Page 12 of 159 FirstFirst ... 234567891011121314151617181920212262112 ... LastLast
Results 111 to 120 of 1583
Like Tree12Likes
Thread: "Transflective" LCD panel with res touch+controler for $101+$36 S+H
  1. #111
    Newbie bebopblues's Avatar
    May 2009
    Has anyone figured out the resolution problem? Is it supporting 800x480 as they claimed, or 800x640?
  2. #112
    May 2011
    So far I've been able to get it to display 800x600 or 640x480, so from that I can see it at least has the right amount of pixels in each direction. When I force 800x480 it seems to try and stretch horizontally so one end gets cut off, and the pixels dont line up perfectly :/
    Happens both on the mac and pc, but I'm hoping its not the controller...
  3. #113
    May 2009
    So is it possible that the specs are wrong that the native resolution is actually the standard 800x600 and not 800x480?
  4. #114
    Maximum Bitrate tft_lcd_org's Avatar
    May 2010
    Detroit, MI
    Quote Originally Posted by bebopblues View Post
    No, the specs are not wrong. The LCD panel has a native resolution of 800x480. The controller is a cheap generic that can be programmed to work with many LCD panels.
    It simply scales the resolution to fit the panel. Much like Lilliput monitors do.
    Quote Originally Posted by HiJackZX1 View Post
    This system was supposed to be a quick, cheap throw together that has now exploded into a budget blowing mess.
  5. #115
    May 2010
    Australia
    So the board can't handle it
    Bummer
  6. #116
    Wants to make it harder monkeyracer's Avatar
    May 2007
    Lakehood, CO
    So, can anyone get any 15:9 resolution to work? And are we sure there is not something in the OSD that is messing with the Res?
    I am now starting to lean towards this screen, but I want to get native res working on it. Maybe it would be a matter of getting the LCD only, and getting a separate controller for it that works with 800x480 if this controller doesn't support it.
    EDIT: Looking at the pics on the ebay ad, it shows a shot with 800x480 selected, but if you look at the image, it is doing what stuv was saying. So, I think a new controller is the way to go, or just dealing with stretched pixels at 800x600.
    2007 Chrysler PT Cruiser TE
    Car PC Progress:
    View my
    Worklog
    Road Runner Skins
    Website
    Favorite thread EVER!
  7. #117
    May 2010
    Detroit, MI
    Quote Originally Posted by monkeyracer View Post
    I can order a different controller from one of my suppliers, and he assures me that reverse cam will work. I asked about 800x480 but I did not get a response yet.
    If it does support native, I will consider ordering them. FYI I have to buy a moq of 10.
  8. #118
    May 2009
    Got a reply from the seller about the resolution, he said:
    Quote Originally Posted by derrick.ny
    You can add the monitor type to get 800* 480. Or you can do it with the video card driver. It should not be a problem. We only had 2 clients mentioned this problem and after we gave instruction. They seems solve the problem.
    Not sure exactly what he meant by adding monitor type, probably add a custom resolution?
  9. #119
    May 2010
    Detroit, MI
    That's the same reply he gave me. That means set your monitor res. to 800x480 in the Resolution Settings. I think that he is saying that as long as you have a video card/onboard GFX that has support for 800x480 the display will work with that res.
  10. #120
    Mar 2011
    PowerStrip
    Has anyone tried to use PowerStrip? I've included a picture I made of the process of adding 800X480...
    http://imageshack.us/m/228/4818/powe...tings800x4.png
  1. FS: 10.2" LCD Touch kit w/transflective enhancement
    By Motorcity in forum Classified Archive
    Last Post: 03-14-2007, 02:20 PM
  2. Replacement 4:3 8" Touch Panel For "Super"
    By gsd_racing in forum Input Devices
    Last Post: 01-25-2006, 05:28 PM
  3. Replies: 146
    Last Post: 08-19-2004, 03:39 AM
  4. Replies: 2
    Last Post: 12-11-2003, 10:36 PM
  5. Can I use an 8" touch panel with a 6" lcd?
    By Odie in forum LCD/Display
    Last Post: 10-29-2002, 11:28 PM
