Page 171 of 175 FirstFirst ... 71121161162163164165166167168169170171172173174175 LastLast
Results 1,701 to 1,710 of 1747
Like Tree13Likes
Thread: "Transflective" LCD panel with res touch+controler for $101+$36 S+H
  1. #1701
    Jan 2014
    Quote Originally Posted by camo.b View Post
    I had the board die on me...was last year and it was left on all day...was probably 40 in the car...screen and touch part of board survived tho...if you need a replacement feel free to pm me
    Anyone experience with capacitive touch in freezing temperatures, do they work fine?
  2. #1702
    Newbie JrFaust's Avatar
    Jun 2000
    Eagan, MN
    Quote Originally Posted by haircut View Post
    My Pioneer's capacitive touch screen worked just fine when the air temp dropped below -20 F here in MN, however the display had a slight lag and I didn't want to touch my fingers to the screen, but it did work.
    That's right, you just got passed by a computerized toaster...
  3. #1703
    Dec 2006
    India
    Have anyone tried this screen and touch controller with Raspberry Pi or any Android MiniPC?
  4. #1704
    Jun 2000
    Eagan, MN
    I'm looking at getting one of these screen setups.
    What is the audio quality on the audio out when using HDMI input?
    Thank you,
    Robert
  5. #1705
    Feb 2014
    Does any one know the service of mini socket KCN4 located below the SD card reader board?
  6. #1706
    Feb 2014
    Got an inadvertent answer from Derrick. It is the aux audio connection from the front panel 1/8" plug jack (as suspected). Pin out is (from the bottom) left, right, ground (according to a photo I received). However it really looks like ground is the middle pin.
  7. #1707
    Feb 2014
    Quote Originally Posted by Stooj View Post
    I recently bought one of these and have a few notes/problems:
    A) Connecting the "Audio In" connector fried one of the ICs on the display board (CS6---, located between the "Audio IN" and "To Speaker" connectors on the ebay image). Luckily the rest of the display functions and disabling HDMI audio appears to stop usage of the dead IC. There's no instructions as to how to connect the audio header. Confusingly, the Audio header cable has a USB header 8pin block, not the FPAUDIO 8pin block (the blank is in a different spot). Under the assumption it operated as a USB device, I plugged it into a header and it cooked. Strangely, the screen powered up as well without 12V supplied! Only 5V from the USB header was supplied, so I can only assume the 5V was flowing from the motherboard header and reaching the screen (via the audio connector? wtf?)
    I emailed Derrick about this issue (wrong connector on the PC end of the supplied audio cable) but I guess I wasn't clear enough as his reply didn't address the problem. I replied back to him that the supplied cable is at fault. Hopefully this item will be understood and corrected by the manufacturer sometime.
  8. #1708
    Feb 2014
    Well I feel STUPID. That cable that plugs in to the audio in and Line (by chance) actually is an internal USB cable meant to replace two black longer USB cables (that come from the button board and the main board). What an idiot (me).
  9. #1709
    Feb 2014
    deleted out of more ignorance.
  10. #1710
    Dec 2009
    I'm sorry for not going back through the hundreds of pages to see what monitor you guys are talking about, but is it the one linked in the OP? This one: http://www.ebay.com/itm/New-SAMSUNG-...ht_15332wt_905 ?
    On the page, it says that it is a resistive touch screen, but the OP says it is capacitive. What is the best, budget open frame capacitive touchscreen to get? What do you guys have? You aren't changing the board or anything are you?
    I switched cars and my old lilliput resistive touchscreen is dead and it has been a while since i've been keeping up with the forums, trying to get back into it and install a carpc into my '13 Optima Hybrid, but could use some help finding a good capacitive touchscreen and any testimonies you guys have.
  1. FS: 10.2" LCD Touch kit w/transflective enhancement
    By Motorcity in forum Classified Archive
    Last Post: 03-14-2007, 03:20 PM
  2. Replacement 4:3 8" Touch Panel For "Super"
    By gsd_racing in forum Input Devices
    Last Post: 01-25-2006, 06:28 PM
  3. Replies: 146
    Last Post: 08-19-2004, 04:39 AM
  4. Replies: 2
    Last Post: 12-11-2003, 11:36 PM
  5. Can I use an 8" touch panel with a 6" lcd?
    By Odie in forum LCD/Display
    Last Post: 10-30-2002, 12:28 AM
