Like Tree13Likes
Thread: "Transflective" LCD panel with res touch+controler for $101+$36 S+H
  1. #1111
  2. #1112
    May 2005
    Quote Originally Posted by 8838.com View Post
    Yes, 260 nit won`t made a ultimate display, but it is acceptable, especially when adding a little shade
    We all know 600~700 nit screen will be the bast, the problem is, cost will become very very high...
    I don't think people want to drive around with screen shades sticking out from their dash.
    I realize price is an issue, but so is usability. When you have the screen mounted up at the dash it needs to be visible. The standard 250nit screens just don't cut it
  3. #1113
    Oct 2006
    Perfect!
    Here is the final symbol we works out for the buttons. Thanks for Ken Homma`s help, AGAIN!
    Any suggestion? If everybody agree with this, we are putting it in to production.
  4. #1114
    Jul 2009
    Looks good to me.
  5. #1115
    May 2011
    Quote Originally Posted by sebberry View Post
    Nice mod
    We try this monitor in a car, with the TMR Technology, under most circumstances, the screen is usable & view-able.
    If you have a strong direct sunlight on it, then you need a shade to work better
  6. #1116
    92x
    92x is offline
    Oct 2011
    I have had direct sunlight on the screen and it definitely is 'readable'.
    It's not super clear, but as long as your not wearing sunglasses, you can definitely still see the screen.
  7. #1117
    Feb 2008
    I ended up with two broken touchscreens (original cracked and my attempt at replacing it led to ribbon becoming useless) and a bybyte enclosure that's falling apart for my 2.5 year old lilliput 701 monitor. I was about to order replacements until I saw this thread. I'm still reading through the entire thread, but based on the last ten posts or so, this screen and enclosure seem real promising.
    I'm sorry if this was asked before, but would the samsung lcd fit in a bybyte enclosure? I currently glued/taped everything for the bybyte together and I'm currently using my wireless keyboard to control my pc. I would really like touch functionality back. I really am excited for derrick's enclosure, and looking forward to purchasing one, but I'm sort of impatient.
    Thanks!
  8. #1118
  9. #1119
    Low Bitrate Zephrant's Avatar
    Sep 2010
    When I got my replacement display in October, I tried it out and it worked fine. Now I've finally got everything in the car, and the display only lights up white. No menu, no video input, no HDMI, just a white screen. I can't get my Intel graphics card in to 800x480 mode anymore, not sure why. But at 800x600x60 or 1024x728x60 I get nothing. The screen flashes back then back to white when I change video modes on the PC, so the screen is getting something. The AV button doesn't seem to do anything either.
    I'm wondering if the HDMI cable is too long, or too noisy. I'll try to get a short one for a trail and see how it goes.
    Here is a utility that will read the data from the monitor:
    http://www.entechtaiwan.com/util/moninfo.shtm
    Here is the output:
    Monitor
    Model name............... AS4637
    Manufacturer............. Iiyama
    Plug and Play ID......... IVM4668
    Serial number............ 0
    Manufacture date......... 2002, ISO week 35
    Filter driver............ None
    EDID revision............ 1.3
    Input signal type........ Digital (DVI)
    Color bit depth.......... Undefined
    Display type............. RGB color
    Screen size.............. 360 x 290 mm (18.2 in)
    Power management......... Standby, Suspend, Active off/sleep
    Extension blocs.......... None
    DDC/CI................... Not supported
    Color characteristics
    Default color space...... sRGB
    Display gamma............ 2.20
    Red chromaticity......... Rx 0.625 - Ry 0.340
    Green chromaticity....... Gx 0.280 - Gy 0.595
    Blue chromaticity........ Bx 0.155 - By 0.070
    White point (default).... Wx 0.281 - Wy 0.311
    Additional descriptors... None
    Timing characteristics
    Horizontal scan range.... 24-80kHz
    Vertical scan range...... 56-85Hz
    Video bandwidth.......... 140MHz
    CVT standard............. Not supported
    GTF standard............. Supported
    Preferred timing......... Yes
    Native/preferred timing.. 1280x1024p at 75Hz
    Modeline............... "1280x1024" 135.000 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync
    Standard timings supported
    720 x 400p at 70Hz - IBM VGA
    640 x 480p at 60Hz - IBM VGA
    640 x 480p at 67Hz - Apple Mac II
    640 x 480p at 72Hz - VESA
    640 x 480p at 75Hz - VESA
    800 x 600p at 56Hz - VESA
    800 x 600p at 60Hz - VESA
    800 x 600p at 72Hz - VESA
    800 x 600p at 75Hz - VESA
    832 x 624p at 75Hz - Apple Mac II
    1024 x 768p at 60Hz - VESA
    1024 x 768p at 70Hz - VESA
    1024 x 768p at 75Hz - VESA
    1280 x 1024p at 75Hz - VESA
    1280 x 1024p at 60Hz - VESA STD
    1280 x 1024p at 75Hz - VESA STD
    1024 x 768p at 60Hz - VESA STD
    1024 x 768p at 85Hz - VESA STD
    800 x 600p at 60Hz - VESA STD
    800 x 600p at 85Hz - VESA STD
    640 x 480p at 60Hz - VESA STD
    640 x 480p at 85Hz - VESA STD
    Report information
    Date generated........... 4/15/2012
    Software revision........ 2.60.0.972
    Data source.............. Real-time 0x0031
    Operating system......... 6.1.7601.2.Service Pack 1
    Raw data
    00,FF,FF,FF,FF,FF,FF,00,26,CD,68,46,00,00,00,00,23 ,0C,01,03,81,24,1D,78,EF,0D,C2,A0,57,47,98,27,
    12,48,4F,BF,EF,00,81,80,81,8F,61,40,61,59,45,40,45 ,59,31,40,31,59,BC,34,00,98,51,00,2A,40,10,90,
    13,00,68,22,11,00,00,1E,00,00,00,FF,00,30,0A,20,20 ,20,20,20,20,20,20,20,20,20,00,00,00,FC,00,41,
    53,34,36,33,37,20,20,20,20,20,20,20,00,00,00,FD,00 ,38,55,18,50,0E,00,0A,20,20,20,20,20,20,00,06
    Zotac H55-ITX w/ 802.11n WiFi, i3-550/3.20GHz, 8GB DDR3 1333MHz, 120G Intel SSD, P2140,
    7" pseudo-transflective resistive TS, Win7-64, Centrafuse 4.3, Elmscan Compact 6, BU-353, Rear camera, Trailer camera
  10. #1120
    Apr 2012
    Finland
    As a potential buyer I've got two questions:
    1) Do we have someone here who has actually managed to get this display (and especially its touch screen) to work under Linux? If so, which distribution etc did you use?
    2) Should a rear-view cam be a NTSC or a PAL model? How about the resolution, anything goes?
    Thanks for any comments!
  1. FS: 10.2" LCD Touch kit w/transflective enhancement
    By Motorcity in forum Classified Archive
    Last Post: 03-14-2007, 03:20 PM
  2. Replacement 4:3 8" Touch Panel For "Super"
    By gsd_racing in forum Input Devices
    Last Post: 01-25-2006, 06:28 PM
  3. Replies: 146
    Last Post: 08-19-2004, 04:39 AM
  4. Replies: 2
    Last Post: 12-11-2003, 11:36 PM
  5. Can I use an 8" touch panel with a 6" lcd?
    By Odie in forum LCD/Display
    Last Post: 10-30-2002, 12:28 AM
