Page 69 of 159 FirstFirst ... 19596061626364656667686970717273747576777879119 ... LastLast
Results 681 to 690 of 1581
Like Tree12Likes
Thread: "Transflective" LCD panel with res touch+controler for $101+$36 S+H
  1. #681
    Newbie Kimoo's Avatar
    Sep 2011
    South Africa
    Quote Originally Posted by 8838.com View Post
    Hi, I got a reply for manufacture, the tech guy have a solution as follow, it should reduce the temp by 20%
    Just put 2 capacitances (1uF 0402) in the yellow position (right mid-bottom). it is not necessary but you if you feel uncomfortable with the temp.
    Attachment 64040
    Ok, I will try this. The caps are really small but I will try my best to solder them
  2. #682
    Nov 2004
    The power cord I had must've been faulty, the LCD functions 100%. Thanks for the info.
  3. #683
    Sep 2011
    Attachment 64040
    Can you attach the whole schematic and the firmware for the board
  4. #684
    May 2011
    Quote Originally Posted by kev711 View Post
    Let me try to ask the manufacture and see if they willing to disclose this. If I can get them, I will upload here
    Any questions, please email to derrick.ny@gmail.com :)
  5. #685
    Sep 2011
    South Africa
    I tried soldering the 2 caps but it didn't seem to have any effect. Derrick, how much will a new controller board cost including postage? Because mine is really getting hot
  6. #686
    May 2011
    Quote Originally Posted by Kimoo View Post
    weird, the tech guy told me this should work, they done the test. Did you use 1uF 0402?
    If you want to get another HDMI board, we can make it 50% off plus shipping, it will be $43+ $26= $69. I don`t suggest you doing this because that board will works fine.
  7. #687
    Sep 2011
    The Board is not written for this LCD module and the RTD2662 IC is not compatible with 15:9 aspect ratios, the IC was built for TV's not monitors. You will get close to 800x480 but with BANDING issues because of the internal scaler. The only way to get a true 1:1 pixel map is to set the display in 4:3 mode and set the resolution to 640x480. Also the EDID is only for the HDMI/DVI port not VGA. If you look at the EDID you will notice the it is wrong also, its is written for a completely different monitor. This is a poor product of someone trying to cash in on the demand for these size screens. They found a cheap board which is listed all over the Chinese B2B.
    What would help us is the SVB-LT0701 in these pics http://translate.googleusercontent.c...3D68gvE_ycVYYQ
  8. #688
    May 2011
    Hi, I really don`t agree what you said "This is a poor product of someone trying to cash in on the demand for these size screens". We put more than 100K and a year in this project and you think it is a "cash in"? What we trying to do is build a low cost, better working monitor for car pc and DSLR camera user.
    let us make it clear here. We were selling LCD panels only before, and lots of clients require a board to driver it up, that is why we found the VGA board to sell. After receiving advises and suggestions here, also helps. We built up the HDMI board, it works better and fulfill most of requirements for car pc, either software and hardware. We can say it is a team work of this whole forum, not just us.
    When the factory were designing this board. The major considerations is HDMI support and lower price. Which they did make it happen. I have no idea what the different between TV`s and monitors. But once it is display 800*480, and support HDMI for PC and camera, what is the problem? We have not seeing the banding issue with the HDMI version as you said when we using 800* 480. I have no idea what you mean. if you can, send us a photo and let us figure out.
    Regarding to the EDID, as I said before, you can write what ever you want. The manufacture just put the one which will compatible and works right. We tried PC and Camera, all OK.
    Again, nothing is perfect, this is just the 2nd Generation product, we still keep improving, like the REV-2 with lower temp chip. Advise or suggestion are still welcome, we are here to listen. hopefully we can finally build up a better car pc monitor, but in low price. that is our target
    PS: no more LVDS version will continue to make, because HDMI is more popular and more simple in wiring for end user.
  9. #689
    May 2011
    Another good news is, after several revision, the complete monitor with case is finally come out, here is the photos. We should be ready to ship out the first load next week
    Backlight/GAMMA Dual adjustable. With SONY F970 battery adapter. Perfect for Canon 5D2!
  10. #690
    Maximum Bitrate tft_lcd_org's Avatar
    May 2010
    Detroit, MI
    Does the LVDS board support EDID?
    Quote Originally Posted by HiJackZX1 View Post
    This system was supposed to be a quick, cheap throw together that has now exploded into a budget blowing mess.
  1. FS: 10.2" LCD Touch kit w/transflective enhancement
    By Motorcity in forum Classified Archive
    Last Post: 03-14-2007, 02:20 PM
  2. Replacement 4:3 8" Touch Panel For "Super"
    By gsd_racing in forum Input Devices
    Last Post: 01-25-2006, 05:28 PM
  3. Replies: 146
    Last Post: 08-19-2004, 03:39 AM
  4. Replies: 2
    Last Post: 12-11-2003, 10:36 PM
  5. Can I use an 8" touch panel with a 6" lcd?
    By Odie in forum LCD/Display
    Last Post: 10-29-2002, 11:28 PM
