Page 174 of 175 FirstFirst ... 74124164165166167168169170171172173174175 LastLast
Results 1,731 to 1,740 of 1747
Like Tree13Likes
Thread: "Transflective" LCD panel with res touch+controler for $101+$36 S+H
  1. #1731
    Oct 2010
    Greece
    Quote Originally Posted by radu81 View Post
    Hello,
    I have some problems with this monitor. I bought it a couple of years ago and since the first day I noticed that the touch screen is not precise. Now is getting worse and cannot use it anymore, I've made a video to show the problem
    As you can see I did the 25 points calibration. Is there any way to solve this problem?
    thank you in advance
    my 800x600 8" touchscreen say something about edges and corners in its settings....! i can rememeber what exactly but i think i ve see it . i am not sure what it does but i think it is there for making ur life easier when trying to tap on the screeen edges.
    Just look on ur settigns in case you have something similar.
    I am having problems pressing things in the corner but i can live with that....!
    Vw Sharan 2007 1.9tdi || Exide 100Ah
    Fuzzy 945gme + core duo T2400 + 2gb ddr 667 + pci nvidia 5500 256mb + kingston v300 60gb + hdd 2.5" 100gb 5400 + Sure Gps module
    Primary monitor 8" 800x600 || Secondary monitor 15.4" 1280x800
    Powered by M2 atx
  2. #1732
    Feb 2014
    Anyone have any success getting the native 800X480 resolution to work over HDMI with Intel integrated graphics?
  3. #1733
    Oct 2006
    Quote Originally Posted by 8838.com View Post
    It is been a long time since our last post here. how is everybody?
    first of all, if anyone have any questions, please feel free to contact us by [email protected]. we are here to help.
    in the mean time, we want to introduce our next project about Car Computer: a LOW COST Win8.1 RT Blade Computer, only around $95! here is the specs:
    nVidia Tegra 3 Quad Core 1.3G CPU
    2G RAM
    32G SSD (64G for a little more)
    Office software Included!
    We done the previous monitor project by getting lot of helps here. Now we need suggestion again, to make a machine that fits your need! Any suggestion will be appreciate
    here are some photos, still under developing. the case should be only 1cm thick, less than 5cm wide, can be easily fit in your car. Plus, it runs very cold and you don`t need to worry about the heat
    Spec looks good, good choice of processor. I think WinRT support is limited, I'd prefer a linux based OS instead, there's a lot of support for them compared to winRT.
    What do you have planned for startup/shutdown? this has been my biggest problem with these kind of system, as they're either on/off, and requires a complete restart every time.
    What about front end? will any front end support WinRT (i haven't been following any front end in a long time)
  4. #1734
    FLAC rray's Avatar
    Apr 2012
    SF Bay Area
    You have to go advanced under the Intel driver and make an 800x480 at 60hz setting, save it.
    Sent from my SCH-I535 using Tapatalk
  5. #1735
    Feb 2014
    That works on a HDMI connection?
  6. #1736
    FLAC rray's Avatar
    Apr 2012
    SF Bay Area
    It did with mine. I have the windows 8 32 bit Intel driver for the 3650 graphics of an atom dm2800mt board and Derrick in NY's 7" HDMI screen.
  7. #1737
    Feb 2014
    Got Derricks Head unit working in our Subaru SVX
    Still messing with loose ends with software and some peripherals but am generally pleased so far.
  8. #1738
    FLAC rray's Avatar
    Apr 2012
    SF Bay Area
    Looks good, glad you actually got it to fit!
  9. #1739
    Dec 2007
    NY
    I got up to page 40...this is too long. My question is, is this monitor really better than http://store.mp3car.com/Lilliput_7_S...p/mon-120.htm?
    The specs look the exact same except the contrast ratio. The contrast ratio of the lilliput is better. Other than that every other spec is the same, so how is the samsung brighter?
  10. #1740
    May 2011
    beijing,china
    Quote Originally Posted by Champak View Post
    maybe this lcd is your best Choice
    http://www.aliexpress.com/store/prod...230822072.html
  1. FS: 10.2" LCD Touch kit w/transflective enhancement
    By Motorcity in forum Classified Archive
    Last Post: 03-14-2007, 03:20 PM
  2. Replacement 4:3 8" Touch Panel For "Super"
    By gsd_racing in forum Input Devices
    Last Post: 01-25-2006, 06:28 PM
  3. Replies: 146
    Last Post: 08-19-2004, 04:39 AM
  4. Replies: 2
    Last Post: 12-11-2003, 11:36 PM
  5. Can I use an 8" touch panel with a 6" lcd?
    By Odie in forum LCD/Display
    Last Post: 10-30-2002, 12:28 AM
