Page 79 of 159 FirstFirst ... 29697071727374757677787980818283848586878889129 ... LastLast
Results 781 to 790 of 1581
Like Tree12Likes
Thread: "Transflective" LCD panel with res touch+controler for $101+$36 S+H
  1. #781
    May 2011
    Quote Originally Posted by lr3guyjoe View Post
    Can someone explain how the auto switching works? does it take a 12v trigger or just simply seeing the video source come on it switches? Also on e ebay page it says it has two analog inputs are they both switching?
    I have a back up camera, a night vision camera for the front and a carpc (vga) So when I start the car I'd like to see my car pc but when I go into reverse I'd like it to switch automatically and then back to vga and when I turn on my front night vision camera I'd like it to do the same.
    Will this setup 8838 is offering do what I want?
    Sorry for the late reply
    The trigger is working like this. Once it receive reverse signal from the car, it will auto switch to AV-1(AV-2 not supporting). When the signal disappear, it will switch back to the channel you select before.
    You can connect the back-up camera to AV1, night vision to the AV2, car PC to the VGA or HDMI.
    Any questions, please email to derrick.ny@gmail.com :)
  2. #782
    May 2011
    Quote Originally Posted by Key421 View Post
    what is a good stand for this 7inch screen? I need it to fold up like a laptop. Want to install a monitor on my dash.
    Sorry, we currently don`t have a case like this
  3. #783
    May 2011
    BTW, here is the connection instruction for Rev-C (green board). If you placed order recently, you should get the green one
  4. #784
    Mar 2008
    Hello,
    Just received the monitor. No touch drivers were included. What drivers do I use? Would eGalax Touch be OK?
    Thanks!
  5. #785
    Nov 2011
    Quote Originally Posted by 8838.com View Post
    Yes, if anyone has information on how to get this working, that would be great. For what it's worth, I have tried hooking the backup light power which only comes on in reverse to the trigger connection which is next to the mini USB but cannot get it to trigger. This is a 12V lead and have tried all variations of only the positive lead, both positive and negative leads, but neither seems to work. I'm looking for the "reverse" trigger but not sure this would be any different from the backup light power which is triggered by setting the car in reverse. If anyone has any information, that would be very helpful. For the record, I have an 05 Accord w/o Navi and am having a searched all the Honda forums w/o much help. Thanks.
  6. #786
    Mar 2008
    OK. I hooked it up to my carpc, came up just fine but I pressed some buttons and Auto Adjust kicked in while Centrafuse was on and messed up the screen - now it's zoomed in and off center.
    I can't find a way to activate Auto Adjust - how do I do that?
    XP resolution is set to 800x600.
    Please help!
    EDIT:
    Fixed by changing the refresh rate from 60 to 72Hz - this forced the Auto Config. Switching back to 60 doesn't do any good. Well 72 is OK with me..
  7. #787
    May 2011
    Quote Originally Posted by maxthebuilder View Post
    Hello,
    Thanks!
    Didn`t you get the email about driver? sorry for the trouble. here is the download link
    http://www.ideacom.com.tw/DR_UTS6680.htm
  8. #788
    May 2011
    Quote Originally Posted by harlam View Post
    I will check with our tech guy and give you update
  9. #789
    May 2011
    Please help!
    EDIT:
    Sorry for the late reply and glad to hear you solve the problem
    Just FYI, if you connect to computer by using HDMI port, you need to switch to DVI channel. Also, pressing ">" for 2 second will switch to Canon 5D2 special channel which is 480i. Do the same process will switch back to 1080i.
    keep in touch and have a nice holiday season to everyone!
  10. #790
    Mar 2008
    Sorry, my fault...
    Got the driver - works perfectly!
  1. FS: 10.2" LCD Touch kit w/transflective enhancement
    By Motorcity in forum Classified Archive
    Last Post: 03-14-2007, 02:20 PM
  2. Replacement 4:3 8" Touch Panel For "Super"
    By gsd_racing in forum Input Devices
    Last Post: 01-25-2006, 05:28 PM
  3. Replies: 146
    Last Post: 08-19-2004, 03:39 AM
  4. Replies: 2
    Last Post: 12-11-2003, 10:36 PM
  5. Can I use an 8" touch panel with a 6" lcd?
    By Odie in forum LCD/Display
    Last Post: 10-29-2002, 11:28 PM
