Page 45 of 159 FirstFirst ... 35363738394041424344454647484950515253545595145 ... LastLast
Results 441 to 450 of 1583
Like Tree12Likes
Thread: "Transflective" LCD panel with res touch+controler for $101+$36 S+H
  1. #441
    May 2011
    Quote Originally Posted by LiquidKernel View Post
    Glad to see you guys got it updated with the OSD changes like we wanted! The price increase is reasonable, just wish it didn't change
    The video cable from the screen to the board appears to be a 40-pin FFC (Flexible Flat Cable), most likely 0.5mm pitch. If that is the case, for $20 USD you can buy an extension board and cable. http://diy-beamer.com/product_info.p...1391502847b561
    Thanks for your understanding for price raise. HDMI board is little expensive than the previous VGA one. We are doing everything we can to keep the price low, especially for friends on mp3car
    by the way, why we need the extension? can`t we just put the board behind the screen? that is what we plan to do
    Any questions, please email to derrick.ny@gmail.com :)
  2. #442
    May 2011
    Are the current pre-orders for the display with the newer firmware (with OSD options)?
    Yes, after the 2nd load, all with newer firmware. I think most of friends here is in 3rd load. so you guys should be all good
  3. #443
    May 2011
    Sorry for the late reply
    The 4 pins is for the touch-screen and the 6 pins is for the back light. If you change to capacitive touch panel, You have to use another control module for capacitive because it is different as resistive.
    For the cable length, we suggest you just set the board behind the screen. You don`t need to use the extension cable.
    Quote Originally Posted by z8man View Post
    Can the manufacturer confirm the pitch of the cable? It looks like there are two other cables as well, a 4 and a 6 pin, but im guessing at least one of them is for the touchscreen so will probably be different on the capacitive version.
    If the seller or TFT wanted to be really, really awesome. Sell versions with longer ribbons or sell a extension kit for the ribbons for both the resistive and capacitive versions of the screen. I would buy that for sure because I am really worried about how short that ribbon cable is and me damaging it trying to mount the board. And it will also keep me from having to mount the board at an incredibly awkward angle inside my double din enclosure. Pretty please??
  4. #444
    May 2011
    Quote Originally Posted by Sonicxtacy02 View Post
    Derrick was nice enough to send over one of the open frame devices for a review. I'm impressed so far. You can tell certain elements are community inspired... like the length of the wires connecting the button board to the controller and the length of the ribbon cabling. I'm going to give it a rundown for the next few days and post it up with comparison to the lilliput (669HB/659SAW) and mini-touch. Thanks again Derrick.
    You are very welcome. If there is anything else we can help, please feel free to contact us at anytime
  5. #445
    May 2011
    Hi, the new board is designed for wide range volt input, since it design for car use
    It can accept 8V~ 20V Volt, and total around 20W will be safe. 12V is good enough.
    Quote Originally Posted by kortium View Post
    what type of power source this new board need? I`ve ordered board without "AC adapter". What do I need to use this board in car? 12v is enought?
  6. #446
    May 2011
    Sorry, we don`t have the data-sheet for the board yet. But I can tell you the dims about the board. It is 115mm* 92 mm
    Quote Originally Posted by coucouillu View Post
    Hi,
    is it possible to have PDF files of the dimension of the board + connectors?
    or a datasheet?
    Thanks.
    Brice.
  7. #447
    May 2011
    Quote Originally Posted by KoGa View Post
    Ok I received my display today, only had time to try it quickly but noticed that the image does not fit on the screen, all sides showing somewhat off the panel. I will play around with it later on.
    Does the touchscreen need any drivers? I connected it on Win XP and it seem to have recognized and installed the device but the touchscreen function does not work.
    Hi, you can change the resolution, either custom setting in windows or by Powerstrip software
    Here is the link for the touch screen driver if you need:
    http://www.ideacom.com.tw/DR_UTS6680.htm
  8. #448
    May 2011
    Thanks for help us to provide an answer. Really appreciate
    If everyone has a question and we don`t reply prompt here. Please email us at derrick.ny@gmail.com
    Quote Originally Posted by elpres View Post
    What you're experiencing is probably overscan. It occurs on TV panels. Depending on the screen you can either change the fit on the monitor or adjust settings in your graphics card's control application (unless you use Intel HD graphics, then your stuffed if the monitor doesn't allow it).
    Yes the touchscreen does require drivers. You will need to find out what touch controller it uses. The lilliput I got has an egalax controller, if I am not mistaken. You may need to plug in a USB from the touch controller/monitor to the computer, if you haven't done so already.
  9. #449
    May 2011
    Sorry for all the mess you have. That is a big reason we develop the new HDMI board which eliminate most of the problems like touch screen
    Now the major issue should be the capacitive touch. We may work out a solution later.
    Quote Originally Posted by Zephrant View Post
    Review of the VGA input resistive touch screen display.
    I received my display almost two weeks ago (quick shipment, it hit the US two days earlier than promised, although I then lost a day due to having to sign for it) and stuffed it in the car and went on a 10 day trip. I temporarily mounted it in a Lilliput frame I had, and that helped out the quick and dirty mount I did. After getting back to town I do have some complaints:
    • (As otherwise mentioned) the old VGA version is really a hack. It has a controller card with connections for an LCD that are not used, but has a daughter card with more components grafted on to it. The cables go from that card to the display, but the flex cable is also a hack. It has a wide spot on it with active components which make it difficult to tuck the controller card behind the display. It's the type of thing I'd expect to see in the lab as a prototype, but not the type of thing I'd expect end users to get.
    • Drivers disk sucks. The drivers on the included disk are dated no newer than 2007, so don't include Windows 7 drivers, and are labeled in Chinese. Derrick immediately offered to find the Win7 driver for me when I emailed about not being able to read the directory entries, but I was able to locate them myself by trail-installing a few things (and failing), then going to the web page that matched the driver name. (Go here: http://home.eeti.com.tw/web20/eGalax...r/W7Driver.htm)
    • No case: I knew this upfront of course, but not having a case at all does make mounting harder. No easy way to hold the display and controller boards, and no place to put the buttons board. With the tiny flex cables, I was very concerned I'd break something (as I think I did to my Lilliput screen).
    • Resistive touch screens suck. It makes the display look a little milky and no multi-touch (zoom is a PITA), really a downer when you are used to an iPad.
    • Touch pad and drivers are not 100%: I've had a few times when it powered up and Windows 7 refused to recognize the panel. When I rebooted it was fine, but it is impossible to reboot unless you carry around a spare keyboard (which I did). Crawling in to the trunk to unplug/replug the USB might have worked too, I'll try that next time.
    • Not really sunlight readable. Maybe if you are close to it, but not when you are driving down the road and trying to read the NAV. I had to take off my sunglasses and lean in to read it many times, and I still have 20/20 vision. It is better than my old Lilliput, but IMHO, not good enough.
    • You may have to really muck around with the video driver to get your system to do 800x480 at 57 hz. I did, and it was not very easy. I could not get the display to work well at 1024x768 which is what I really wanted.
    I do want to say that Derrick is very responsive and great to work with. I am having an issue with the LCD washing out the blue color in to the adjacent pixels, and I suspect he ran down the issue (dirty pins on the ribbon cable). I'll know for sure when I can pull it out and clean it off.
    So in summary, go for the capacitive touch screen on the HDMI board. Don't even consider the original, unless you were desperate for something before a big trip as I was.
    And as for Centrafuse, I've got a whole other list of complaints for it.
  10. #450
    Mar 2005
    Quote Originally Posted by 8838.com View Post
    I need an extension because I am mounting the screen into a cage like this and the wire isnt long enough to go as far as I need it to
    What can I say, I love Volvos:
    Volvo 740 with 5.0 mustang conversion (totaled)
    Volvo 740 stock (sold)
    Volvo 940se (sold)
    Volvo 850 T-5R yellow (sold)
    Volvo S70 T5SE
    Volvo C70
    Volvo 850R with a long list of mods
  1. FS: 10.2" LCD Touch kit w/transflective enhancement
    By Motorcity in forum Classified Archive
    Last Post: 03-14-2007, 02:20 PM
  2. Replacement 4:3 8" Touch Panel For "Super"
    By gsd_racing in forum Input Devices
    Last Post: 01-25-2006, 05:28 PM
  3. Replies: 146
    Last Post: 08-19-2004, 03:39 AM
  4. Replies: 2
    Last Post: 12-11-2003, 10:36 PM
  5. Can I use an 8" touch panel with a 6" lcd?
    By Odie in forum LCD/Display
    Last Post: 10-29-2002, 11:28 PM
