Page 83 of 175 FirstFirst ... 33737475767778798081828384858687888990919293133 ... LastLast
Results 821 to 830 of 1747
Like Tree13Likes
Thread: "Transflective" LCD panel with res touch+controler for $101+$36 S+H
  1. #821
    Dec 2011
    Moncks Corner, South Carolina, United States
    Derrick, I bought one of your screens and installed it to my car. Now I have a problem for you
    I have mounted the bare board onto a plywood frame and put it into the dash of my car. All of the functions of the screen (display/touch) work well, but as soon as the display turns on I see a massive drop in GPS signal strength.
    Using GPSinfo for my BU-353 reciever I see ~45-50 signal strength on multiple satallites before I turn on the car PC. Once I get to windows and the touchscreen starts up I will drop almost all of the satallites and then reaquire them at only 25-30 signal strength. I don't think it is the computer, as I have kept it running with the screen disabled, but there is something with the board that is disrupting GPS.
    Do you have any suggestions on how to shield the board? I have heard aluminium foil on double sided tape can be effective...
  2. #822
    Dec 2005
    Raleigh, NC
    Trigger barrel plug size
    Does anyone know the inner and outer diameter for the reverse-camera trigger plug?
    Also is there a minimum and maximum voltage for the reverse-camera trigger?
    "You're just about as useless as JPEGs to Helen Keller" - Wierd Al
  3. #823
    Nov 2011
    Quote Originally Posted by blafrisch View Post
    Hi,
    I ended up getting one of the tips from Radio Shack and it's the type "H" tip that you can connect to their stripped wire plug. I still don't know exactly what to connect however since Derrick hasn't listed any specs on the connection. I cannot tell you how much voltage is needed, only that 12V will not trigger the autoswitch.
  4. #824
    Dec 2004
    Even the LCD power button off and running in stand-by it suddenly draws some red white and green pixels across the screen. Its like someone throwing sand all over the screen. Is this is a type of glitch?
  5. #825
    Dec 2004
    I managed to capture how the screen behaves.
    It goes red to white. Sometimes greens as well.
  6. #826
    Dec 2005
    Raleigh, NC
    Quote Originally Posted by harlam View Post
    Hi,
    Thank you very much for the sizing. The "H" tip is 3.4mm outer diameter, 1.3mm inner diameter.
    I'll experiment with voltage on my workbench and report back if I get it working.
  7. #827
    Mar 2008
    Wow.. this is no a good news
    ....I cannot tell you how much voltage is needed, only that 12V will not trigger the autoswitch.
  8. #828
    Maximum Bitrate tft_lcd_org's Avatar
    May 2010
    Detroit, MI
    Quote Originally Posted by davedave1234 View Post
    Do you sell just the dbl-din assembly? I already have the complete lcd/controller and just need a nice way to mount it and your kit looks great.
    Yes. PM me for details.
  9. #829
    May 2011
    Quote Originally Posted by maxthebuilder View Post
    Sorry, I still don't get it!
    What's the difference between "camera" and "pc"?
    I don't have hdmi in either of them. What I have is an Android tablet with HDMI.
    It works with HDMI channel (the picture is cut off but there is a picture) but doesn't with DVI (the screen flickers, looks like the monitor goes between On and OFF every 2-3 seconds)
    Please specify what is the difference between HDMI and DVI "channels"
    Sorry for the holiday delay
    The HDMI channel is special tuned for Canon 5D Mark II and other DSLR camera, it will have the short cut key to get into 480i which camera needs.
    The DVI channel is just regular computer tuned. If you using a tablet with below 59mhz refresh rate. It may cause the flick.
  10. #830
  1. FS: 10.2" LCD Touch kit w/transflective enhancement
    By Motorcity in forum Classified Archive
    Last Post: 03-14-2007, 03:20 PM
  2. Replacement 4:3 8" Touch Panel For "Super"
    By gsd_racing in forum Input Devices
    Last Post: 01-25-2006, 06:28 PM
  3. Replies: 146
    Last Post: 08-19-2004, 04:39 AM
  4. Replies: 2
    Last Post: 12-11-2003, 11:36 PM
  5. Can I use an 8" touch panel with a 6" lcd?
    By Odie in forum LCD/Display
    Last Post: 10-30-2002, 12:28 AM
