Like Tree13Likes
Thread: "Transflective" LCD panel with res touch+controler for $101+$36 S+H
  1. #1611
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    Quote Originally Posted by 8838.com View Post
    Hi, we suggest you use a DC-DC PSU, or connect directly to car`s 12V cigarette port. If you put it at home, an AC-ADAPTER will be recommend
    regular AC-DC PSU will be too powerful and easy to burn the board
    how can it be too powerful? if you get an ac-dc psu with a 12v output and at lease 2 amps. seems like you'd be good to go witha ac-dc psu
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
  2. #1612
    May 2011
    Quote Originally Posted by scott_fx View Post
    That is what I got reply from the tech guy, after we receive few burn board replies by using the regular PC-PSU
    It is not saying the AC-PSU will burn the board 100%, but there is a chance, so we do not recommend to use PC AC-PSU.
  3. #1613
    FLAC rray's Avatar
    Apr 2012
    SF Bay Area
    I used the intellegent dc-dc converter from the mp3car store, set to 12v output, and it powered th carpc and screen fine. (atom 2800 based)
  4. #1614
    Feb 2012
    I see you must have done what I did and made an adapter rray. However i Want someway to go directly from the car battery to a 12v 2amp output. Any ideas anyone? I really dont want to burn up another one.
  5. #1615
    May 2011
    Quote Originally Posted by psi3000 View Post
    DC-DC PSU is the best solution. Or, you can use the cigarette port 12V, that one has protection circuit which is safe to use
  6. #1616
    Maximum Bitrate camo.b's Avatar
    Nov 2011
    If your handy with a soldering iron you can get a decent heatsink,small amount of pcb a couple of diodes and a 7812ct voltage regulator the 7812 has 3 pins voltage in..ground and vol out.pretty easy and it will cope with 2amp with a decent heat sink....
    Can do the same with a 7805 voltage reg for a stable 5v.these can be lined up in a project box so you can have 9-14v in and a stable 12v and 5v out...costs very little and a bit of fun
  7. #1617
    Feb 2012
    This is great. I am very handy with a soldering iron. Do you have a schematic?
  8. #1618
    Feb 2012
    Maybe 8388.com can chime in and tell us the actual power consumption of the LCD? As the 7812ct is only rated for 1.5 amps.....
  9. #1619
    Raw Wave SNOtwistR's Avatar
    Nov 2009
    Keswick,On Canada
    The problem with using the 7812 is that if alternator/engine is not running, the battery does not provide enough power to work the 7812 properly, most regulators like this need a 2v overhead above the output so technically you need a constant 14v. I am in the same delema, I want to regulate for led lighting, very low draw but not enough input power. Just my 2 cents SNO
  10. #1620
    Nov 2011
    Good point Sno it really didn't think bout that.as mine goes on and off with the ingition....the 5v 7805 for my usb parts is happy.
  1. FS: 10.2" LCD Touch kit w/transflective enhancement
    By Motorcity in forum Classified Archive
    Last Post: 03-14-2007, 03:20 PM
  2. Replacement 4:3 8" Touch Panel For "Super"
    By gsd_racing in forum Input Devices
    Last Post: 01-25-2006, 06:28 PM
  3. Replies: 146
    Last Post: 08-19-2004, 04:39 AM
  4. Replies: 2
    Last Post: 12-11-2003, 11:36 PM
  5. Can I use an 8" touch panel with a 6" lcd?
    By Odie in forum LCD/Display
    Last Post: 10-30-2002, 12:28 AM
