Page 59 of 158 FirstFirst ... 9495051525354555657585960616263646566676869109 ... LastLast
Results 581 to 590 of 1580
Like Tree12Likes
Thread: "Transflective" LCD panel with res touch+controler for $101+$36 S+H
  1. #581
    Mod - iPad Forums RipplingHurst's Avatar
    Dec 2007
    Danville, CA
    But that's the plan! I want the mouting points at the top. And then, the image will be upside down, right? That's why I'd need the vertical flip.
  2. #582
    Sep 2005
    Can't you do that through your graphics card drivers?
  3. #583
    Sep 2005
    Quote Originally Posted by z8man View Post
    I bought my entire capacitive kit from display-touch using the preorder and received it about 2 weeks ago.
    Thanks for confirming!
    How do you find the fit of the capacitive touch screen against the LCD? I understand it's slightly larger?
  4. #584
    Dec 2007
    Danville, CA
    Quote Originally Posted by miraclemaker View Post
    I guess. Last time I tried it wasn't reliable. It also wouldn't work on bios. I certainly wouldn't buy without a hardware flick, but I completely understand if it's not possible.
  5. #585
    Jan 2008
    Has anyone had any problems when using the HDMI?
  6. #586
    Low Bitrate Zephrant's Avatar
    Sep 2010
    From an email earlier from Derrick, if you are plugged in to the HDMI port you need to select "DVI" from the LCD's menu for the correct data to be used by the screen.
    The "HDMI" menu option is designed to accept HDMI data from a camera, and is not always compatible with a PC.
    So you can use the HDMI cable port, just select DVI on the screen's menu.
  7. #587
    Dec 2007
    Danville, CA
    OFF TOPIC:
    I suppose the HDMI input was tuned for SLRs that shoot video, to help focus. This would be some such rig, but you'd need an ENCLOSURE for that...where is it? :-)
    And they produce something like this BMW commercial shot with SLRs (more here):
    http://www.youtube.com/watch?v=_e0eC...layer_embedded
  8. #588
    Jan 2008
    Sounds good. I'm excited. Waiting for it to arrive any day now
    Quote Originally Posted by Zephrant View Post
  9. #589
    Aug 2011
    USSR
    how can I get 800-480? I can`t make it work in 800x480 on VGA or HDMI. What parameters should work for powerstrip?
  10. #590
    Jan 2008
    can someone confirm if this uses the same exact power plug as the lilliput?
  1. FS: 10.2" LCD Touch kit w/transflective enhancement
    By Motorcity in forum Classified Archive
    Last Post: 03-14-2007, 02:20 PM
  2. Replacement 4:3 8" Touch Panel For "Super"
    By gsd_racing in forum Input Devices
    Last Post: 01-25-2006, 05:28 PM
  3. Replies: 146
    Last Post: 08-19-2004, 03:39 AM
  4. Replies: 2
    Last Post: 12-11-2003, 10:36 PM
  5. Can I use an 8" touch panel with a 6" lcd?
    By Odie in forum LCD/Display
    Last Post: 10-29-2002, 11:28 PM
