Like Tree12Likes
Thread: "Transflective" LCD panel with res touch+controler for $101+$36 S+H
  1. #1441
    Variable Bitrate rray's Avatar
    Apr 2012
    SF Bay Area
    Quote Originally Posted by jlitjens View Post
    Hi RayRay,
    At a guess, the url should be http://www.8838.com/soft/usb_hid.rar
    Cheers,
    James
    Thanks James, I did not notice the _rar should have been .rar and kept getting 404 errors.
  2. #1442
    Apr 2012
    SF Bay Area
    [QUOTE=Leon64;1484540]
    Thanks for the suggestion Derrick. I have spent 2 hours googling and nothing
    Install the monitor driver from here ( www.8838.com/soft/800x480.zip)
    Thanks for the link Leoo64, I tried to load the intel GMA 3150 drivers in that package, but it replies "your computer does'nt meet the minimum requirements" even though my hardware well exceeds those requirements.
    I won't be able to do anything with my screen resolution, sadly Intel refuses to write windows 7 64bit drivers for the GMA 3650 graphics adapter on my motherboard. I am stuck at 800x600.
  3. #1443
    Apr 2012
    SF Bay Area
    Did anyone figure out how to program their left panel buttons yet?
    All I can do is change their color, and when I do it, selecting blue makes the buttons glow green, green turns them red, and red turned them gray, and white turns them off.
    I tried configuring the bottom buttons for volume up and down, but nothing happens when I press them except the light burns brighter for a few seconds. I was wondering if I need to do anything special like put any of the files in a system directory or something?
  4. #1444
    Sep 2011
    Has there been any word on the left button panel availability? I sure would like to get my setup finished. =)
  5. #1445
    Apr 2012
    SF Bay Area
    A couple of us got the left panel buttons from Derrick, by emailing him directly with inquery.
    I loaded the USB driver for the buttons, but cannot figure out how to program them, only how to change the color.
    -Robert
    Sent from my SCH-I535 using Tapatalk 2
  6. #1446
    Nov 2012
    Netherlands
    Finally gor to read all 145 pages, and I must say it is an awesome project and the project is just what I was looking for.
    Although im not sure what computer (Raspberry pi, ODROID-X2,..) I will be using, I know what case and screen Ill be using
    I would like to order a HDMI full kit soon, but will it include the button side board?
  7. #1447
    Nov 2012
    Hello everyone, Raspberry Pi user reporting in. I found this forum and thread while I was waiting for delivery from Derrick. Today I got the parcel, connected the screen to the controller board and managed to hook my raspi to it through HDMI input.
    In case there are any raspi users, my settings (/boot/config.txt) are as following:
    hdmi_safe=0
    no overscan
    framebuffer_width=848
    framebuffer_height=480
    hdmi_force_hotplug=1
    hdmi_group=2 # DMT mode
    hdmi_mode=14 # 848x480 @ 60 Hz
    config_hdmi_boost=4
    hdmi_ignore_edid=0xa500080
    The screen works okay, touch works as well (Linux recognizes it as a standard mouse, though I think it needs to be calibrated a bit). I couldn't manage to make raspi to switch to 800x480 resolution. Playing with framebuffer sizes and overscan values got me nowhere. Apparently raspi's firmware doesn't support this resolution, but I heard they will include support of arbitrary resolutions in near future. The best I could get is 848x480 shrunk into 800x480, so horizontally pixels are not aligned and appear blurred. I drew a test picture with 1px thin horizontal and vertical lines to see how it appears on the screen. As you can see, the horizontal lines (top middle and bottom left squares) are clearly visible while vertical lines and dot grids are blurred.
    Now I have a little problem. After approximately 5 minutes of work an 1px thin red line appears at the very bottom of the screen and black interlace lines start to rise from the bottom. These lines appear only on color pixels, black and white rectangles are unaffected. The interlace gets as high as 80-90 px from the bottom. These effects don't appear instantly but rather slowly grow withing several minutes.
    I though the problem was the signal from raspi, but then I switched to AV channel with no signal (with blue screen option on) - both red line and interlace appeared on the blue screen. When I let the screen cool for a couple of minutes (with controller board running) and then turn it on, the effects disappear. Anyone else has this problem? Also I would much appreciate advices as how to get native resolution on raspi.
    Update: Apparently the lower part of the screen where these effects appear gets very hot. Maybe the problem is in my power source? I'm using 12 V 2 amps adapter.
    DigitalVampire likes this.
  8. #1448
    Apr 2012
    SF Bay Area
    I discovered why I cannot program the Left Panel HID buttons, it appears they are incorrectly mapped to different functions. I discovered when I program Mute it stores Play/Pause and when I program Volume Up, it opens Media Player. Programing blue buttons gets green, program green and get no LED at all, program red and get purple, then program white and you get red.
    Derrick, can we get an updated version of the USB_HID.rar utility with correctly mapped buttons?
    Thanks,
    Robert
  9. #1449
    Nov 2012
    Quote Originally Posted by Niek View Post
    Yeah, I ordered this kit too and it included the button side board.
    The interlace and red line on my screen were definitely caused by its overheating. A placed the screen on an elevated surface with air underneath, now it works okay for many hours!
  10. #1450
    May 2011
    Sorry for the late reply. due to the hurricane Sandy, we lost power for almost two weeks, and runs on battery with very limit internet access every day.
    Thanks for electricians from all over the states & Canada to help us out, we finally got recover!
    Any questions, please email to derrick.ny@gmail.com :)
  1. FS: 10.2" LCD Touch kit w/transflective enhancement
    By Motorcity in forum Classified Archive
    Last Post: 03-14-2007, 02:20 PM
  2. Replacement 4:3 8" Touch Panel For "Super"
    By gsd_racing in forum Input Devices
    Last Post: 01-25-2006, 05:28 PM
  3. Replies: 146
    Last Post: 08-19-2004, 03:39 AM
  4. Replies: 2
    Last Post: 12-11-2003, 10:36 PM
  5. Can I use an 8" touch panel with a 6" lcd?
    By Odie in forum LCD/Display
    Last Post: 10-29-2002, 11:28 PM
