I'm sure derrick will send you the correct hdmi board. Send him an email. SNO
I ordered the $195 HDMi panel and there is a female HDMI port on the PCB board. Can't miss it really! I'm sure Derrick will send out the right part!
On other notes, I managed to convert an old single DIN pull out monitor using one of these, I just ordered an extra set of cables and basically extended the wiring using an old 28AWG floppy cable, pics available if anyone is interested? :D
So far it's been in the car for 2-3 months and it works flawlessly!
Got my screen today and it's all up and running.
One problem i've had, i tried to use the usb_hid utility to set up the buttons on the left hand side.
It came up in Chinese and silly me, i started clicking buttons. Now the left hand side buttons are showing a mix of red and white colour, not white like they were before.
I haven't changed any jumpers or switches, so it's as it came, how can i reset the buttons back to standard?
Never mind, found the language switch utility and got it sorted out.
I've installed the 800x480 driver that has been linked to here and installed it, however it only shows desktop as a thin strip across the screen, with black bars top and bottom.
Windows reports 800x480 but the screen says 800x600 60hz. Sure enough, putting Windows to 800x600 fills the screen.
Is there a different setting required for the VGA version I have? My graphics card is an Intel GMA3150 and i've used the driver linked here.
How does this screen compare to a lilliput? Going to be doing my install this year.
Ok, got my HDMI board, hoping it's not DOA!
Does anyone know what it means when the brightness button on the right side just flashes and not much else happens?
Standby from memory....could be wrong.have you got a hdmi feed into it? Try av1/2also.
Sent from my GT-N7000 using Tapatalk 2
