Like Tree13Likes
Thread: "Transflective" LCD panel with res touch+controler for $101+$36 S+H
  1. #1311
    May 2012
    If someone needs new touchpanel, I can sell you my screen with broken cable. Touch panel works good. I didnt use the screen,only tested with laptop connected, as I didnt finish my carpc setup.
    I ordered new screen from derick, and I ordered liliput case so I can fit the screen easier in to my dash.
  2. #1312
    Oct 2006
    Quote Originally Posted by dogislav View Post
    how much? my cable broke on the touch screen, already took it off, pain, hopefully I can take yours off, Or change cable?
  3. #1313
    May 2012
    Where are you from? I just checked shipping to USA is 29$. And I would like 15$ for it.
  4. #1314
    May 2011
    Update, I just found out that the wide LCD cable is broken at the end. Is that replacable or I need new screen?
    Or can I repair it somehow?
    https://lh5.googleusercontent.com/-5...4/IMAG1191.jpg
    Finally back from a business trip, sorry for the late reply
    This main cable come directly from the LCD glass, so it can not be fix...please email us and we will work out a solution for you. Keep in touch.
  5. #1315
    May 2011
    Quote Originally Posted by radu81 View Post
    I finally installed this monitor on my car, the only problem is that the touch screen is not precise, I did the calibration but nothing changed. It is wrong about 2 mm.
    Anybody had similar problems? Thanks in advance
    Sent from my Nexus S using Tapatalk 2
    Hi, did you use a pin or stylus to calibrate it? don`t use your finger to calibrate
  6. #1316
    May 2011
    I think it was like that for me too. I calibrated it in windows, and then it was spot on.
    PS: My screen is dead without that cable, I will order new one asap. My raspberry pi just arrived, and I didnt get the chance to try it, as I've broken my cable when I was connecting rpi to it
    Does anyone have raspberry pi?? How did you set it up for carpc use? Someone in this thread wrote before that it works great with this screen, and the touch function works too. But I dont know what OS to use for it?
    Sorry to hear that. ribbon cable is very fragile, it need to handle by care
    please contact us, we will work you out a solution.
    For the raspberry pi, try Linux, we have the driver for that.
    Keep in touch
  7. #1317
    May 2011
    Quote Originally Posted by dsballer2000 View Post
    Hi Derrick,
    Received my touchscreen today and everything looks great so far. Haven't tested it thoroughly yet but what I have works very well!
    Just a heads up to any Canadian that the duties/taxes came to $16.21 on this unit which isn't bad at all. Shipment was fast as the tracking # says it left Monday and it was here yesterday but i wasn't home to receive it. Obviously YMMV depending on what customs wants to do with it.
    All in all, so far, I'm very satisfied with the service and the product. I'll update once i get to play with it more.
    Glad to hear that you enjoy your purchase. Keep in touch
  8. #1318
    May 2011
    Hi Everyone,
    I'm having a slight problem and wondering if anyone else has seen this. I randomly get an issue where it doesn't matter where i touch on the screen, it acts as if I touched the bottom right corner. I've tried recalibrating and that doesn't fix it. I'm pretty sure it's the USB cable on the board because if I play around with it, it eventually goes back. Has anyone else had this issue?
    It's definitely not windows as I have formatted a second hard drive and the problem still exists. Once I play around with the cable, it eventually goes back. I may have to get the cable replaced unless someone can chime in on what is causing this issue from their experience?
    thanks
    The 4pin touch cable can not be bend too much or it may have bad connection. Just to make it "flat" from front to end and try
  9. #1319
    May 2011
    Quote Originally Posted by nivanov View Post
    Chances are whatever enclosure you are using for the monitor is pressing on the screen. Try loosening whatever is holding the screen down, or apply a thin strip of rubber tape around the perimeter of the screen outside of the touchscreen area to create some space
    Thanks for helping
    You are right, the frame pressing the touch screen will also cause this.
  10. #1320
    May 2011
    Quote Originally Posted by Mickz View Post
    Random Thoughts.
    Have you tried unplugging the USB touch screen cable from the PC, waiting a few seconds and plugging it back in. Does it work?
    Wait until it fails again and open Device manager and find the USB device entry. Right click and disable it. Right click again and enable it, does it work?
    You may have a hardware issue with the USB interface on the LCD or you may have a problem with the way the PC and screen (USB TS) are powered (timing wise.) Could be a cable or HUB issue if you are using one?
    Check the driver revision in device manager and make sure Windows has installed the correct driver?
    Thanks for helping
  1. FS: 10.2" LCD Touch kit w/transflective enhancement
    By Motorcity in forum Classified Archive
    Last Post: 03-14-2007, 03:20 PM
  2. Replacement 4:3 8" Touch Panel For "Super"
    By gsd_racing in forum Input Devices
    Last Post: 01-25-2006, 06:28 PM
  3. Replies: 146
    Last Post: 08-19-2004, 04:39 AM
  4. Replies: 2
    Last Post: 12-11-2003, 11:36 PM
  5. Can I use an 8" touch panel with a 6" lcd?
    By Odie in forum LCD/Display
    Last Post: 10-30-2002, 12:28 AM
