Page 89 of 158 FirstFirst ... 39798081828384858687888990919293949596979899139 ... LastLast
Results 881 to 890 of 1580
Like Tree12Likes
Thread: "Transflective" LCD panel with res touch+controler for $101+$36 S+H
  1. #881
    Jun 2010
    Vancouver, Washington, United States
    Peavey,
    Are you not able to do a custom resolution within windows? Right-clicking on the desktop should give you access to an ATI display settings window. It's been years since I used ATI but I can say nVidia still does this. From there you can do custom resolutions. Hoping ATI has similar stuff. It's not something directly available through standard Windows options.
  2. #882
    Dec 2007
    When i look at the catalyst control centre I see 800x480 in the list as supported resolution. when i select it half of the start bar is cut off.
    when i click on Menu on the lcd screen, its showing resolution as 800x600 even though in windows its showing 800x480
  3. #883
    May 2011
    Sorry for the late reply due to the holiday~ Finally we clean up all the messages and orders left over
    Any questions, please email to derrick.ny@gmail.com :)
  4. #884
    May 2011
    Quote Originally Posted by hasun100 View Post
    Hello
    Will this screen work with the mimics iphone module? On they website they claim it works with Any Lilliput 4 wire screen.
    Any help would be greatly appreciated.
    Thanks guys!
    Our screen is 4 wire touch control also. We never try that module but it should works OK. I`ve forwarded this to our tech guy already
  5. #885
    May 2011
    Quote Originally Posted by bratnetwork View Post
    I came across this thread and read through a little of it, but I admit that I have not read the whole thing. One thing I would like to know is, will the screen auto-on/off via the HDMI input or does it only trigger off the VGA like most older screens? If it does not trigger off the HDMI then if you choose the HDMI input and then cut the power to the screen will it come right back to HDMI when power is restored?
    The screen will auto switch on/off when it receive signal. When you put it on HDMI channel and there is HDMI signal come in, it will auto on. Once the signal disappear, it will auto go to sleep mode. Same as the VGA channel
  6. #886
    May 2011
    Quote Originally Posted by windraver View Post
    I've unplugged the unit and upon reconnecting, it starts in HDMI. If I turn it off, upon reconnecting power, it stays off. At least thats its done to this point.
    Don`t switch it off. That will make the screen state in OFF position. Just keep it in sleep mode(when no signal)
  7. #887
    May 2011
    Quote Originally Posted by richpngu View Post
    can anybody tell me what the final price is now with the forum discount?
    We still provide $10 off for MP3car user
    Just contact us by email before you place the order.
  8. #888
    May 2011
    Quote Originally Posted by theBlueLight View Post
    Dredged this one up from page 49, I have not been able to find an answer yet. What a thread! I've got two of these screens with the older VGA board, and need to figure out a way to adjust the backlight. I'm assuming there is a PWM adjust or maybe even a voltage divider I can get access to? Is anyone aware of this?
    Sorry, there is no way to add back-light adjustment to the old board. As I know, it should be control by the new chip
  9. #889
    May 2011
    Quote Originally Posted by peavey View Post
    guys,
    having a bit of problem with my screen setup...
    windows shows resolution as 800x480 but when i click on menu its saying 800x600 !!!
    start bar on the menu is cutoff.. i am using hdmi connection and graphic is ATI Radeon
    help please...
    Hi, the screen shows the real resolution signal it receive. So when it shows 800* 600, means your output has problem. You should google "800*480 driver" with your video card model#, get a correct driver to work on real 800*480
  10. #890
    Jan 2012
    WI
    Quick question... With just the resistive screen, what is the recommended double din case? I see there's cases for the 669 and 629 from bybyte. Is one better or easier to fit than the other?
  1. FS: 10.2" LCD Touch kit w/transflective enhancement
    By Motorcity in forum Classified Archive
    Last Post: 03-14-2007, 02:20 PM
  2. Replacement 4:3 8" Touch Panel For "Super"
    By gsd_racing in forum Input Devices
    Last Post: 01-25-2006, 05:28 PM
  3. Replies: 146
    Last Post: 08-19-2004, 03:39 AM
  4. Replies: 2
    Last Post: 12-11-2003, 10:36 PM
  5. Can I use an 8" touch panel with a 6" lcd?
    By Odie in forum LCD/Display
    Last Post: 10-29-2002, 11:28 PM
