Like Tree13Likes
Thread: "Transflective" LCD panel with res touch+controler for $101+$36 S+H
  1. #1391
    Jun 2012
    Germany
    Quote Originally Posted by jlitjens View Post
    Hi Derrick,
    Any word on the left button board?
    And has anyone else received the screen yet? If so, what are your thoughts?
    Cheers,
    James
    Sent from my Nexus 7 using Tapatalk 2
    Hi James,
    I received mine today. Looking very good so far. Didn't have time to test anything though.. The Left Button board is missing as Derrick said. But it doesn't look complicated to mount it, seems to bolt on without having to remove anything. Quality is very nice, the screen bracket doesn't look like cheap plastic and is nice to the touch. The only thing I'm a little concerned about are the cables going to the board connectors, they don't seem very stable to me.. Would move them to much to avoid damage
    Best regards,
    Tobias
  2. #1392
    FLAC rray's Avatar
    Apr 2012
    SF Bay Area
    I sent an email in to Derrick to order the full HDMI case kit and buttons kit. I think it will fit my dash better than the other ddin case out there, and it looks real nice too.
    Sent from my SCH-I535 using Tapatalk 2
  3. #1393
    Jan 2012
    Quote Originally Posted by 8838.com View Post
    Yes, we have the bezel and screen only kit for sale also. Here is all versions
    A. VGA kit with 2-DIN holder= $138
    VGA board w/ Remote
    front bezel
    2 customize buttons board w/ SD
    2pcs holding plate for 2-DIN
    Shipping: DHL= $30, POST= $20
    B. HDMI kit with 2-DIN holder = $175
    HDMI board w/ Remote
    front bezel
    C: VGA FULL 2-DIN kit= $158
    VGA board w/ Remote
    front bezel
    2-DIN ITX Case
    Shipping: DHL= $35, POST= $25
    D: HDMI FULL 2-DIN kit= $195
    front bezel
    2-DIN ITX Case
    So whats the status for these units? Is the motherboard in the picture the dell unit you sell on your ebay page?
  4. #1394
    Newbie Xero's Avatar
    Apr 2006
    Northern VA
    Well, since my build has finally hit a major snag and I'm waiting on a reply from Derrick, here's some eye candy.
    Edit for clarity:
    And here's the cause of my snag. It seems the average "2DIN" dash and "2DIN" aftermarket stereo is actually a tiny bit narrower than the actual 2DIN specification. While I can't fault this unit on being true 2DIN, I don't know what I'm going to do now since I have zero fabrication and/or Dremel skills to make it fit right into what's considered a "2DIN" stereo bezel.
  5. #1395
    Jun 2012
    Germany
    Hi,
    same for me, the case doesn't fit my "Adaptor" Frame! I thought I had the wrong frame, but now as I see this, it doesn't seem so anymore!
  6. #1396
    Jun 2012
    Germany
    Here's a pic of how it looks with my frame.
  7. #1397
    FLAC rray's Avatar
    Apr 2012
    SF Bay Area
    Will it fit with the lcd bezel behind the
    Dash panel like shown?
    Can you find a used dash panel on eBay to use as dremel fodder to develop a solution with?
    I had to do that with my current Android head unit, and hope I don't need to with this kit.
    What mini-itx board did you choose and how was the fit with everything inside?
  8. #1398
    Oct 2006
    Just take a little off each side, use masking tape as a guide...You can do it!
  9. #1399
    Apr 2006
    Northern VA
    Quote Originally Posted by cloned_impalaSS View Post
    Yes, well, I'd prefer to keep my rather expensive bezel I had to have shipped from Subaru Japan in tact in case I ever want to fit a normal size 2-DIN unit back where the PC was going to go. Either way I mis-measured my behind the dash depth so this solution is a no-go either way. I just feel like it wasn't fully clear that this isn't a direct fit for what's generally accepted as a 2-DIN stereo bezel, even if the unit does technically conform to the 2-DIN standard.
  10. #1400
    Apr 2006
    Northern VA
    Quote Originally Posted by rray View Post
    My build:
    PSU: M2-ATX
    CPU: Core i3-3240, stock cooler
    GPU: Ivy Bridge onboard video
    SSD: Samsung 830 Series, 128GB
    Motherboard: Asus P8Z77-I Deluxe
    Memory: 8GB Crucial DDR3/1600
    OS: Win7 x64
  1. FS: 10.2" LCD Touch kit w/transflective enhancement
    By Motorcity in forum Classified Archive
    Last Post: 03-14-2007, 03:20 PM
  2. Replacement 4:3 8" Touch Panel For "Super"
    By gsd_racing in forum Input Devices
    Last Post: 01-25-2006, 06:28 PM
  3. Replies: 146
    Last Post: 08-19-2004, 04:39 AM
  4. Replies: 2
    Last Post: 12-11-2003, 11:36 PM
  5. Can I use an 8" touch panel with a 6" lcd?
    By Odie in forum LCD/Display
    Last Post: 10-30-2002, 12:28 AM
