monitor is also trying to fit as much car as possible, and a knob can not in this layout because of the space...sorry
  5. #1055
    May 2011
    These photos will show how "tie" it is inside
  6. #1056
    May 2011
    Here should be the final product
    We are adding the remote, should not be a problem. The right side still keep 2 hardware control buttons for the monitor.
    One for power switch, with channel switch by holding 2 sec, it will switch to another channel by loop.
    another one for back-light control.
  7. #1057
    kdl
    kdl is offline
    Mar 2012
    That looks great. When and where will this be available?
  8. #1058
    May 2011
    looking awsome!
    just hope that the 3.5 jack is some kind of aux input as putting a mic input in there seems just weird for me.
    also, will the lcd that comes with this case be the one that displays no OSD when changing inputs?
  9. #1059
    May 2011
    Quote Originally Posted by slownumb View Post
    looking awsome!
    Yes, it is a Aux Input, not a mic input
    The power button also work as "channel switch" hot key. When you hold it for 2 sec, it will switch to another channel by loop.
  10. #1060
    May 2011
    Also, here is the button logo, any thought? after confirm this. we will submit for molding this weekend
  1. FS: 10.2" LCD Touch kit w/transflective enhancement
    By Motorcity in forum Classified Archive
    Last Post: 03-14-2007, 02:20 PM
  2. Replacement 4:3 8" Touch Panel For "Super"
    By gsd_racing in forum Input Devices
    Last Post: 01-25-2006, 05:28 PM
  3. Replies: 146
    Last Post: 08-19-2004, 03:39 AM
  4. Replies: 2
    Last Post: 12-11-2003, 10:36 PM
  5. Can I use an 8" touch panel with a 6" lcd?
    By Odie in forum LCD/Display
    Last Post: 10-29-2002, 11:28 PM
