Like Tree13Likes
Thread: "Transflective" LCD panel with res touch+controler for $101+$36 S+H
  1. #1491
    May 2012
    Did anyone manage to get raspberry pi working with this touchscreen? Does it work in XBMC? What linux did you use??
  2. #1492
    Aug 2010
    Quote Originally Posted by nivanov View Post
    I hate to sound like a broken record, but now that the current product line is complete, any chance you'd wanna give a capacitive version a crack? Alternatively, is tft_lcd_org still retrofitting these monitors with capacitive multitouch overlay?
    I second that!
    The fact that it isn't capacitive is the main reason why I haven't purchased one yet. Tft_lcd_org is out of stock (no word on when it will be back in stock - if ever.) Had there been a capacitive option, I would've gotten at least 3 already.
  3. #1493
    Sep 2005
    Quote Originally Posted by mrkjcy View Post
    I second that!
    Same here. I can't believe there are now so many <$100 Android tablets with 7" capacitive screens but we have very little available as a standalone screen
    Car news and wallpaper site: www.carfeed.net
  4. #1494
    Nov 2012
    Brisbane, Australia
    Hey Derrick, I think you may have some problems with your left hand button board...
    I was wondering why mine wasn't working very well so I wrote a simple key logger which tells me the ascii and keycode of any key being pressed and got the following results:
    I set the 6 keys as power(cannot be changed), f1 , f2, f3, f4, f5
    1st button (power) does not light up nor does it register any key inputs (maybe it registers power button which isn't a key that i cant read...)
    2nd button lights up and registers f4, not f1
    3rd button lights up and registers f3, not f2
    4th button lights up and registers f2, not f3
    5th button lights up and registers f1, not f4
    6th button lights up but does not register any key inputs.... :/
    I also noticed that the key press is only registered when no lights are on on the button control and only after you press a key, and it lights up, it registers the key, and while the light is on, it will not register the key again until the light turns off, making it rather useless for volume up/down in real time
    Also note, the side button came installed with the screen and case and i have not touched it at all
    Andrew.
  5. #1495
    Low Bitrate Zephrant's Avatar
    Sep 2010
    So does anyone know how to set the brightness and contrast from Windows? I want them both set to zero at night, and 100% during the day from a script.
    This time of the year, I have to turn up the brightness every morning and turn it down every night.
    Zotac H55-ITX w/ 802.11n WiFi, i3-550/3.20GHz, 8GB DDR3 1333MHz, 120G Intel SSD, P2140,
    7" pseudo-transflective resistive TS, Win7-64, Centrafuse 4.3, Elmscan Compact 6, BU-353, Rear camera, Trailer camera
  6. #1496
    FLAC rray's Avatar
    Apr 2012
    SF Bay Area
    Quote Originally Posted by shukamanon View Post
    Mine does the same thing, and I was replied that some boards were built upside down. I am only able to use the 4 inner buttons, programed upside down because of this issue. Also, I cannot program the color I want, blue. I had tried to get a schematic from Derrick, so I could fix mine, but he never replied, so when he posted boards were available a couple weeks ago, I ordered one in hopes I get a properly built button board this time.
    I don't care about the cost, I just want one that works correctly so I can finish off my box.
  7. #1497
    FLAC rray's Avatar
    Apr 2012
    SF Bay Area
    Quote Originally Posted by Zephrant View Post
    I have been using Driveline as my front end, and it automatically dims the screen by time of day, so you might be able to contact Clockwork and find out how he did it.
  8. #1498
    FLAC rray's Avatar
    Apr 2012
    SF Bay Area
    My new Left Button Board arrived, and it works correctly. Now I can select Blue LED's and the buttons are in the correct order, from top to bottom, button 1 is a momentary switch to connect to the motherboard's power (front panel header), and button 2-6 are programmable. You can program Red, Blue, Green, White, Off, and Red+White, using a combination of the 4 programable colors, and a jumper on the board.
    There is no microphone however, but you can solder on a small electret condenser type, then use the bottom micro JST header to connect it to the front panel microphone header with your own cable.
  9. #1499
    Dec 2007
    The backlight on my unit has failed. I am currently awaiting resolution/replacement from Derrick.
    I will keep all of you posted.
  10. #1500
    Oct 2005
    Southern Maryland
    I am also waiting to see a capacitive screen available for this unit. Everything else about it looks/sounds incredible!
    Are there any options (including DIY) for a capacitive screen in these units? I love the buttons, the inputs, etc.... but I don't think I could ever deal with a resistive screen again :| Please let me/us know!
  1. FS: 10.2" LCD Touch kit w/transflective enhancement
    By Motorcity in forum Classified Archive
    Last Post: 03-14-2007, 03:20 PM
  2. Replacement 4:3 8" Touch Panel For "Super"
    By gsd_racing in forum Input Devices
    Last Post: 01-25-2006, 06:28 PM
  3. Replies: 146
    Last Post: 08-19-2004, 04:39 AM
  4. Replies: 2
    Last Post: 12-11-2003, 11:36 PM
  5. Can I use an 8" touch panel with a 6" lcd?
    By Odie in forum LCD/Display
    Last Post: 10-30-2002, 12:28 AM
