Like Tree13Likes
Thread: "Transflective" LCD panel with res touch+controler for $101+$36 S+H
  1. #1351
    May 2011
    Quote Originally Posted by sebberry View Post
    I believe it is one panel with a parallax barrier splitting up the two images.
    I know Sharp makes the panel, but I don't know how to get them.
    That is possible, but it still need to processes two signals source
    Let me forward to my colleague and see if there is any chance to get them.
  2. #1352
    Constant Bitrate dsballer2000's Avatar
    Oct 2005
    Canada
    my experience so far with visibility
    Just wanted to post some pics of how the screen is working out for me. My first controller board came malfunctioning but working with Derrick to get this one replaced. I couldn't wait for this process so I purchased a second unit to get my project on the run and installed.
    With the screen orientation in my set up, the first pic is the highest level of sun I get which is still clearly visible. The rest is in high sun but not direct.
    Although these pics make it look washed out, it is definitely better in person. Either way, this will give most an idea of what they are working with.
  3. #1353
    Jun 2003
    Chicago
    How is the DAC audio quality when using HDMI? I intend to use this display with the Mimics X2 module (Android) and would like to only connect cable to the phone (don't want to connect to phone headphone jack). Who's tested the DAC audio quality when connected to amps? Does it sound good? I'm not a audiophile but would like to know folks impressions before comitting to this path.
  4. #1354
    Jun 2003
    Chicago
    Thanks, good pics
  5. #1355
    Mar 2011
    Hello Derrick,
    Just a quick idea regarding the 2din case you're planning. I would consider adding Raspberry pi support to the case as it looks like it's going to be very popular in car PC installations too. Also it should not be difficult to do, maybe just the mounting holes...
  6. #1356
    May 2011
    Quote Originally Posted by dsballer2000 View Post
    WoW, you made a pop up screen. that is so nice! looks like OEM. Thanks for sharing
  7. #1357
    May 2011
    Quote Originally Posted by EBJUSTIN View Post
    We did not put a high end DAC ther. so it may not meet audiophile standard...but it is not bad, good for regular use
  8. #1358
    May 2011
    Quote Originally Posted by KoGa View Post
    Hello Derrick,
    there is plenty room, you should be easy to mount the Pi
  9. #1359
    Jun 2003
    Chicago
    ok, fair enough, I suppose worst case I could use a HDMI to analog audio extractor similar to:
    http://www.amazon.com/ViewHD-Analog-.../ref=pd_cp_e_3
  10. #1360
  1. FS: 10.2" LCD Touch kit w/transflective enhancement
    By Motorcity in forum Classified Archive
    Last Post: 03-14-2007, 03:20 PM
  2. Replacement 4:3 8" Touch Panel For "Super"
    By gsd_racing in forum Input Devices
    Last Post: 01-25-2006, 06:28 PM
  3. Replies: 146
    Last Post: 08-19-2004, 04:39 AM
  4. Replies: 2
    Last Post: 12-11-2003, 11:36 PM
  5. Can I use an 8" touch panel with a 6" lcd?
    By Odie in forum LCD/Display
    Last Post: 10-30-2002, 12:28 AM
