Like Tree13Likes
Thread: "Transflective" LCD panel with res touch+controler for $101+$36 S+H
  1. #1661
    Maximum Bitrate camo.b's Avatar
    Nov 2011
    Quote Originally Posted by fishpost19 View Post
    Ahh, sorry, I meant switch from HDMI to RCA, not VGA
    It will switch from any input to reverse cam rca when power is applied..then switch back.fast switching too.its very nice
  2. #1662
    Jan 2009
    Quote Originally Posted by redheadedrod View Post
    If you have an HDMI screen and you have both MHL and USB outputs from your phone you can drive the screen from your phone and use the USB port to connect to the USB touch screen and it would work like a mouse. I have actually hooked a mouse to my SG III before as a test as well as a keyboard. Haven't gotten the MHL port working with it though. There are Samsung branded docks that will allow me to have an HDMI and USB ports so I do know they are out there.
    Quote Originally Posted by camo.b View Post
    It sure will.
    Thank you for your info. Readheaddroid, i don't thing it is possible to connect both usb touch-interface and the mhl output.
    If the hdmi output works ok, then it is good for me. My concern then is, because the phone's output resolution is highter than the native resolution of 800x480, how good or bad will that look.
  3. #1663
    Jan 2009
    One more strange thing i noticed. Please if someone could give me some info
    Both my TV and computer monitor are full HD (1920x1080).
    When i connect my phone to the computer monitor, it ouputs at: 1280x720 60hz (which is the phones native resolution)
    When i connect my phone to the TV set, it ouputs at: 1920x1080 30hz (that's what my tv OSD says)
    I believe the true output resolution is the first one which is phones native resolution. Is that right?
    If so, can this topic's screen play with that resolution? In the ebay description it says 800x480 native and it supports 1080p. What about any in between resolutions?
  4. #1664
    FLAC rray's Avatar
    Apr 2012
    SF Bay Area
    This screen will support all kinds of in between resolutions. It's just that the fonts get so small you cannot see them. Also, at 1280 x 720, the aspect ratio is not perfect, it's like circles get turned into ovals.
    DimitrisTS likes this.
  5. #1665
    Jan 2009
    rray thank you so much for your help. I think I will trust what you say and I will order it
  6. #1666
    Apr 2008
    I have an earlier driver board and it is kind of picky with its resolutions. I'm running Windows 8.1 so anything that isn't 768 height wont' work with the Modern UI. My board won't display 1280x768 or 1280x800 so I'm running at 1440x900.
  7. #1667
    Jan 2007
    Does anyone have any pictures of Windows 8 running on these screens? Like the start screen, Xbox music and internet explorer.
  8. #1668
    FLAC rray's Avatar
    Apr 2012
    SF Bay Area
    Probably not many photos of the screens you want out there. I had grief because the graphics driver, Intel HD3650, was not too friendly under Windows 8 as well as the minimum resolution required by Win 8 made fonts too small to read, although they were clear, just too small. I hated the stupid Metro interface, so never used it. I cant take new photos as that system was pulled, and is in my junk box now.
    I have a picture of Firefox running on windows 8 on this screen:
    Here is Drivelines HD Radio screen running on windows 8 on this screen:
    Here is a BIOS Screenshot on this screen:
    And here is the screen in my car on a cloudy day with Drivelines Phidget screen under Windows 8:
  9. #1669
    Jun 2011
    Atlanta
    Quote Originally Posted by Stooj View Post
    I recently bought one of these and have a few notes/problems:
    A) Connecting the "Audio In" connector fried one of the ICs on the display board (CS6---, located between the "Audio IN" and "To Speaker" connectors on the ebay image). Luckily the rest of the display functions and disabling HDMI audio appears to stop usage of the dead IC. There's no instructions as to how to connect the audio header. Confusingly, the Audio header cable has a USB header 8pin block, not the FPAUDIO 8pin block (the blank is in a different spot). Under the assumption it operated as a USB device, I plugged it into a header and it cooked. Strangely, the screen powered up as well without 12V supplied! Only 5V from the USB header was supplied, so I can only assume the 5V was flowing from the motherboard header and reaching the screen (via the audio connector? wtf?)
    I'm currently debating whether to order a new board. But even then, what's to say connecting the audio header wouldn't kill it again? I'm feeling lucky enough it didn't kill my ITX motherboard. Has anyone actually connected this and got it functioning? Pics would be nice.
    B) The left-side button board requires at least 3 screws. The center of the PCB flexes, such that the buttons in the middle are UNUSABLE and the force required on the buttons is overcome by the PCB flexing. I'm currently trying to find a way around this.
    C) The touch software works fine in Windows 8. But I can't swipe from the edges. I may need to tweak the edge detection settings.
    D) The 12V screen input works fine of the 12V Molex supply on my PicoPSU. I just cut and soldered the cable to one of many PCIE->Molex splitter cables I have lying around. Side-effect being the screen is only powered when the PC is, but that's no biggie (I don't intend on using the screen without the PC on).
    I noticed the flex also." B) " I took a brass square tube and notched it to sit under the side mounting bracket. I had to wrap it in a insulating material. ( electrical tape) I also needed to file the lower part of the bracket. So it did not put to much pressure on the board. Seems to be fine now.
    Still working on my projects details. Before I put it all together and in. Hope this helps.
  10. #1670
    Jan 2009
    Audio output has 4 pins. Labeled 1 2 3 and 4. Which one is what channel and which is the ground? I am trying to connect them to a 3.5mm audio plug.
  1. FS: 10.2" LCD Touch kit w/transflective enhancement
    By Motorcity in forum Classified Archive
    Last Post: 03-14-2007, 03:20 PM
  2. Replacement 4:3 8" Touch Panel For "Super"
    By gsd_racing in forum Input Devices
    Last Post: 01-25-2006, 06:28 PM
  3. Replies: 146
    Last Post: 08-19-2004, 04:39 AM
  4. Replies: 2
    Last Post: 12-11-2003, 11:36 PM
  5. Can I use an 8" touch panel with a 6" lcd?
    By Odie in forum LCD/Display
    Last Post: 10-30-2002, 12:28 AM
