Like Tree13Likes
Thread: "Transflective" LCD panel with res touch+controler for $101+$36 S+H
  1. #1501
    FLAC rray's Avatar
    Apr 2012
    SF Bay Area
    You might like this resistive screen. It is really sensitive, and if you calibrate with a stylus, very accurate. When using a finger to navigate a front end, it's just fine. I use my fingers with Driveline, and response is instant without using any pressure, just like a capicitive screen. But unlike a capicitive screen, you can use the stylus in windows to touch those tiny file icons, where a capicitive screen would be more finicky because your fingertip covers 4 or 5 icons at a time if using a minimal working windows 8 resolution.
    That aside, I would like to have a multitouch driver for this screen so I could slide screens in windows 8. The current driver acts like a mouse pointer instead of a multi touch screen.
  2. #1502
    FLAC mauri's Avatar
    Jan 2004
    NOT tested.. but try if work this driver:
    http://www.touch-intl.com/drivers/resdrivers.html
  3. #1503
    FLAC rray's Avatar
    Apr 2012
    SF Bay Area
    Awesome, I will try. Downloading TI-TOUCHKIT-V.5.0.1.5310.zip for Windows 7.
  4. #1504
    FLAC mauri's Avatar
    Jan 2004
    And this is the standard driver update/site for most all touch 4 wire resistive panel:
    http://home.eeti.com.tw/web20/eg/Touch_Drives.html
    Edit: tested, but NO multitouch.
  5. #1505
  6. #1506
    May 2011
    Quote Originally Posted by madbird View Post
    Yep received mine pretty fast too. I had some initial problems with the screen not lighting up (loose cable) and trying to obtain 800*480 resolution. Derrick was great in providing support to resolve these issues.
    I have a question on the left button board. I understand the top button is non programmable and serves as a on/off button. With just a USB connection, I don't quite understand how to power on the pc. I am also not able to power off. Am I missing something here?
    Sorry for the late reply. for some reason we do not get update notice by email...
    here is how to connect the power switch to your computer.
    anything else we can help, please feel free to email us. enjoy and have a wonderful 2013!!
  7. #1507
    May 2011
    Quote Originally Posted by rray View Post
    Just as a mouse. I tried to install some windows 7 drivers from eGalax Touch , and some experimental windows 8 drivers, but did not get multi point touchscreen to work.
    The Touch.rar drivers linked in this thread work with windows 8, but I could only get mouse mode out of them.
    You are right. because this is not a multi-touch layer. so only works as a mouse
  8. #1508
    May 2011
    It's a momentary contact switch that you connect to the power button header on the motherboard. You could also use it for reset if you prefer.
    What you do is have 12v battery to the yellow wire input to power supply, red or white power supply goes to the car's blue acc switched when car starts, and blk to gnd. Then you find the computer power button 2 pin out from your power supply to send the momentary pulse that boots your motherboard.
    Thanks for helping!
  9. #1509
    May 2011
    Quote Originally Posted by nivanov View Post
    I hate to sound like a broken record, but now that the current product line is complete, any chance you'd wanna give a capacitive version a crack? Alternatively, is tft_lcd_org still retrofitting these monitors with capacitive multitouch overlay?
    currently I don`t see any capacitive project going on...anyway, I will update here if I hear anything
  10. #1510
    May 2011
    Quote Originally Posted by shukamanon View Post
    Hey Derrick, I think you may have some problems with your left hand button board...
    I was wondering why mine wasn't working very well so I wrote a simple key logger which tells me the ascii and keycode of any key being pressed and got the following results:
    I set the 6 keys as power(cannot be changed), f1 , f2, f3, f4, f5
    1st button (power) does not light up nor does it register any key inputs (maybe it registers power button which isn't a key that i cant read...)
    2nd button lights up and registers f4, not f1
    3rd button lights up and registers f3, not f2
    4th button lights up and registers f2, not f3
    5th button lights up and registers f1, not f4
    6th button lights up but does not register any key inputs.... :/
    I also noticed that the key press is only registered when no lights are on on the button control and only after you press a key, and it lights up, it registers the key, and while the light is on, it will not register the key again until the light turns off, making it rather useless for volume up/down in real time
    Also note, the side button came installed with the screen and case and i have not touched it at all
    Andrew.
    yes, few shipments came in with upside down button settle. it only make a little confuse in setting(upside down), once you finish, it will be fine.
    if this is really bother you, we can replace for you. but has to wait because available quantity still keep low...
  1. FS: 10.2" LCD Touch kit w/transflective enhancement
    By Motorcity in forum Classified Archive
    Last Post: 03-14-2007, 03:20 PM
  2. Replacement 4:3 8" Touch Panel For "Super"
    By gsd_racing in forum Input Devices
    Last Post: 01-25-2006, 06:28 PM
  3. Replies: 146
    Last Post: 08-19-2004, 04:39 AM
  4. Replies: 2
    Last Post: 12-11-2003, 11:36 PM
  5. Can I use an 8" touch panel with a 6" lcd?
    By Odie in forum LCD/Display
    Last Post: 10-30-2002, 12:28 AM
