Page 61 of 158 FirstFirst ... 11515253545556575859606162636465666768697071111 ... LastLast
Results 601 to 610 of 1580
Like Tree12Likes
Thread: "Transflective" LCD panel with res touch+controler for $101+$36 S+H
  1. #601
    Jan 2008
    as far as drivers. windows 7 found them instantly and it was ready to go in seconds
  2. #602
    Jan 2008
    Is the RCA input avi1 or 2? I keep getting no signal no matter what I do
  3. #603
    May 2011
    Quote Originally Posted by ed1380 View Post
    Hi. there is a little tricky about the plugs
    unlike normal AV connectors. For this cable, it is reverse: the red and white cables are for AV1 and AV2 input. the Yellow one is for Audio.
    Any questions, please email to derrick.ny@gmail.com :)
  4. #604
    Jan 2008
    Thanks and what is the plug between the usb connector and the AV connector? it looks like a small power plug.
  5. #605
    May 2011
    that one is reverse camera trigger
  6. #606
    Aug 2011
    this is a very convenient solution!
  7. #607
    Jul 2011
    where do i wire up 12v from the PSU (PC PSU)? Straight up to the underside of the main board where the DC in plug is? or is there a special part of the board where i can easily solder in a 12v+ and - to?
  8. #608
    Jan 2008
    I just soldered my psu wires to a power plug.
  9. #609
    Sep 2011
    physical mounting
    I thought I'd add in my mounting options to this thread instead of creating a new one as there might be others who could use some of what I've done.
    I have a couple of kits I am planning on putting in to my van as extra DVD screens. I had all these parts laser cut at pololu.com Their prices are pretty good.
    I had a frame that fits the outside dimensions of the LCD cut from 1/4" ABS. I had holes lasered through it that I tapped to have a 10-32 thread. The frame fits nice and snug into this opening.
    I also made a front bezel out of 1/16" abs, with a smaller cutout made in it. This cut out is the same dimensions as the active screen area. I plan on gluing the 1/16" and 1/4" sheets together. I had hoped that the edges of the two sheets would simply need aligned and then the inactive area of the screen would be covered perfectly. As you can see in the shot below, something must not be "to print" because I get a bit of the touchscreen edge showing. I will need to investigate a bit more, and will probably remove the touchscreen as I will not be using it.
    Lastly I made a small bracket on the back that will hold the control board. It has the same pattern as the 1/4" sheets holes, and then has the hole pattern for the control board). This is 1/16" acrylic (cause it is cheaper than abs, and won't be glued). I plan on attaching the board to the acrylic, then screwing it down to the 1/4" frame to hold it all together.
    Of course, this can all be then molded into whatever you choose, me into the exsisting map pockets of the overhead console of my van.
    I did have a question, what is the best way to glue the flat sheets of 1/16" and 1/4" ABS together? Should I rough up the surfaces and use acetone?
    Tboy
  10. #610
    Maximum Bitrate tft_lcd_org's Avatar
    May 2010
    Detroit, MI
    Quote Originally Posted by Tboy;1457876I
    Tboy
    Use MEK...Methyl Ethyl Keytone. Best for ABS plastic.
    Quote Originally Posted by HiJackZX1 View Post
    This system was supposed to be a quick, cheap throw together that has now exploded into a budget blowing mess.
  1. FS: 10.2" LCD Touch kit w/transflective enhancement
    By Motorcity in forum Classified Archive
    Last Post: 03-14-2007, 02:20 PM
  2. Replacement 4:3 8" Touch Panel For "Super"
    By gsd_racing in forum Input Devices
    Last Post: 01-25-2006, 05:28 PM
  3. Replies: 146
    Last Post: 08-19-2004, 03:39 AM
  4. Replies: 2
    Last Post: 12-11-2003, 10:36 PM
  5. Can I use an 8" touch panel with a 6" lcd?
    By Odie in forum LCD/Display
    Last Post: 10-29-2002, 11:28 PM
