Like Tree13Likes
Thread: "Transflective" LCD panel with res touch+controler for $101+$36 S+H
  1. #1361
    Sep 2012
    Hey,
    has anyone tried to fit one of the small form factors controller board and LCD in to a lilliput case?
    It seems to have been done by a few of the members of this forum but from what I gathered, TFT claimed that you'd need to longer ribbon cable, but as far as I was aware, that was the initial release of this screen.
    The main reason i'm asking this is i'm trying to fit a 7" inside an E36. I'm getting a brezel made up by SRCSTC from mybimmer, and from what I can tell, the installation would require a 619,629,669,701 housing.
    Thanks in advance
    Yates
  2. #1362
    Variable Bitrate daclothe's Avatar
    Dec 2004
    Quote Originally Posted by ptrout View Post
    I got the board today and tested. Its a great value for what it is. It does have DAC, (which would have been ~100 add on to my lilliput.)
    Everything works fine, and Derrick has been great with support.
    Few points of note maybe for future board rev.
    Though the board does 2ch audio out, pins are there for L+/- R+/- only L is connected. I will be soldering on a 4 pin connector.
    However, the yellow RCA is also audio out but its mono. I believe in future rev, if the yellow RCA was replaced with 3.5mm stereo jack it would be perfect. As lots of us doing car audio, would use the aux in directly, without any hassle.
    Great product
    i know this was from a while ago, but did anyone end up doing something like this? i was trying to get audio out of the yellow RCA cable, but had a terrible ground loop issue (even with a ground loop isolator).
  3. #1363
    May 2011
    Quote Originally Posted by daclothe View Post
    We should hear some news from the factory by tomorrow, regarding to the 2-DIN case. If I get anything. Will update here
  4. #1364
    Constant Bitrate dsballer2000's Avatar
    Oct 2005
    Canada
    Quote Originally Posted by Yates View Post
    Hey,
    Thanks in advance
    Yates
    In my setup, I fit the lcd, board, vga connection, usb cable, vga cable (the one end), all in the casing. It is not a liliput case but i bet they are the same size.
  5. #1365
    Sep 2012
    Quote Originally Posted by dsballer2000 View Post
    I presume you have the vga only board? Is it the blue or small green board? Did you have any troubles with the length of the LCD ribbon? or the occasional connection between ribbon/pcb or pcb/lcd case?
    Tthanks for your input,
    I've decided to purchase one of the HDMI screen kits to accompany either an ASRock AD-2700 (Atom 2700 // $95) or e350M1/ USB 3 (amd e-350 // $145) or Zotac Fusion Wifi (amd e-350 // $200)...any thoughts there?:P
    Derek i'll be intouch via ebay, how do apply the $10 coupon, i'll drop you a message before i purchase it
  6. #1366
    Low Bitrate Spacelord's Avatar
    Oct 2006
    I'm still wondering, if it is possible to get an alternative firmware to get the source rolled from one to another pressing just one button, like almost every other panel.
    Car: Volvo XC60
    CarPc: intel D945CLF2, 7"-Touchscreen, RoadRunner, IGo8
    HiFi: Diabolo D19/AndrianAudio A165g,2xPolk DB10, Signat RAMbo pimped, BRAX X2000
  7. #1367
  8. #1368
  9. #1369
    Low Bitrate Zephrant's Avatar
    Sep 2010
    So can I buy just the front bezel and whatever I need to use the buttons? I didn't realize this was going to be a whole case. I don't have room in my dash for it, so just need a nice looking front piece for my screen.
    Zotac H55-ITX w/ 802.11n WiFi, i3-550/3.20GHz, 8GB DDR3 1333MHz, 120G Intel SSD, P2140,
    7" pseudo-transflective resistive TS, Win7-64, Centrafuse 4.3, Elmscan Compact 6, BU-353, Rear camera, Trailer camera
  10. #1370
  1. FS: 10.2" LCD Touch kit w/transflective enhancement
    By Motorcity in forum Classified Archive
    Last Post: 03-14-2007, 03:20 PM
  2. Replacement 4:3 8" Touch Panel For "Super"
    By gsd_racing in forum Input Devices
    Last Post: 01-25-2006, 06:28 PM
  3. Replies: 146
    Last Post: 08-19-2004, 04:39 AM
  4. Replies: 2
    Last Post: 12-11-2003, 11:36 PM
  5. Can I use an 8" touch panel with a 6" lcd?
    By Odie in forum LCD/Display
    Last Post: 10-30-2002, 12:28 AM
