Page 50 of 175 FirstFirst ... 404142434445464748495051525354555657585960100150 ... LastLast
Results 491 to 500 of 1747
Like Tree13Likes
Thread: "Transflective" LCD panel with res touch+controler for $101+$36 S+H
  1. #491
    Jul 2011
    what methods are there for controlling the power on/off for the hdmi version (with capacitive panel)?
  2. #492
    May 2011
    The remote is considering cancel because most of client said it is useless and it need an IR receiver in the front...I will forward your feedback to our design team and see if they can keep it
    Yes, it has a auto-switch to reverse channel function. The VGA version also has it. Please check the cable come with the control board, which looks same as the power input-plug.
    Quote Originally Posted by Zephrant View Post
    That is disappointing- I want a completely built in look (so no buttons will be visible). Hiding the IR receiver sensor in an air vent and using the remote was what how I was going to control the screen when needed.
    I guess I'll have to move the buttons to a hidden panel someplace.
    Do you have a reverse input so it will auto-switch to the video input when the reverse lights come on? I can't find it on the VGA version.
  3. #493
    May 2011
    Quote Originally Posted by monkeyracer View Post
    Wow! I go away for a few weeks and come back to some nice updates with this panel.
    I don't like the case for a few reasons;
    - the screen edge should be beveled so that you can more easily touch the edge of the panel.
    - the stepped in buttons are great for DSLR guys, but for in the car it is hard to mold into a panel. I actually like the buttons being on the side of the monitor, but for me I will probably get some laser cut/etched buttons made and mold that panel into the car itself. If there is enough interest, and I can get them done for cheap enough, this might be something I would be willing to sell.
    - Since this is being produced for a variety of markets, I think the best bet would be the standard tripod mount, vesa mounts, hot shoe and flash mounts would make it the most versatile. Dash/window mounts can be adapted to the VESA or tripod mounts.
    I will probably just get the eby701 panel and mess with that, but it would be harder to mount the boards...
    I love the new board, and the new OSD options, and will probably be ordering a kit from TFT_LCD_ORG in the near future. This is almost exactly what I need for my build (8" would be nice, but I'll take 7...)
    Thanks for the great responses and the quick development on this thing.
    You are exactly right, the case looks not that good for car user. I discuss this with our design team and what they said was, most of car user will have their own bezel, so they may only need something to mount the board. We are working on this.
    This case is for standard monitor use. it will have the standard tripod mount, vesa mounts and hot shoe mount. Should be OK to mount on dash or windshield
  4. #494
    May 2011
    Quote Originally Posted by hailrazer View Post
    Yea I bought the older version and I am sad to say that it is barely better than a stock Lili.
    I'm sorry but you have to have an optically bonded touchscreen.
    This screen IMO is barely any better in the sun than any other screen that is not transflective.
    Again, it is a sunlight viewable grade screen, like most GPS unit. If it is not transflective, all lights will pass through, no reflection. You can not see the image at all
    we suggest you put a little shade and adjust the brightness to highest, it will helps a little.
  5. #495
    May 2011
    I pulled my LCD from the car. The brightness for my pictures was set to 80, as was the contrast. The other options on the menu are NOSYNCOFF, Hposition, Vposition, and AUTO. When I cranked up the brightness and contrast, the screen did appear brighter (in my office, at night). I'll take another set of pictures with it when I can get my gear back in the car.
    The bad news is that I still have an issue with washed out blue. This is with no VGA plugged in, and it is still "smeared". When booted to windows it is less noticeable, but still there.
    As we discuss in email, if the noisy problem is from the board. We will replace it, no worries
    This is the first time we have issue like this, we will learn now if we get the board back. Again, sorry for the trouble.
  6. #496
    Mod - iPad Forums RipplingHurst's Avatar
    Dec 2007
    Danville, CA
    Quote Originally Posted by 8838.com View Post
    Did I miss the final picture with the case?
    Also, will it have the option to flip the image vertically, so that I can mount it upside down?
    Like this:
  7. #497
    May 2011
    no, we don`t have the final picture yet
    regarding to the flip. Why don`t you just mount the LCD upside down? you don`t need to flip it.
    Quote Originally Posted by RipplingHurst View Post
    Like this:
  8. #498
    Dec 2007
    Danville, CA
    You mean why not upside up?
    1. Generally the bezel is slimmer at the top, and I'd rather see more of the screen area itself than blank plastic, a row of buttons, logos and what not (so no need to lower it that much to see the same thing); if the screen is going to be mounted *perfectly* centered on the monitor enclosure, than yes, it wouldn't make a difference for me.
    2. Easier to mount IF you use that slide mount (like the Xenarc picture above) or screw mount at the bottom-> because then the mounting point is hidden out of view. If I change to vesa, than it makes no difference indeed.
  9. #499
    Mar 2011
    ... I was interested in this screen from the start because of the fact it was simply a screen with no casing, flipping parts, or any other things that drive up the price.
  10. #500
    Dec 2007
    Danville, CA
    Quote Originally Posted by LiquidWater View Post
    WTF? It's not available anymore? What do you mean "it was" simply a screen?
    http://tinyurl.com/3gbawhz
  1. FS: 10.2" LCD Touch kit w/transflective enhancement
    By Motorcity in forum Classified Archive
    Last Post: 03-14-2007, 03:20 PM
  2. Replacement 4:3 8" Touch Panel For "Super"
    By gsd_racing in forum Input Devices
    Last Post: 01-25-2006, 06:28 PM
  3. Replies: 146
    Last Post: 08-19-2004, 04:39 AM
  4. Replies: 2
    Last Post: 12-11-2003, 11:36 PM
  5. Can I use an 8" touch panel with a 6" lcd?
    By Odie in forum LCD/Display
    Last Post: 10-30-2002, 12:28 AM
