Page 39 of 175 FirstFirst ... 29303132333435363738394041424344454647484989139 ... LastLast
Results 381 to 390 of 1747
Like Tree13Likes
Thread: "Transflective" LCD panel with res touch+controler for $101+$36 S+H
  1. #381
    May 2011
    Nice PS job
    the problem is, this will provide a glossy surface instead of matt...
    Quote Originally Posted by secured-nor1 View Post
    I meant something like this.
  2. #382
    May 2011
    Just discuss this with our design guy. The reason we keep the front un-flat, divide by two sections (screen and button), is preventing mis-operate. When you have a "step", you can find the button section without seeing it :P
    Quote Originally Posted by KoGa View Post
    Looks nice but glossy is absolutely not good for automotive use! Also, I would keep the cost low, if you want to burn $3-400 on a monitor, you have other options. I'd keep this one cheap but very competitive spec wise.
    This is what I was thinking:
  3. #383
    May 2011
    The OSD is invisible all the time now. either changing inputs or resolution. When you touch the "menu", the OSD come out and can be set to transparency
    Here is some samples:
    Quote Originally Posted by z8man View Post
    I like that one the best, I agree glossy is not the best finish inside of a car and would much rather have a matte finish (even though I will be throwing away any housing it comes with because I wont be using it). Right now im just waiting to hear what channels refers to on making the OSD invisible.
    Also LiquidKernal, I am only guessing but it looks like there is a transparency option to make it invisible and the timer adjustment would only apply if transparency is off
  4. #384
    May 2011
    Thanks for your business and supprot. If there is anything else we can help, please feel free to contact us at anytime
    Quote Originally Posted by popi79 View Post
    Hey guys, It's been a while since I don't post but here are my firs impressions on the eBay 7" led form eBay...
    -Item arrived promptly and well packed via Fedex.
    -Easy to connect and I think will be easy to install in my setup since the lack of bezel.
    -Transflective??? I don't think so... It looks better than my old cheapo eBay one that is 5 years old now, but about the same when it was new...
    -Price... tough to beat specially if you need the space.
    I'll keep you updated.
    Cheers.
  5. #385
    May 2011
    Could you tell us, which position you think is the best to fit the buttons? I can share this to our design guy
    Quote Originally Posted by Custommx3 View Post
    I think the buttons need to be moved away from the bottom edge, its going to be a problem for those wanting to mold it in.
  6. #386
    Maximum Bitrate tft_lcd_org's Avatar
    May 2010
    Detroit, MI
    Quote Originally Posted by 8838.com View Post
    Yes, capacitive touch panel can make it flat like iPhone4, but the cost will be much high and it will have glossy surface, which is not good for in-car or out door use
    Now our major consider is keep the price low and provide better screen performance. Like better color and can be use under sun light. Since it is design for camera extend screen and Car-PC.
    Sorry, but I can't agree with this statement. The resistive touch screen dilutes colors, reduces image quality and lowers the brightness of the display.
    True, the capacitive panel is glossy, but in most applications, the added glare is not as bad as some think, and the added benefits of the cap. panel out weigh the gloss issue.
    Resistive panels do not offer better performance.
  7. #387
    Dec 2004
    Quote Originally Posted by tft_lcd_org View Post
    Definitely agree with that.
    Iphone/Ipad have retina type transreflective&capacitive display which are also being used at outdoor. I prefer capacitive over resistive. Resistive is like all the time cataract over the display.
  8. #388
    Mar 2011
    I see... but come on! It's a monitor! Why would you operate it if you don't even see it...?
    Here's a neat idea from my Dell though... It shows the functions for the buttons when the OSD is displayed. Very handy if you're in the dark and the buttons are not lit (are they?).
  9. #389
    Jun 2003
    Memphis - TN
    I'd say move them towards the middle and up from the bottom. That way it can be molded in and not effect the buttons. Also, no powered on LED would be nice.
    Does it have auto power on ? Also, keep the case square, it would be easier to mold in.
    2011 Nissan Frontier SL
    AMD X3 2.2 | M4-ATX | 16Gb SSD | 2GB DDR3-1333 | MSI GF615M-P33 MB
    OBDPROS USB | BU-303 GPS l LILLIPUT TS | Car2PC adapter | XM Direct | USB Dual band N with custom mag-mount antenna.
  10. #390
    Mar 2011
    Regarding to the stand, now the hot-shoe stand is confirmed. dash/windscreen mount is still under develop
    How about making it VESA mountable and people could use any kind of stand they want?
    Even better put a standard 1/4" fixing hole in the bottom which could be used for fixing it on any kind of stand/camera arm, would be wonderful for photo or video guys
  1. FS: 10.2" LCD Touch kit w/transflective enhancement
    By Motorcity in forum Classified Archive
    Last Post: 03-14-2007, 03:20 PM
  2. Replacement 4:3 8" Touch Panel For "Super"
    By gsd_racing in forum Input Devices
    Last Post: 01-25-2006, 06:28 PM
  3. Replies: 146
    Last Post: 08-19-2004, 04:39 AM
  4. Replies: 2
    Last Post: 12-11-2003, 11:36 PM
  5. Can I use an 8" touch panel with a 6" lcd?
    By Odie in forum LCD/Display
    Last Post: 10-30-2002, 12:28 AM
