Page 169 of 175 FirstFirst ... 69119159160161162163164165166167168169170171172173174175 LastLast
Results 1,681 to 1,690 of 1747
Like Tree13Likes
Thread: "Transflective" LCD panel with res touch+controler for $101+$36 S+H
  1. #1681
    kdl
    kdl is offline
    Mar 2012
    Quote Originally Posted by wrxcv View Post
    KDL unfortunately not a straight fit , I own a 2012 and the unit is 10-15mm to deep and depending on which factory facia you have , there are two the standard with is a little wider opening and a DD one made for like an Sony , Pioneer unit. Both are the incorrect size (about 3mm to narrow in the opening) as the unit is made to the correct DD sizing.
    But I knew this before I brought the unit and I have both facia and I got the unit only on Friday (had a hang over on Saturday) so I aint got around to making a decision yet if to trim out the 3mm and square the corner on the new DD facia or laser cut and adaptor ring to fill the standard facia in. On the depth side of things I have the unit so now I can work around that problem of what to do. There is the main bar the dash is mounted to so it not like just cut this and all is good im sorry to say. E3io in this thread http://www.mp3car.com/newbie/156262-...or-to-not.html if you have a read Novak points out that that company use's the front screen and a Small Edition (BYBYTE BlackBox) to get the depth down, but depending on the hard wear your going to use this maybe not an option.
    For me I got the case and screen and will modify / rebuild from there it was only $20 differences between getting it with or with out, plus its a nice reference point to start from, anyway I hope that helps in some way....
    Wow, so the model for sale on ebay will not fit in the WRX without some modes? If thats the case i may just go with my first idea and try to fit a tablet in the dash, if i have to cut into it anyway
  2. #1682
    Feb 2012
    Quote Originally Posted by SNOtwistR View Post
    No need for heat sink since you are only dropping alittle bit. you could feed 12v+ from ignition on and it will turn on the regulator and monitor or feed pin 4 12v+ from battery and it will always be powered. SNOAttachment 70356
    SNO
    I dont think this is right. pin 2 is 12 output, not ground. I made three of these and could not figure out why pin 3 was only out putting .8 volts. I will cross-refference the datasheet :
    http://sharp-world.com/products/devi...pq05rd21_e.pdf
    I will post what i find out.
    thanks
  3. #1683
    Feb 2012
    yup, i see now. on fig.1 and fig. 2 on the datasheet they the pins go 1,3,4,2 i guess because its easier to show the diagram with them being in that order. I think you thought 3 was 2. Just wanted to bring it up in case anyone else has this issue. I will build another one today and post later.
  4. #1684
    Feb 2012
    Ok, now looking at the on/off regulator which is the last figure I think your diagram is correct. But when I place it in the bread board I still get .8 volt whether the on switch has high voltage or not. On a whim I flipped the chip backwards and it works! So I think the data sheet is wrong and pin one is on the right if the writing is facing you. So on the data sheet right above "internal connection diagram" and it has the pin outs it should be like your looking down on the chip. Is this correct, like how all data sheets are? Or is this a misprint?
  5. #1685
    Raw Wave SNOtwistR's Avatar
    Nov 2009
    Keswick,On Canada
    I got pin position from the top right picture it shows looking at the chip laying flat with writing face up and pins towards you. As for the accuracy of the datasheet, you will have to verify that with sharp. been awhile since I have used one, and of course no notes to be found. the schematics usually just show the internal circuitry and have no real relation to pin position. I go by the top right image and pin assignment. Good luck SNO
    Also have you done like the right picture pin out as you mentioned you had no power on pin 4 or 2 which are output and turn on maybe you need to apply power to pin 4 to get pin 2's voltage reading and ground on pin 3 just curious
  6. #1686
    Feb 2012
    yeh, this schematic is either wrong or its supposed to be like your looking down at the chip with the pins facing down. I flipped it around and it works GREAT! Thanks SNO!
  7. #1687
    Newbie Kimoo's Avatar
    Sep 2011
    South Africa
    Hi, any luck with getting feedback on this issue? My camera is doing the exact SAME thing. I connected the camera directly to the tv and it works fine.
    Another problem recently occurred is when I switch the screen (car) on, it goes to AV1 by default. This used to be VGA and only switch to AV1 when in reverse gear. Any ideas on how to get it back to VGA default? I tried switching to VGA, switching the screen off then on again but it keeps going back to AV1
  8. #1688
    Nov 2009
    Keswick,On Canada
    Maybe check your wiring to the reverse trigger wire? Also check your reverse light bulb to see if it has stopped working or the bulb is funky. Just a thought SNO
  9. #1689
    Maximum Bitrate camo.b's Avatar
    Nov 2011
    I recently had a similar problem with a screen.defualts got all screwed up..i think my problem was my hid spotlights was somhow powering up the reverse cam wire...it ended up cooking the board...i rechecked the wiring anf redid a lot of it.mainly earthing and battery isolation seemed to sort mine our
  10. #1690
    Jun 2007
    Boston MA
    Is anyone having troubles with the SD card reader? I've actually got two bezels - one with a monitor and one without. With both, I plugged in all 3 USB cables (1 for touch screen, 1 for USB port and 1 for SD reader, I assume), and the touchscreen and the USB port works, but the SD reader does not do jack - it doesn't even show up in Device Manager. Does it need a driver? I assume if it does, it would at least show up in Device Manager. I'm on Win7 SP1.
    My Project: All-in-one Double Din Unit
  1. FS: 10.2" LCD Touch kit w/transflective enhancement
    By Motorcity in forum Classified Archive
    Last Post: 03-14-2007, 03:20 PM
  2. Replacement 4:3 8" Touch Panel For "Super"
    By gsd_racing in forum Input Devices
    Last Post: 01-25-2006, 06:28 PM
  3. Replies: 146
    Last Post: 08-19-2004, 04:39 AM
  4. Replies: 2
    Last Post: 12-11-2003, 11:36 PM
  5. Can I use an 8" touch panel with a 6" lcd?
    By Odie in forum LCD/Display
    Last Post: 10-30-2002, 12:28 AM
