Like Tree12Likes
Thread: "Transflective" LCD panel with res touch+controler for $101+$36 S+H
  1. #1421
    Oct 2012
    Are there any details on using the audio interface this kit provides? The ebay page shows some kind of 4 pin header that I assume provides right and left channels. However, the image doesn't have an hdmi interface so I'm not sure if the hdmi version is laid out the same. My ideal usage would be to use the hdmi input to feed audio and video, and then use the header to pipe the audio out to an amplifier. Is anyone doing this and is a $20 line output converter sufficient?
    Or better yet does the circuit board have a line level output hidden on it anywhere?
    Intended use is with a raspberry, and while I could just get a usb sound card, it would be a simpler project (less software the raspberry has to worry about) if I could use the lcd panel's output.
  2. #1422
    Oct 2008
    Quote Originally Posted by 8838.com View Post
    finally, they are officially on ebay. here is the links
    HDMI full kit:
    http://www.ebay.com/itm/110966372323
    VGA FULL KIT:
    http://www.ebay.com/itm/121002166617
    HDMI kit:
    http://www.ebay.com/itm/121002169460
    VGA kit:
    http://www.ebay.com/itm/110966376586
    Are we able to see pictures of the mini-itx board mounted inside the enclosure? At this stage Im not sure how hard it would be to mount a hard drive/ power supply inside. On top of that, do you utilize a smaller VGA cable? I believe from the back panel of the motherboard to the VGA input for the screen you would need a cable, the standard one is typically 1m + , so we would have a really long cable to go maybe 5-10cm?
    Thanks in advance.
  3. #1423
    Variable Bitrate rray's Avatar
    Apr 2012
    SF Bay Area
    Here are my progress pictures, showing a Thin Mini-ITX board installed:
    Topside:
    Backside:
    And the BIOS onscreen:
  4. #1424
    May 2012
    Melbourne, Australia
    Hi Derrick and all,
    I am working through getting the screen to display at 800x480. So far I have set the custom resolution but the actual screen still seems to be stuck in 720p mode (see image below) . Any suggestions?
    - using HDMI
    - Intel HD2000 on board graphics with latest drivers
    - Created 800x480, 32 bit @ 60hz custom res
    - set this res via advanced settings
    - the monitor refreshes with smaller screen (see pic)
    - notification that optimal resolution is 1280x720 (see pic)
    - osd of screen says 720p (see pic)
    If you have any idea what to do I'd appreciate it
    Cheers, James
    Sent from my Nexus 7 using Tapatalk 2
  5. #1425
    Apr 2012
    SF Bay Area
    Thanks Meva99 for posting a link to the touchscreen drivers, I was able to get the touchscreen to calibrate and work well with them.
    What I now need, is the drivers for the left buttons panel so I can program them to be of use, and program their color. Did anyone see any drivers for those buttons posted, or did anyone receive a driver with their kit?
    Also, I too cannot create a working 800x480 driver for this touchscreen, it only detects at 800x600. Any tips?
    Thanks,
    Robert
  6. #1426
    Oct 2012
    HDMI 800x480, 32 bit @ 60hz ,the answer will find here www.8838.com/soft/800x480.zip
  7. #1427
    May 2011
    Quote Originally Posted by coucouillu View Post
    Hi,
    I foloww this thread since its first post.
    You have really done such a good job.
    But definitely, NO CAPACITIVE=NO PURCHASE for me.
    I am notsure if you have measured tohe potential of the market with capacitive overlay. It's larger that resistive.
    16 months before, when I was able to buy a capacitive touch screen kit at Motor City Technologies http://www.motorcitytech.com/ (mirrored through http://www.display-touch.com), it was a second birth of my carpc.I will never go back to RESISTIVE TS.
    But I hope, I could read on its website, there is a red banner "6.95 capacitive panel kits arriving soon. Exact fit on Samsung and mini Touch 700".
    I think this company was a partner of you, isn't it? When you say " I don`t see there is a capacitive version coming soon", I understand that you are not talking about Motor City Technologies.
    Please, give more info.
    Thank you.
    Brice.
    Sorry for the late reply
    Yes, Motor City Technologies was our reseller before, we may do business again in the future. The capacitive overlay caused some problem and we put that plan suspended...Motor City should have their own project, but it is not relate to us.
    I will talk to the management and see if we can bring the capacitive plan alive, but it won`t happen soon...any updates, I will post here. hope everyone in the east will have a safe week due to the weather. take care
    Any questions, please email to derrick.ny@gmail.com :)
  8. #1428
    May 2011
    Quote Originally Posted by rray View Post
    I have received my DDIN kit with the optional Left Side Buttons, but I could not find any software drivers in the package. There are 4 USB cables and the LCD panel itself, so I suspect I will need drivers for at least the HDMI Screen 800x480, the SD Card Driver, and the USB Button Interfaces.
    I did not see the driver links posted on the ebay listing page either, so I hope Derrick can post a download link with all the latest drivers available.
    Meanwhile I started a worklog for my project here: 2012 Camaro In Dash PC Project
    Thanks for sharing
    here is download link for all the drivers: www.8838.com/soft/touch.rar
  9. #1429
    May 2011
    Quote Originally Posted by meva999 View Post
    Hi Everyone - I'm new to the forum and wanted to comment on this screen. I picked one up from Derrick and so far he's been extremely responsive to all of my questions. I thought I had a show stopper as well when my trim kit didn't fit the screen.
    Attachment 67815
    I got lucky and the 2 DIN computer case bolted right onto the factory radio frame of my 01 Honda Prelude. The carbon dash trim fits right over top of this screen with a bit of room to spare. I ended up not needing to use the American International trim kit that I bought and this is the end result. I might make a custom fitting for between my CF bezel and the screen to make it look 100% finished but for now it looks great as it is.
    Attachment 67816
    I'll take another picture of the screen up and running later today and include outer dimensions of the screen bezel if anyone needs to double check before buying. For me it has worked out well so far but it really stinks to see others having issues with it.
    Cheers,
    Mike
    Thanks for sharing! anything we can help, let us know. enjoy and take care
  10. #1430
    May 2011
    Hey rray - Here's the link to the touch drivers I got from derrick. The USB slot / SD card for me work plug and play without the need for additional drivers.
    For the resolution I was able to setup a custom resolution under my Nvidia control panel to get the screen to display native 800x480 resolution.
    Thanks for helping
  1. FS: 10.2" LCD Touch kit w/transflective enhancement
    By Motorcity in forum Classified Archive
    Last Post: 03-14-2007, 02:20 PM
  2. Replacement 4:3 8" Touch Panel For "Super"
    By gsd_racing in forum Input Devices
    Last Post: 01-25-2006, 05:28 PM
  3. Replies: 146
    Last Post: 08-19-2004, 03:39 AM
  4. Replies: 2
    Last Post: 12-11-2003, 10:36 PM
  5. Can I use an 8" touch panel with a 6" lcd?
    By Odie in forum LCD/Display
    Last Post: 10-29-2002, 11:28 PM
