Page 82 of 175 FirstFirst ... 32727374757677787980818283848586878889909192132 ... LastLast
Results 811 to 820 of 1747
Like Tree13Likes
Thread: "Transflective" LCD panel with res touch+controler for $101+$36 S+H
  1. #811
    May 2011
    Quote Originally Posted by maxthebuilder View Post
    I was wondering what that port was for..
    What type of connector does it use? Where "+' and where "-" go?
    Do you guys have all this documented somewhere? Can you put together a short manual and post it?
    We have a connector photo with the listing. it is very simple
    For the reverse trigger. it is a standard connector which you can get the reverse signal cable from your car.
  2. #812
    Mar 2008
    Sorry, I still don't get it!
    What's the difference between "camera" and "pc"?
    I don't have hdmi in either of them. What I have is an Android tablet with HDMI.
    It works with HDMI channel (the picture is cut off but there is a picture) but doesn't with DVI (the screen flickers, looks like the monitor goes between On and OFF every 2-3 seconds)
    Please specify what is the difference between HDMI and DVI "channels"
    Quote Originally Posted by 8838.com View Post
    These two channels are tune for different use
    HDMI is for camera HDMI use and has the 2 sec ">" shortcut key.
    DVI is tune for computer HDMI use.
  3. #813
    Mar 2008
    well. my car doesn't have a "reverse signal cable with standard connector" - I soldered it myself to the backup light...
    I'll take a look at the listing..
    thanks!
  4. #814
    Mar 2008
    checked ebay listings - couldn't find the connector photo. can you send me the link?
  5. #815
    Maximum Bitrate tft_lcd_org's Avatar
    May 2010
    Detroit, MI
    Quote Originally Posted by l337biker View Post
    Nice work tft_lcd_org, I was wondering if you would be making that setup available for purchase?
    I do offer this, on a limited basis. I have the LCD panels with the multi-touch panel installed in stock, but I do not have the HDMI controllers.
    Derrick wants too much for just the controller and since I have the LCD's it does not make sense to buy the entire display.
    If you want one, you can have the HDMI board sent directly to me from Derrick (others have done this and it actually saves them the extra shipping costs).
  6. #816
    Nov 2011
    I bought the HDMI board from Derrick and had it shipped directly to tft_lcd_org to assembled everything as stated in above post. Here are a few pics showing its native 800*480 resolution running on Intel HD over HDMI. I did nothing more than installing PowerStrip and selecting 800*480...as simple as that! Sorry for the dark and somewhat blurry pics. I assure you everything on the screen looks bright and sharp in person. I'm still learning how to use my DSLR properly. The workmanship from tft_lcd_org and the panel from Derrick are simply outstanding!
  7. #817
    Dec 2011
    Quote Originally Posted by tft_lcd_org View Post
    How much is this setup? I would possibly be interested in this setup
  8. #818
    Jul 2010
    My mistake. Our HDMI board has a DAC chip. It can out put 2 channel audio signal if your HDMI has audio source there
    I got the board today and tested. Its a great value for what it is. It does have DAC, (which would have been ~100 add on to my lilliput.)
    Everything works fine, and Derrick has been great with support.
    Few points of note maybe for future board rev.
    Though the board does 2ch audio out, pins are there for L+/- R+/- only L is connected. I will be soldering on a 4 pin connector.
    However, the yellow RCA is also audio out but its mono. I believe in future rev, if the yellow RCA was replaced with 3.5mm stereo jack it would be perfect. As lots of us doing car audio, would use the aux in directly, without any hassle.
    Great product
  9. #819
    Nov 2011
    Any updates to this this issue? One of the reasons I bought the monitor was knowing that it would autoswitch. So far, I haven't been able to use that feature. If you could provide some info on this, that would be very helpful. Thanks.
  10. #820
    Apr 2008
    Do you sell just the dbl-din assembly? I already have the complete lcd/controller and just need a nice way to mount it and your kit looks great.
  1. FS: 10.2" LCD Touch kit w/transflective enhancement
    By Motorcity in forum Classified Archive
    Last Post: 03-14-2007, 03:20 PM
  2. Replacement 4:3 8" Touch Panel For "Super"
    By gsd_racing in forum Input Devices
    Last Post: 01-25-2006, 06:28 PM
  3. Replies: 146
    Last Post: 08-19-2004, 04:39 AM
  4. Replies: 2
    Last Post: 12-11-2003, 11:36 PM
  5. Can I use an 8" touch panel with a 6" lcd?
    By Odie in forum LCD/Display
    Last Post: 10-30-2002, 12:28 AM
