Like Tree13Likes
Thread: "Transflective" LCD panel with res touch+controler for $101+$36 S+H
  1. #1631
    Raw Wave SNOtwistR's Avatar
    Nov 2009
    Keswick,On Canada
    Getting a bit off the posts topic, but for 5v and 3.3v-1.5a. http://canada.newark.com/webapp/wcs/...&storeId=10196 This item is the best solution, small, no heat, efficient. SNO
  2. #1632
    FLAC rray's Avatar
    Apr 2012
    SF Bay Area
    I bought some of those, and wanted to power a USB hub with one, but my hub wants 2 amps. I wonder if I can put 2 in parallel, or would they fight each other like switching supplies do? I had a glorious fire at a model train show when I setup a12v switching supply in parallel with one my buddy installed several feet away.
    Back to topic...
    Sent from my SCH-I535 using Tapatalk 4
  3. #1633
    Feb 2012
    I am being told by Derek now that the cigarette port is fine to power these. As it has a protected circuit. Not sure if my 1970 chevelle has this circuit in it. How could i replicate this circuit?
  4. #1634
    Feb 2012
    the only circuit i am finding in cigarette receivers are a fuse and a relay.....
  5. #1635
    Nov 2009
    Keswick,On Canada
    I think what he is saying is that if you use the cig lighter adapter its fine as the adapter will regulate the 12v but he might also mean if you hook up wires to the wires going to cig lighter socket it is fused with usually a low amp fuse say around 10amps. But I personally would regulate the power going to the screen. Just my 2 cents SNO
  6. #1636
    FLAC rray's Avatar
    Apr 2012
    SF Bay Area
    I think that most cigarette lighters are powered only when the engine is running, where older cars they were always on. So you can use the ignition wire to trigger a standard automotive relay, and run the 12v to the lighter through that relay and back to the lighter to upgrade it if its always on.
    -Robert
  7. #1637
    Feb 2012
    This should work right?
    http://www.ebay.com/itm/1-to-3-Car-C...item1c2ac46fcb
    12v 5Amp , so if im running 2 of these screens at 2.5 Amps I should be fine, right?
    comes with a 5v 500mA as well.
  8. #1638
    Feb 2012
    If I were to use the digikey part Sno supplied what other capacitors/diodes ect would i need. Or should it be exactly like this :
    http://www.eidusa.com/Electronics_Voltage_Regulator.htm
  9. #1639
    Nov 2009
    Keswick,On Canada
    You don't need anything with that regulator, it is all built on that little T-220 board Thats why I love them so much. Here is all you need to do. SNO Name:  minireg.jpg
  10. #1640
    Feb 2012
    LOVE IT!!! Ordering like 15! Thanks again snow!
  1. FS: 10.2" LCD Touch kit w/transflective enhancement
    By Motorcity in forum Classified Archive
    Last Post: 03-14-2007, 03:20 PM
  2. Replacement 4:3 8" Touch Panel For "Super"
    By gsd_racing in forum Input Devices
    Last Post: 01-25-2006, 06:28 PM
  3. Replies: 146
    Last Post: 08-19-2004, 04:39 AM
  4. Replies: 2
    Last Post: 12-11-2003, 11:36 PM
  5. Can I use an 8" touch panel with a 6" lcd?
    By Odie in forum LCD/Display
    Last Post: 10-30-2002, 12:28 AM
