Like Tree13Likes
Thread: "Transflective" LCD panel with res touch+controler for $101+$36 S+H
  1. #1301
    Constant Bitrate dsballer2000's Avatar
    Oct 2005
    Canada
    Quote Originally Posted by 8838.com View Post
    Didn`t you get the email about driver? sorry for the trouble. here is the download link
    http://www.ideacom.com.tw/DR_UTS6680.htm
    Hey Derrick,
    Can you point to the vga only controller board touch drivers? Just tried these and they didn't work so I'm assuming there are some for this board. I'm hoping it may fix the issue I'm currently having with the touchscreen registering at the bottom right once I boot to Windows.
  2. #1302
    Sep 2005
    I was originally using a via EPIA MII 12000, the problem persisted when I switched it out for a Zotac ION N330 board. I'm using Windows XP with the drivers supplied by the manufacturer for the touchscreen.
    Car news and wallpaper site: www.carfeed.net
  3. #1303
    Sep 2005
    This page might be relevant: http://www.mp3car.com/lcd-display/11...uch-panel.html
    Note this page is currently being blocked on my desktop machine for having some kind of script malware on it - had to open it on my tablet.
  4. #1304
    Oct 2005
    Canada
    Quote Originally Posted by miraclemaker View Post
    Thanks for the link. Is this what fixed your problem? Derrick just sent me the actual drivers for the new vga only touch screen kit and unfortunately it did not solve my problem.
    Seems to be the issue that the screen needs to heat up a bit before the touch panel starts functioning correctly.
  5. #1305
    Sep 2005
    I'm still suffering from the problem. I haven't tried the instructions on the link, need to get the screen out of my car which is no small task.
  6. #1306
    Oct 2005
    Canada
    lol no doubt. Ok, thanks for the info none the less. I think i'm going to see how Derrick and his team handle this prior to even trying this. It is a brand new unit so I'd much rather go through the troubleshooting and them hopefully replacing the panel all together instead of doing this. It is definitely interesting but the touchscreen on this unit is attached to the LCD so going through the hassle of removing it and putting it back on would be a pain.
    Sucks because this is the only thing keeping me from finishing my project. Everything else seems to be in place but I don't want to install only to have to rip it back out to fix.
  7. #1307
    Mar 2011
    Bay Area, CA
    I had the same problem, but with a different LCD. Usually cold starts the damn thing was acting crazy until after 10 mins. I have the mini touch 700. Drove me nuts to figure out what the problem was. Even tried the lighter trick found in these forums, where you lightly heat up the edges, but didn't work. Finally just replaced the touchscreen overlay and it was back to normal. Perhaps your overlay is hosed.
  8. #1308
    Oct 2006
    in my experience, that is happen when one or more the 4-wire resistive touch panel is loose, either that or your touch panel is pooched.
  9. #1309
    Oct 2005
    Canada
    Quote Originally Posted by audballz View Post
    Ya, this blows. It is exactly the same thing. If I run the touch screen until it warms up, everything is perfect. The minute I turn the monitor off (keeping the pc on) until it cools down and turn it back on, it is all out of whack. It has to be the touch overlay.
    Just waiting for Derrick to reply to my emails on what we can do to resolve this. I don't think it's going to be cheap to send this back to hong kong. I'm debating whether to send the lcd or the whole kit just in case I get a new lcd/touchscreen back and it's still malfunctioning.
  10. #1310
    Dec 2004
    Phone pictures
    Direct sunlight
    Shadowed
  1. FS: 10.2" LCD Touch kit w/transflective enhancement
    By Motorcity in forum Classified Archive
    Last Post: 03-14-2007, 03:20 PM
  2. Replacement 4:3 8" Touch Panel For "Super"
    By gsd_racing in forum Input Devices
    Last Post: 01-25-2006, 06:28 PM
  3. Replies: 146
    Last Post: 08-19-2004, 04:39 AM
  4. Replies: 2
    Last Post: 12-11-2003, 11:36 PM
  5. Can I use an 8" touch panel with a 6" lcd?
    By Odie in forum LCD/Display
    Last Post: 10-30-2002, 12:28 AM
