Page 86 of 159 FirstFirst ... 36767778798081828384858687888990919293949596136 ... LastLast
Results 851 to 860 of 1583
Like Tree12Likes
Thread: "Transflective" LCD panel with res touch+controler for $101+$36 S+H
  1. #851
    Jan 2012
    Anybody ever try fitting one of these in a bybyte BBN or BBX-1 case? Will the screw holes on the controller line up? This panel is looking like a winner over the lilliputs...
  2. #852
    Nov 2004
    Quote Originally Posted by kegobeer View Post
    You've posted three times in this thread, and the only problem you've had was due to a faulty power cord. It would help if you took the time to post what problems you've had instead of just saying this is a piece of junk.
    I've talked to derrick.ny numerous times through eBay. My opinion is based on my experience. I requested a refund but he insisted I try out a replacement. I then offered to purchase their AC adapter since my adapter could've potentially been the issue. He said that the adapter would be in the replacement package. No adapter. So I finally found a 12vdc barrel plug coax power cable in town and I'm running into the same issue with this one. I press the power button and after 7 sec the green LED switches to the red LED and begins flashing. The screen itself never lights up or displays anything. I'm not saying he doesn't try to help, but my purchase does not work. After my last post in this thread, the display was operational that one time. I don't have anymore ideas and the screen is the last part of my install. I finished everything else 3 months ago.
  3. #853
    Mar 2011
    Quote Originally Posted by JoezDog4 View Post
    I had a similar issue when I first got mine. The screen would never even have any power and the LEDs would do some weird flashing. Turns out that I had the connections from the LCD to the control board upside down. Those cables only have contacts on one side and I had them the wrong way so they were essentially not even plugged in. As soon as I flipped the power one, the back light turned and it worked perfectly!
    Not sure you are having the same issue but it sounds eerily familiar...
  4. #854
    Nov 2004
    I'll try it again. Could you do a multimeter test on your power adapter and tell me the voltage and current?
  5. #855
    May 2011
    Thanks for supporting. Enjoy and wish everybody a wonderful weekend
    Any questions, please email to derrick.ny@gmail.com :)
  6. #856
    May 2011
    Could you tell me your ebay ID? so I can find out what happen to the replacement kit. This monitor can accept input volt between 8~20v, but needs to be 2A. this is very important or you can not turn the screen on.
  7. #857
    May 2011
    Also, what board did you get? blue or green? they have slight different in connection. LiquidWater is right(thanks!), If you put the cable up side down, the monitor can not turn on also
  8. #858
    Dec 2011
    Quote Originally Posted by tft_lcd_org View Post
    I do offer this, on a limited basis. I have the LCD panels with the multi-touch panel installed in stock, but I do not have the HDMI controllers.
    Derrick wants too much for just the controller and since I have the LCD's it does not make sense to buy the entire display.
    If you want one, you can have the HDMI board sent directly to me from Derrick (others have done this and it actually saves them the extra shipping costs).
    How much is this setup? I would possibly be interested in this setup (This is a repost I think you guys missed my question lol)
  9. #859
    Apr 2008
    sorry to jump in, ive tried looking for this before but this thread has become quite the beast. is there a link to the store where the capacitive monitor can be purchased and what is the coupon code for mp3car members? thank you!!
  10. #860
    Sep 2011
  1. FS: 10.2" LCD Touch kit w/transflective enhancement
    By Motorcity in forum Classified Archive
    Last Post: 03-14-2007, 02:20 PM
  2. Replacement 4:3 8" Touch Panel For "Super"
    By gsd_racing in forum Input Devices
    Last Post: 01-25-2006, 05:28 PM
  3. Replies: 146
    Last Post: 08-19-2004, 03:39 AM
  4. Replies: 2
    Last Post: 12-11-2003, 10:36 PM
  5. Can I use an 8" touch panel with a 6" lcd?
    By Odie in forum LCD/Display
    Last Post: 10-29-2002, 11:28 PM
