Like Tree12Likes
Thread: "Transflective" LCD panel with res touch+controler for $101+$36 S+H
  1. #1231
    May 2011
    Quote Originally Posted by Ttobi View Post
    Thanks for your reply, that's cool! Really looking forward to hearing some news! Screen Dimensions (especially borders) are the same as the "standalone" screen? Mods INSIDE the case shouldn't be a big deal for me, but on the outside i wouldn't like to change anything.
    Ttobi
    Yes, we use the same screen. So you should be no problem
    Any questions, please email to derrick.ny@gmail.com :)
  2. #1232
    May 2011
    Quote Originally Posted by shad1 View Post
    The ground wire you hooked to your voltmeter needs to be grounded to the outside of the barrel connector. Back at post #873 there are good pictures of someone testing the reverse camera.
    Thanks for helping
  3. #1233
    May 2011
    Quote Originally Posted by Shaxs View Post
    I am also having issues with this feature. I have av-1 connected to a video source. I also have hdmi-1 connected as well. I have 8 x AA batteries (video says triple aaa, ignore that) which is 8x1.5v = 12v. I have this connected to a H size dc power plug from Radio Shack to simulate power to the plug outside a car setting. If I have the controller board on hdmi-1 and give power to the reverse switch, nothing happens. I have verified using a multimeter that 12v is getting to the power switch. Please see the video below:
    The audio is a little loud for whatever reason. Sorry.
    Any idea why this isnt working??
    Sorry for the late reply. shad1 is right. You need to put the ground in the right place
    For the audio, you can turn it a little down.
    Here is the link for the manual: http://www.arvinlin.com/Support/7inc...enu%20REV2.pdf
  4. #1234
    May 2011
    Quote Originally Posted by Deneteus View Post
    I like that!! Nice! LEt me know when they go on sale!
    Could you send a email to derrick.ny@gmail.com? we will keep you update once it comes out
  5. #1235
    May 2011
    When you find some let me know and I'll place the order.
    Will do, once I hear anything back. will let you know
  6. #1236
    May 2011
    Quote Originally Posted by dogislav View Post
    Ok
    How do I fix this, everytime i start my pc the lcd stats in black and white,so i need to reset everytime i start my car.
    Hi, there is a black and white hot key, by pressing the "up" key. check the manual
  7. #1237
    May 2011
    Quote Originally Posted by Zephrant View Post
    Dogislav- You may need to press the SW1 button. I spent a good hour messing around with mine when it got in to B&W mode somehow, not realizing that it was the monitor and not the computer doing that to me. It remembers state (which is great), but that also makes it stick in B&W mode...
    Also worth noting, my PC crashes when I turn the LCD off. Not sure why, but was wondering if anyone else had that problem.
    You are right. that is the "hot key" for B&W
    could you give me more detail about your PC crash? also try disconnect the touch USB cable. see if things change.
    keep in touch.
  8. #1238
    May 2012
    Melbourne, Australia
    Hi Derrick,
    Can you please confirm the final outer dimensions of the screen bezel? I am going to be fitting it in a Scosche standard Double Din Dash Kit (MA1540B for Mazda3) and am concerned about the dimensions. The following are the internal dimensions I have to play with in the Dash kit. From your CAD measurements below it won't work?
    172mm x 96mm for dash kit verses 178mm x 100mm for CAD design.
    Name:  MA1540B Internal Dimensions.PNG
    Cheers,
    James
    Quote Originally Posted by 8838.com View Post
    Here is the final dimension, the outer dims never change:
    Attachment 65821
  9. #1239
    Dec 2007
    Sydney Australia
    Looks like your dask kit has a masking lip, like most do, around the inside which you might have to dremmel off.
    VIA Pico ITX, M2-ATX clone, 7" Seform 800x480 LCD Touchscreen, Dual 2x75WRMS Mini Amps, IDE-CF & SATA-CF adapters, 8GB (Sys) & 32GB (MP3s) CF, ELMscan5USB, Slot-load DVD, Craig Brass DAB+/FM USB module, Odyssey Navigator
    Build 90% Apps 50% Install 10%
  10. #1240
    May 2011
    Quote Originally Posted by jlitjens View Post
    Hi Derrick,
    Cheers,
    James
    RevheadKev is right, there is a lip inside and the open is standard 2-DIN
    I will get you the dims ASAP.
  1. FS: 10.2" LCD Touch kit w/transflective enhancement
    By Motorcity in forum Classified Archive
    Last Post: 03-14-2007, 02:20 PM
  2. Replacement 4:3 8" Touch Panel For "Super"
    By gsd_racing in forum Input Devices
    Last Post: 01-25-2006, 05:28 PM
  3. Replies: 146
    Last Post: 08-19-2004, 03:39 AM
  4. Replies: 2
    Last Post: 12-11-2003, 10:36 PM
  5. Can I use an 8" touch panel with a 6" lcd?
    By Odie in forum LCD/Display
    Last Post: 10-29-2002, 11:28 PM
