Like Tree13Likes
Thread: "Transflective" LCD panel with res touch+controler for $101+$36 S+H
  1. #1641
    Mar 2005
    Is anyone selling a multitouch (capacitive) TMR or transflective screen yet in 7"?
  2. #1642
    Maximum Bitrate camo.b's Avatar
    Nov 2011
    Chalkboard electronics in malaysia have a 7".... glossy screen tho..google them and have a look.I have there 10.1" kit,its nice
  3. #1643
    Feb 2012
    Quote Originally Posted by SNOtwistR View Post
    You don't need anything with that regulator, it is all built on that little T-220 board Thats why I love them so much. Here is all you need to do. SNO Attachment 70323
    ou
    Shoot, I just saw you were talking about something else as your pic
    has 3 prongs and this one has 4:
    http://www.digikey.ca/product-search...on=on&x=13&y=9
    Is this the same?
  4. #1644
    Raw Wave SNOtwistR's Avatar
    Nov 2009
    Keswick,On Canada
    That one is the 2amp output and just a plain old regulator. It will need caps on both sides of + feeds on in and output and 1 connection is for turning it on or off. The other unit I showed you has the caps built on the little circuit board but is only 1.5amp output and no on/off pin. SNO
    Looks like 0.33uF cap on input side and 47uF on output side
  5. #1645
    Feb 2012
    cool, do I wire them from the chip negative to the screen positive , and negative to the chip on the input to positive to the battery? Also these are plastic, so i take it there is no need for a heat sync?
  6. #1646
    Nov 2009
    Keswick,On Canada
    No need for heat sink since you are only dropping alittle bit. you could feed 12v+ from ignition on and it will turn on the regulator and monitor or feed pin 4 12v+ from battery and it will always be powered. SNOName:  12vregulator.jpg
  7. #1647
    Feb 2012
    AWESOME, AN IDIOT PROOF DIAGRAM! Just what i needed. Thanks SNO!
  8. #1648
    Feb 2012
    If i dont have a .33uf rated at 12v can i use another 47 uf in its place?
  9. #1649
    Nov 2009
    Keswick,On Canada
    The caps should always be at least a 1/3rd higher in voltage rating (my opinion only) I personally would like to see a 16v cap on output side and a 25v cap on input side. They are really just to smooth out the current flow. You could go with larger size uF wthout much problem, just not under size. SNO
  10. #1650
    Feb 2012
    By the way if anyone is looking for the 3 prong 12 v.220 chips already on a massive heat sync, just disassemble a old atx power supply for a PC. I found 4 of them hooked up to a heat sync. And m not sure but I think the other heat sync had the 5 v ones...
  1. FS: 10.2" LCD Touch kit w/transflective enhancement
    By Motorcity in forum Classified Archive
    Last Post: 03-14-2007, 03:20 PM
  2. Replacement 4:3 8" Touch Panel For "Super"
    By gsd_racing in forum Input Devices
    Last Post: 01-25-2006, 06:28 PM
  3. Replies: 146
    Last Post: 08-19-2004, 04:39 AM
  4. Replies: 2
    Last Post: 12-11-2003, 11:36 PM
  5. Can I use an 8" touch panel with a 6" lcd?
    By Odie in forum LCD/Display
    Last Post: 10-30-2002, 12:28 AM
