Like Tree13Likes
Thread: "Transflective" LCD panel with res touch+controler for $101+$36 S+H
  1. #1521
    Raw Wave SNOtwistR's Avatar
    Nov 2009
    Keswick,On Canada
    I'm sure derrick will send you the correct hdmi board. Send him an email. SNO
  2. #1522
    Feb 2013
    Quote Originally Posted by SNOtwistR View Post
    I believe so too! - Was just much confusion at first, all should be just fine in a little while
    Quote Originally Posted by James39 View Post
    I paid the 195 - and it's much more obvious after checking out rrays build that I got the VGA version.
    I ordered the $195 HDMi panel and there is a female HDMI port on the PCB board. Can't miss it really! I'm sure Derrick will send out the right part!
    On other notes, I managed to convert an old single DIN pull out monitor using one of these, I just ordered an extra set of cables and basically extended the wiring using an old 28AWG floppy cable, pics available if anyone is interested?
    So far it's been in the car for 2-3 months and it works flawlessly!
  4. #1524
    Dec 2003
    Yep, I'd expect a little wait for the part though.
    I've ordered a monitor via ebay and it won't ship until next week due to Chinese New Year. It's the one week that you can't get anything to happen in China.
  5. #1525
    Dec 2003
    Got my screen today and it's all up and running.
    One problem i've had, i tried to use the usb_hid utility to set up the buttons on the left hand side.
    It came up in Chinese and silly me, i started clicking buttons. Now the left hand side buttons are showing a mix of red and white colour, not white like they were before.
    I haven't changed any jumpers or switches, so it's as it came, how can i reset the buttons back to standard?
  6. #1526
    Dec 2003
    Quote Originally Posted by lkernan View Post
    Never mind, found the language switch utility and got it sorted out.
    I've installed the 800x480 driver that has been linked to here and installed it, however it only shows desktop as a thin strip across the screen, with black bars top and bottom.
    Windows reports 800x480 but the screen says 800x600 60hz. Sure enough, putting Windows to 800x600 fills the screen.
    Is there a different setting required for the VGA version I have? My graphics card is an Intel GMA3150 and i've used the driver linked here.
  7. #1527
    May 2009
    How does this screen compare to a lilliput? Going to be doing my install this year.
  8. #1528
    Maximum Bitrate tft_lcd_org's Avatar
    May 2010
    Detroit, MI
    Quote Originally Posted by liquidh8 View Post
    Depends on what Lilliput monitor you compare it to. In terms of numbers, the Lilliput 669 (regular and high bright versions) both are brighter.
  9. #1529
    Feb 2013
    Ok, got my HDMI board, hoping it's not DOA!
    Does anyone know what it means when the brightness button on the right side just flashes and not much else happens?
  10. #1530
    Maximum Bitrate camo.b's Avatar
    Nov 2011
    Standby from memory....could be wrong.have you got a hdmi feed into it? Try av1/2also.
    Sent from my GT-N7000 using Tapatalk 2
  1. FS: 10.2" LCD Touch kit w/transflective enhancement
    By Motorcity in forum Classified Archive
    Last Post: 03-14-2007, 03:20 PM
  2. Replacement 4:3 8" Touch Panel For "Super"
    By gsd_racing in forum Input Devices
    Last Post: 01-25-2006, 06:28 PM
  3. Replies: 146
    Last Post: 08-19-2004, 04:39 AM
  4. Replies: 2
    Last Post: 12-11-2003, 11:36 PM
  5. Can I use an 8" touch panel with a 6" lcd?
    By Odie in forum LCD/Display
    Last Post: 10-30-2002, 12:28 AM
