Like Tree13Likes
Thread: "Transflective" LCD panel with res touch+controler for $101+$36 S+H
  1. #1531
    May 2009
    Quote Originally Posted by tft_lcd_org View Post
    Depends on what Lilliput monitor you compare it to. In terms of numbers, the Lilliput 669 (regular and high bright versions) both are brighter.
    Good question, I don't remember the one i have.
  2. #1532
    Feb 2013
    Quote Originally Posted by camo.b View Post
    Standby from memory....could be wrong.have you got a hdmi feed into it? Try av1/2also.
    Sent from my GT-N7000 using Tapatalk 2
    Got it, wasn't sure how to change input, needed to use remote!!! --
    Thanks. Nice little display. Touch works great.
  3. #1533
    Maximum Bitrate camo.b's Avatar
    Nov 2011
    Touch is super sensertive on a hot day.almost capacitive like.
  4. #1534
    Feb 2013
    Do you have the HDMI version? If so, does the "brightness" button toggle brightness? Mine brings up the OSD menu, but you can't do anything, must do Monitor OSD with the remote.
    When I had the VGA board, the brightness button toggled 5 brightness settings, I'd like to know how to get it back (maybe I need to download the drivers/control panel app?)
    Would be nice if there was a set of instructions out there for this.
  5. #1535
    Nov 2011
    I had the first hdmi version in open frame.so i only had the remote the adjust the brightness as i didnt have clean acces to the button board.from memory it was the same as what u said.5 up and 5 down.yours should have the auto dimming wire right? Am curious to know if this is preset or adjustable....
  6. #1536
    Nov 2011
    I did think the right hand 2 buttons were hardware buttons for the screen only...but the left 5 or so buttons were usb hid configurable.
  7. #1537
    Nov 2011
    A detailed manual would be nice....
  8. #1538
    Feb 2005
    Cali
    What do you mean in terms of numbers?
    Hey all,
    I've been looking at these for quite some time, especially the photos when they are in bright or direct sunlight. When you say in "terms of numbers" that the Lillputs are both brighter, do you mean that their specifications for brightness or luminance (greater cd/m2) are better? Or that the Lilliputs are actually brighter in real use, specifically in bright or direct sun? I am under the impression that the "transflective" technology used in these is supposed to make them more visible in direct sun than the Lilliputs. Either way, they are way more visible than the screen I have in my cheap pullout.
    Your input is greatly appreciated and thanks to all who have been contributing to this forum.
    Cheers
  9. #1539
    Nov 2011
    I dont know about the lilliputs but i would say the photos that are on the ebay description are accurate for a bright day if you sitting in the front of your car looking at the screen.if it was a slightly shaded or had a bit of a hood,it would get a lot better.veiwing angles are about the same too meaning side to side its good.here in australia its gets pretty bright and hot in summer with this screen you need to pick your frontend skin carefully as some i found made it look very washed out when you crank the brightness up.i use cf4 and the stock skin was my choice.
  10. #1540
    Feb 2013
    From what little I can tell, the 2 right side buttons (power and brightness) interface directly with the board. I have a feeling the HDMI board just isn't programmed properly for those 2 buttons to work as advertised Brightness control with a touch sure would be nice.
    I have a question in with the seller regarding the HDMI board and these one-touch features.
  1. FS: 10.2" LCD Touch kit w/transflective enhancement
    By Motorcity in forum Classified Archive
    Last Post: 03-14-2007, 03:20 PM
  2. Replacement 4:3 8" Touch Panel For "Super"
    By gsd_racing in forum Input Devices
    Last Post: 01-25-2006, 06:28 PM
  3. Replies: 146
    Last Post: 08-19-2004, 04:39 AM
  4. Replies: 2
    Last Post: 12-11-2003, 11:36 PM
  5. Can I use an 8" touch panel with a 6" lcd?
    By Odie in forum LCD/Display
    Last Post: 10-30-2002, 12:28 AM
