Page 91 of 159 FirstFirst ... 4181828384858687888990919293949596979899100101141 ... LastLast
Results 901 to 910 of 1581
Like Tree12Likes
Thread: "Transflective" LCD panel with res touch+controler for $101+$36 S+H
  1. #901
    Jan 2012
    The depth of the entire enclosure? I'm not sure it varies based on vehicles really. I imagine you'll be limited by whatever motherboard setup you use. Like I said it may be fine the way it is? I'm not sure you should have a recessed lip all the way around the screen though unless you plan on having a trim ring to put around it as many cars wouldn't likely cover that? I'm not entirely sure though. The area I was talking about previously was the edge of the lip between the LCD panel it self and the part that extends beyond it. It just looks deep but could be the picture?
  2. #902
    May 2011
    Quote Originally Posted by Hdale85 View Post
    I think the 2 din case should have a standard for the deep. Will find out more later
    The design of the edge lip may just want to make the boarder look small. I will keep update here if I hear anything more.
    Any questions, please email to derrick.ny@gmail.com :)
  3. #903
    Jan 2012
    Well if you go on Crutchfield or something and look at different 2 din head units some are different depths, also some cars can't fit a lot of double din units because they don't have the space behind the dash.
  4. #904
    May 2011
    will check that out. Our gold is try to make a unit which fits to as many car as possible
  5. #905
    Jan 2012
    Yeah, well figure out what kind of depth you need for the hardware, and then get it as small as you can from that point is what I'd recommend. Also maybe instead of having a full enclosure option like that for people that just want to mount the screen just have it with the ears on the side to mount in the DD kit/dash this way there wouldn't be much depth? Might be a cheaper option as well. But don't remove the nice buttons and stuff on the front just make headers so we can run wires to the CarPC!
  6. #906
    Jan 2012
    Well I can't find any depth info on Crutchfield so maybe they've moved to a standard of some sort.
  7. #907
    May 2011
    Good idea. I will forward this
    I am thinking maybe we can make a short case with open end, so it can fix most of cars. Plus with open end, even the PC board is longer, still can be install with this case.
  8. #908
    Jan 2012
    Maybe tie the buttons, usb port, and card reader into one USB device if possible. The power button would just have to be a header though for the motherboard switch.
  9. #909
    May 2011
    I got little confuse, what do you mean "into one USB device"?
    Another thing. Is anyone think a Radio function is necessarily? I mean. the Radio can work without even turn on the CAR-PC
  10. #910
    Jan 2012
    Some people don't run a head unit (like me) with their CarPC, but you can add an external tuner regardless via USB. Like I'm using a Visteon HDZoom HD radio tuner that has a special cable to go to USB, does AM and FM.
    As for the device, instead of having a bunch of connections for each one (on the stand alone screen version) make it so they all work through 1 USB cable to the PC. So to get a functional screen you'd run HDMI and one USB cable from the CarPC to get the buttons, SD card reader, and extra USB port all over the single cable. Well you'd also have to run a small wire for the power button to work I'd imagine? Or maybe that could work over USB as well just maybe not to turn it on although my HTPC has a USB IR receiver that can turn it on as well but it has to go between the PSU and the motherboard to do that. Not sure how useful a power button is though? Maybe a mute button instead?
  1. FS: 10.2" LCD Touch kit w/transflective enhancement
    By Motorcity in forum Classified Archive
    Last Post: 03-14-2007, 02:20 PM
  2. Replacement 4:3 8" Touch Panel For "Super"
    By gsd_racing in forum Input Devices
    Last Post: 01-25-2006, 05:28 PM
  3. Replies: 146
    Last Post: 08-19-2004, 03:39 AM
  4. Replies: 2
    Last Post: 12-11-2003, 10:36 PM
  5. Can I use an 8" touch panel with a 6" lcd?
    By Odie in forum LCD/Display
    Last Post: 10-29-2002, 11:28 PM
