Page 84 of 175 FirstFirst ... 34747576777879808182838485868788899091929394134 ... LastLast
Results 831 to 840 of 1747
Like Tree13Likes
Thread: "Transflective" LCD panel with res touch+controler for $101+$36 S+H
  1. #831
    May 2011
    Quote Originally Posted by chung_chang View Post
    I bought the HDMI board from Derrick and had it shipped directly to tft_lcd_org to assembled everything as stated in above post. Here are a few pics showing its native 800*480 resolution running on Intel HD over HDMI. I did nothing more than installing PowerStrip and selecting 800*480...as simple as that! Sorry for the dark and somewhat blurry pics. I assure you everything on the screen looks bright and sharp in person. I'm still learning how to use my DSLR properly. The workmanship from tft_lcd_org and the panel from Derrick are simply outstanding!
    Attachment 64568
    Attachment 64569
    Attachment 64570
    Attachment 64571
    Thanks for your supporting and sharing. Enjoy and have a wonderful 2012!
  2. #832
    May 2011
    Quote Originally Posted by harlam View Post
    Any updates to this this issue? One of the reasons I bought the monitor was knowing that it would autoswitch. So far, I haven't been able to use that feature. If you could provide some info on this, that would be very helpful. Thanks.
    Hi, I double check with our tech guy. The reverse trigger is a 12V input. I think the problem is you connect to the wrong AV-1 port, here is the instruction
  3. #833
    May 2011
    Quote Originally Posted by Terry Yu View Post
    Derrick, I bought one of your screens and installed it to my car. Now I have a problem for you
    I have mounted the bare board onto a plywood frame and put it into the dash of my car. All of the functions of the screen (display/touch) work well, but as soon as the display turns on I see a massive drop in GPS signal strength.
    Using GPSinfo for my BU-353 reciever I see ~45-50 signal strength on multiple satallites before I turn on the car PC. Once I get to windows and the touchscreen starts up I will drop almost all of the satallites and then reaquire them at only 25-30 signal strength. I don't think it is the computer, as I have kept it running with the screen disabled, but there is something with the board that is disrupting GPS.
    Do you have any suggestions on how to shield the board? I have heard aluminium foil on double sided tape can be effective...
    I did forward to our tech guy and here is what I got reply
    1. when you connect the AC for the monitor but not turn on the monitor, is the GPS signal drops?
    2. try to find a ground to connect to the power.
  4. #834
    May 2011
    Quote Originally Posted by blafrisch View Post
    Does anyone know the inner and outer diameter for the reverse-camera trigger plug?
    Also is there a minimum and maximum voltage for the reverse-camera trigger?
    The voltage for the trigger is 12V. You need to connect to AV-1 Port to get this works. the AV-2 won`t work with the auto switch
  5. #835
    May 2011
    Quote Originally Posted by secured-nor1 View Post
    Even the LCD power button off and running in stand-by it suddenly draws some red white and green pixels across the screen. Its like someone throwing sand all over the screen. Is this is a type of glitch?
    Try to have a ground with the board, also check the connection of main signal cable from the LCD
  6. #836
  7. #837
    Aug 2011
    Can you please confirm that this works with straight 12v power, the monitor itself I mean. Or do I need a converter for it? I'm close to ready to buy but I need to know this before I do. I know it was in here somewhere but I can't find it, too many pages to go through. Thanks!
  8. #838
    Mar 2008
    yes, it does
    Quote Originally Posted by Scott Carver View Post
  9. #839
    Aug 2011
    Wow thanks for the uber quick response, I very much appreciate it!
  10. #840
    May 2011
    Yes, the monitor itself will work with 12V, 2A input
  1. FS: 10.2" LCD Touch kit w/transflective enhancement
    By Motorcity in forum Classified Archive
    Last Post: 03-14-2007, 03:20 PM
  2. Replacement 4:3 8" Touch Panel For "Super"
    By gsd_racing in forum Input Devices
    Last Post: 01-25-2006, 06:28 PM
  3. Replies: 146
    Last Post: 08-19-2004, 04:39 AM
  4. Replies: 2
    Last Post: 12-11-2003, 11:36 PM
  5. Can I use an 8" touch panel with a 6" lcd?
    By Odie in forum LCD/Display
    Last Post: 10-30-2002, 12:28 AM
