Like Tree13Likes
Thread: "Transflective" LCD panel with res touch+controler for $101+$36 S+H
  1. #1121
    Low Bitrate Zephrant's Avatar
    Sep 2010
    Found my problem- The main flex had pulled out when I mounted it. Really wish I had an official case for it that I could screw everything down to. : )
    Zotac H55-ITX w/ 802.11n WiFi, i3-550/3.20GHz, 8GB DDR3 1333MHz, 120G Intel SSD, P2140,
    7" pseudo-transflective resistive TS, Win7-64, Centrafuse 4.3, Elmscan Compact 6, BU-353, Rear camera, Trailer camera
  2. #1122
    May 2011
    Hi, I assume the problem may from the bad connection with the main cable, which between the LCD and the control board. Could you check and re-connect it? Also try to reconnect the backlight 6pins cable.
    Don`t worry, we will solve it. keep in touch
    Quote Originally Posted by Zephrant View Post
    When I got my replacement display in October, I tried it out and it worked fine. Now I've finally got everything in the car, and the display only lights up white. No menu, no video input, no HDMI, just a white screen. I can't get my Intel graphics card in to 800x480 mode anymore, not sure why. But at 800x600x60 or 1024x728x60 I get nothing. The screen flashes back then back to white when I change video modes on the PC, so the screen is getting something. The AV button doesn't seem to do anything either.
    I'm wondering if the HDMI cable is too long, or too noisy. I'll try to get a short one for a trail and see how it goes.
    Here is a utility that will read the data from the monitor:
    http://www.entechtaiwan.com/util/moninfo.shtm
    Here is the output:
    Monitor
    Model name............... AS4637
    Manufacturer............. Iiyama
    Plug and Play ID......... IVM4668
    Serial number............ 0
    Manufacture date......... 2002, ISO week 35
    Filter driver............ None
    EDID revision............ 1.3
    Input signal type........ Digital (DVI)
    Color bit depth.......... Undefined
    Display type............. RGB color
    Screen size.............. 360 x 290 mm (18.2 in)
    Power management......... Standby, Suspend, Active off/sleep
    Extension blocs.......... None
    DDC/CI................... Not supported
    Color characteristics
    Default color space...... sRGB
    Display gamma............ 2.20
    Red chromaticity......... Rx 0.625 - Ry 0.340
    Green chromaticity....... Gx 0.280 - Gy 0.595
    Blue chromaticity........ Bx 0.155 - By 0.070
    White point (default).... Wx 0.281 - Wy 0.311
    Additional descriptors... None
    Timing characteristics
    Horizontal scan range.... 24-80kHz
    Vertical scan range...... 56-85Hz
    Video bandwidth.......... 140MHz
    CVT standard............. Not supported
    GTF standard............. Supported
    Preferred timing......... Yes
    Native/preferred timing.. 1280x1024p at 75Hz
    Modeline............... "1280x1024" 135.000 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync
    Standard timings supported
    720 x 400p at 70Hz - IBM VGA
    640 x 480p at 60Hz - IBM VGA
    640 x 480p at 67Hz - Apple Mac II
    640 x 480p at 72Hz - VESA
    640 x 480p at 75Hz - VESA
    800 x 600p at 56Hz - VESA
    800 x 600p at 60Hz - VESA
    800 x 600p at 72Hz - VESA
    800 x 600p at 75Hz - VESA
    832 x 624p at 75Hz - Apple Mac II
    1024 x 768p at 60Hz - VESA
    1024 x 768p at 70Hz - VESA
    1024 x 768p at 75Hz - VESA
    1280 x 1024p at 75Hz - VESA
    1280 x 1024p at 60Hz - VESA STD
    1280 x 1024p at 75Hz - VESA STD
    1024 x 768p at 60Hz - VESA STD
    1024 x 768p at 85Hz - VESA STD
    800 x 600p at 60Hz - VESA STD
    800 x 600p at 85Hz - VESA STD
    640 x 480p at 60Hz - VESA STD
    640 x 480p at 85Hz - VESA STD
    Report information
    Date generated........... 4/15/2012
    Software revision........ 2.60.0.972
    Data source.............. Real-time 0x0031
    Operating system......... 6.1.7601.2.Service Pack 1
    Raw data
    00,FF,FF,FF,FF,FF,FF,00,26,CD,68,46,00,00,00,00,23 ,0C,01,03,81,24,1D,78,EF,0D,C2,A0,57,47,98,27,
    12,48,4F,BF,EF,00,81,80,81,8F,61,40,61,59,45,40,45 ,59,31,40,31,59,BC,34,00,98,51,00,2A,40,10,90,
    13,00,68,22,11,00,00,1E,00,00,00,FF,00,30,0A,20,20 ,20,20,20,20,20,20,20,20,20,00,00,00,FC,00,41,
    53,34,36,33,37,20,20,20,20,20,20,20,00,00,00,FD,00 ,38,55,18,50,0E,00,0A,20,20,20,20,20,20,00,06
  3. #1123
  4. #1124
  5. #1125
    Apr 2005
    8838.com, please send invoice
    8838.com can you please send me the pay pal invoice we spoke about, so i can buy your screen. =)
  6. #1126
    Apr 2012
    Milton Keynes in UK
    LCD Touch Screens and parts
    Hi was recently looking for reasonably priced LCD controllers to repair 2 19" monitors that needed sorting out as one packed up working and the other was having trouble starting up, Both the same make.
    Was also wondering if i could use the 2 laptops that ive had for ages in the loft.
    One a small Dell Latitude that works but just too slow and small as a laptop but the 12.1" screen with 1024x768 XGA screen would work well as car touch screen monitor if its salvageable and the other an old Notebook that was given to me.
    Searched the net for repair monitor and use old laptop screens and got a hit that covers all the boxes, i've spent most of my time on Centrafuse forum recently and posted same there, but here is you tube link http://www.youtube.com/watch?v=xiOKd...eature=related and it gave me a supplier of parts for touch screens and controller cards that sell on Ebay. http://stores.ebay.com/njytouch?_trksid=p4340.l2563
    Good prices too.
    Keith
  7. #1127
    May 2011
  8. #1128
    Aug 2011
    Hey Derrick, is there any type of camera management on this monitor. I bought one from you a while ago to use as a video monitor, but now I'm going a different route. But I want to put it in my truck and use a camera for reverse monitoring, but also a second camera to use as a rear view mirror. I was thinking of putting it up near the cargo lamp on my truck cabin, and then have the feed on the monitor. But I'd like to have it switch from there full time to reverse or back up camera automatically when I go in reverse. Is there any way to do that with this monitor without relays etc? Just curious. Looking at all options. Thanks!
  9. #1129
    May 2011
    Quote Originally Posted by Scott Carver View Post
    Sorry for the late reply
    Here the solution for you:
    1. connect your reverse camera to the AV-1, then connect the 12V signal cable(from your car`s reverse system) to the reverse trigger, which beside mini-USB port.
    2. connect your 2nd camera to the AV-2.
    Now you are all set. You can select AV-2 channel for the 2nd Camera in normal circumstance. Once you put in reverse gear, the monitor will auto switch to AV-1, which is your reverse camera. After you put the gear back from reverse, the monitor will auto switch back to AV-2.
    hope this will help. if there is anything else we can help, please feel free to contact us at anytime. enjoy and have a wonderful day
  10. #1130
    May 2011
    BTW, anyone knows any famous Camera or Camcorder forum?
    We just build up another version, which supports "peaking focus assistance". It is a very helpful function for manual focus, almost a "must have"
    here is the example:
    In focus, it will shows "white spots"
    If out focus, no "white spots" shows
  1. FS: 10.2" LCD Touch kit w/transflective enhancement
    By Motorcity in forum Classified Archive
    Last Post: 03-14-2007, 03:20 PM
  2. Replacement 4:3 8" Touch Panel For "Super"
    By gsd_racing in forum Input Devices
    Last Post: 01-25-2006, 06:28 PM
  3. Replies: 146
    Last Post: 08-19-2004, 04:39 AM
  4. Replies: 2
    Last Post: 12-11-2003, 11:36 PM
  5. Can I use an 8" touch panel with a 6" lcd?
    By Odie in forum LCD/Display
    Last Post: 10-30-2002, 12:28 AM
