Page 51 of 175 FirstFirst ... 414243444546474849505152535455565758596061101151 ... LastLast
Results 501 to 510 of 1747
Like Tree13Likes
Thread: "Transflective" LCD panel with res touch+controler for $101+$36 S+H
  1. #501
    Mar 2011
    Quote Originally Posted by RipplingHurst View Post
    WTF? It's not available anymore? What do you mean "it was" simply a screen?
    http://tinyurl.com/3gbawhz
    I have one right here beside me, but thanks for the link.
  2. #502
    Maximum Bitrate kegobeer's Avatar
    Nov 2010
    Panama City Beach
    Quote Originally Posted by LiquidWater View Post
    ... I was interested in this screen from the start because of the fact it was simply a screen with no casing, flipping parts, or any other things that drive up the price.
    You need to re-read the thread. The screen is still offered without a case. The case being designed is an accessory. The only person talking about mounting it upside down is Ripp.
    1999 Mercury Grand Marquis GS with: ASRock E350M1 w/4GB RAM, 80GB Intel SSD, Opus DCX3.120, Visteon HD Radio + HDR-USB, PL-18N wifi, OBDLink Scan Tool, BTA6210 BT, BU-353, Win 7 Ultimate, CF 4.0, Alpine MRP-F240 + MRP-T220, RF Punch 1572s, Kicker 8" Comp.
  3. #503
    Maximum Bitrate tft_lcd_org's Avatar
    May 2010
    Detroit, MI
    Quote Originally Posted by kegobeer View Post
    .....The only person talking about mounting it upside down is Ripp.
    Being the typical PITA that he is LOL!!!
    (jk ripp, you are alright in my book...)
  4. #504
    Mod - iPad Forums RipplingHurst's Avatar
    Dec 2007
    Danville, CA
    Heh.
  5. #505
    Variable Bitrate hailrazer's Avatar
    Mar 2008
    Columbus, Georgia
    Quote Originally Posted by 8838.com View Post
    Again, it is a sunlight viewable grade screen, like most GPS unit. If it is not transflective, all lights will pass through, no reflection. You can not see the image at all
    we suggest you put a little shade and adjust the brightness to highest, it will helps a little.
    It is not really "sunlight viewable" at all is my point.
    It is not much better than the average Lili or Xenarc screen when viewed in sunlight.
  6. #506
    Jul 2011
    so go buy a LILI OR XENARC for double the price and it will be as you said, worse. lol? Your complaning about a cheaper product with slightly better performance? Sunlight, no matter what, will always be an issue for car screens. The best way to prevent the issue is to somehow position them in a way in which they are shaded. This is how lots of OEM screens are done. IE. Mazda 3/6 etc.
    Anyway, how do people power their screens generally? off the PSU for the computer? Lame question i know, but no matter what i search on this forum i cant be sure what is current information, theres so much here
  7. #507
    Mar 2005
    Yesturday I got the Capacitive version of this screen and spent all day putting it into my frame. I ended up having to use the extension cables I bought from digikey to fit it into my frame. The extension cables were a pretty tight fit, but with some sanding of both the ribbon cable and the LCD screen cable it will fit. The 6 pin was a lot easier to fit the the 40pin was.
    Today I spent all day putting my new ASrock e350m1/USB3 motherboard into my carpc and reformatting the hard drive. Screen looks good, its very bright and much sharper then my old screen was. I didnt get a chance to test it out in the sunlight yet though.
    I am using the HDMI out on my motherboard to feed into this screen. However I didn't realize that for 90% of the boot process the HDMI out is disabled. As well as anytime you are in DOS, such as when installing windows. I had to plug another display into the DVI port so I could reformat the hard drive.
    However two problems I have with it.
    1) When its booting, even though there should be no output to the HDMI port, it will do this weird color shift where it will glow red, then slowly change to glowing white, then will turn black again before it starts showing windows. This always happens when, on the DVI screen, it says "Starting windows" (This is on Windows 7) with the twirling colored orbs that form the windows logo. Really dont like this. This is probably not the screens fault, but does anyone have suggestions on a fix?
    2) In an effort to get to the elusive 800x480 resolution I first tried installing the latest drivers for my onboard ATI 6310 but the lowest it could go was 800x600. So I installed powerstrip and with that was able to set the display to output 800x480. But even at 800x480 the screen does not fill the LCD viewing area, There is a 1" black bar above and below the image and the left side appears cutoff a tiny bit. This is throwing off all my touchscreen presses because it is basing it off the 7" screen size and so I have to imagine the screen fills the whole LCD and where the button should be located and press there. I cannot find any resolutions that fill the whole LCD viewing area, although several are closer then 800x480. I also checked the OSD of the LCD to see if I could expand the screen vertically to make it fit, but that option was not available, I could only move the screen, not shrink/expand it. Any Help??
    What can I say, I love Volvos:
    Volvo 740 with 5.0 mustang conversion (totaled)
    Volvo 740 stock (sold)
    Volvo 940se (sold)
    Volvo 850 T-5R yellow (sold)
    Volvo S70 T5SE
    Volvo C70
    Volvo 850R with a long list of mods
  8. #508
    Mar 2008
    Columbus, Georgia
    Quote Originally Posted by nuk1ear View Post
    I'm not "complaining"
    I am letting people know not to get their hopes up thinking this is a solution to a cheap sunlight readable screen , when it is not.
    And no it is not always an issue. I have a Mo-Co-So 7" sunlight readable that I can view in direct sunlight easily. I have an Inelmatic 7" sunlight readable that is viewable in direct sunlight. I have a 10.4" Avionics that is viewable easily in direct sunlight.
    It is possible. It needs to be transflective , high brightness and have an optically bonded touchscreen with antiglare. It's just going to cost you.
  9. #509
    Dec 2004
    I don't think it is possible. Or at least I don't like the screens that is meant to be transreflective. The best ones are used in the ATM banking and to me, they are still not readable at direct sunlight. I actually never seen any 'readable' screen at direct sunlight. So this is not my hope and the word 'readable' is something relative.
  10. #510
    Mar 2008
    Columbus, Georgia
    Quote Originally Posted by secured-nor1 View Post
    It's not really a matter of opinion.
    All 3 screens I have are completely and totally readable in direct sunlight. I paid $700 for the Mo-Co-So , $580 for the Avionics and $580 for the Inelmatic.
    I am assuming you have not bought a transflective , optically bonded, high brightness, ag touchscreen have you?
    You get what you pay for.
    And I work on automobiles at 14 car lots. There are several car manufacturers that have sunlight readable near perfect touchscreens now. The Dodge Challenger I fixed this week has an awesome 8" that I would sell a firstborn to have in my car. It is beautiful from all angles in all sunlight.
  1. FS: 10.2" LCD Touch kit w/transflective enhancement
    By Motorcity in forum Classified Archive
    Last Post: 03-14-2007, 03:20 PM
  2. Replacement 4:3 8" Touch Panel For "Super"
    By gsd_racing in forum Input Devices
    Last Post: 01-25-2006, 06:28 PM
  3. Replies: 146
    Last Post: 08-19-2004, 04:39 AM
  4. Replies: 2
    Last Post: 12-11-2003, 11:36 PM
  5. Can I use an 8" touch panel with a 6" lcd?
    By Odie in forum LCD/Display
    Last Post: 10-30-2002, 12:28 AM
