Page 77 of 175 FirstFirst ... 27676869707172737475767778798081828384858687127 ... LastLast
Results 761 to 770 of 1747
Like Tree13Likes
Thread: "Transflective" LCD panel with res touch+controler for $101+$36 S+H
  1. #761
    Sep 2011
    Quote Originally Posted by DigitalVampire View Post
    Excellent support Derrick. Really appreciated!
    Now that some solution is in sight for supporting 800x480 natively for most video cards, will this solution be transitioned into production version or will we have to take care of the reprogramming part ourselves?
    If we need to load the custom BIOS ourselves, please explain the procedure. Like me, I'm sure there are many folks here who has access to soldering stations, EEPROM programmers and the such.
    To program the firmware you need a SPI or Willem EPROM Programmer PCB 5.0E which has compatibility for w25xxx series EEPROM.Erase then write new bios. Resolder back to board then your set.Just make sure you do multiple backups of your original bios encase something goes wrong.Also when soldering the chip back make sure you do it correctly or you will have bad solder joints and it wont work,I used hot air quick and easy.You can also make a socket adapter to put the bigger version of the chip that is used in a lot of motherboards.Here is a good guide for soldering http://www.infidigm.net/articles/solder/ NOTE: a good soldering joint will look shinny not dull
    This might work too http://www.ebay.com/itm/Parallel-Pro...item3f103d5386Name:  e_4sqb50192004_0.jpg
  2. #762
    Dec 2006
    India
    Thanks Kev711!
  3. #763
    Maximum Bitrate tft_lcd_org's Avatar
    May 2010
    Detroit, MI
    Quote Originally Posted by kev711 View Post
    Nope, it won't.
    I have that programmer, and it didn't read or write.
  4. #764
    Sep 2011
    I used a Willem EPROM Programmer PCB 5.0E(http://www.ebay.com/itm/PCB5-0E-Will...item4ab1096907)Name:  KGrHqJjIE3SBQI7zBN89B1CGdw_12.JPG
    I soldered the chip to the backside because I didn't want to buy the adapter for that package chip.
  5. #765
    Oct 2006
    SOLD!
  6. #766
    May 2011
    Sorry for the late reply
    we did have a slight update in BIOS for the last two weeks orders, to make this monitor more easy to communicate with video card. But that BIOS is special made for KEV711, not for everybody.
    You should not have the problem like KEV711, 99.99% of our clients were fine with 800*480. With the newer version of BIOS, it should cover everything and make it 100%. So no need to load the BIOS yourself.
  7. #767
    Dec 2011
    Moncks Corner, South Carolina, United States
    Just ordered one for my car pc install.
    If anyone is wondering how to get the mp3car discount, just send him a message with your paypal account email and he will send you a discounted invoice!
  8. #768
    May 2010
    Detroit, MI
    Here are some pictures of the HDMI version installed in a double Din frame w/capacitive multi touch.
  9. #769
  10. #770
    Dec 2011
    What would be a good complete mobo solution with ram sticks hd everything, that will work flawlessly with this screen + controller?
  1. FS: 10.2" LCD Touch kit w/transflective enhancement
    By Motorcity in forum Classified Archive
    Last Post: 03-14-2007, 03:20 PM
  2. Replacement 4:3 8" Touch Panel For "Super"
    By gsd_racing in forum Input Devices
    Last Post: 01-25-2006, 06:28 PM
  3. Replies: 146
    Last Post: 08-19-2004, 04:39 AM
  4. Replies: 2
    Last Post: 12-11-2003, 11:36 PM
  5. Can I use an 8" touch panel with a 6" lcd?
    By Odie in forum LCD/Display
    Last Post: 10-30-2002, 12:28 AM
