Page 62 of 175 FirstFirst ... 12525354555657585960616263646566676869707172112162 ... LastLast
Results 611 to 620 of 1747
Like Tree13Likes
Thread: "Transflective" LCD panel with res touch+controler for $101+$36 S+H
  1. #611
    Low Bitrate Zephrant's Avatar
    Sep 2010
    What he said, but I'd think that ABS pipe glue would work too, and as it is a moose-snot consistency might be easier than MEK which is water thin (drips all over).
    Elsewhere I've read of people dissolving ABS in MEK to make a slurry, which also has gap filling properties.
    Zotac H55-ITX w/ 802.11n WiFi, i3-550/3.20GHz, 8GB DDR3 1333MHz, 120G Intel SSD, P2140,
    7" pseudo-transflective resistive TS, Win7-64, Centrafuse 4.3, Elmscan Compact 6, BU-353, Rear camera, Trailer camera
  2. #612
    Aug 2011
    USSR
    my install in 2DIN
  3. #613
    Jul 2011
    on the bottom of the main board, for the power plug, there are 3 pins. Which 2 do you use for soldering on + and -? The rear most of the plug for + and the side pin for -?
  4. #614
    Sep 2011
    Thanks guys for the MEK recommendations. I've not been able to find it reasonably. I tried auto parts store who didn't have it, and a paint store that could get me a gallon for 30 bucks! Way more than I would need. I'll stop by lowes and grab some abs pipe cement, that should work fine I think. I wouldn't have thought about that myself!
    Tboy
  5. #615
    Maximum Bitrate tft_lcd_org's Avatar
    May 2010
    Detroit, MI
    Quote Originally Posted by Tboy View Post
    Tboy
    Where do you live? I can drop a small container of it in the mail for the cost of postage.
  6. #616
    Mod - iPad Forums RipplingHurst's Avatar
    Dec 2007
    Danville, CA
    Quote Originally Posted by kortium View Post
    my install in 2DIN
    Great job! What car is this?
  7. #617
    Aug 2011
    USSR
    toyota mark 2 jzx100
  8. #618
    Jul 2011
    can anyone confirm if the bybyte double din frame fits with this screen with capacitive touch? I noticed it was looked at ealier but it wasnt the HDMI board (screen hasnt changed has it?) just want to confirm, roughly 3mm needs to my taken out width on the frame?
  9. #619
    Jun 2006
    Calgary, Alberta
    Blog Entries
    1
    I searched this thread but the answer was not clear. How does the reverse camera trigger? Do you have to apply +12V to a certain line, or will it auto switch if it senses a signal on AV1?
  10. #620
    Jan 2008
    The small round plug by the usb jack.
  1. FS: 10.2" LCD Touch kit w/transflective enhancement
    By Motorcity in forum Classified Archive
    Last Post: 03-14-2007, 03:20 PM
  2. Replacement 4:3 8" Touch Panel For "Super"
    By gsd_racing in forum Input Devices
    Last Post: 01-25-2006, 06:28 PM
  3. Replies: 146
    Last Post: 08-19-2004, 04:39 AM
  4. Replies: 2
    Last Post: 12-11-2003, 11:36 PM
  5. Can I use an 8" touch panel with a 6" lcd?
    By Odie in forum LCD/Display
    Last Post: 10-30-2002, 12:28 AM
