Page 96 of 158 FirstFirst ... 468687888990919293949596979899100101102103104105106146 ... LastLast
Results 951 to 960 of 1580
Like Tree12Likes
Thread: "Transflective" LCD panel with res touch+controler for $101+$36 S+H
  1. #951
    Jan 2012
    Quote Originally Posted by 8838.com View Post
    Here is the new layout of the bezel. opinion require
    USB HID confirmed. We have 7 touch key in the left side, 4 of them can be customize. other 3 are relate to sound control.
    Attachment 65409
    I see a brightness button, will that be tied in directly to the LCD or will it be a software controlled brightness?
    I'm liking the direction this is going. Not sure what the S button is for though? lol
  2. #952
    May 2011
    Quote Originally Posted by Hdale85 View Post
    Hi, that is a hardware control brightness directly to the LCD, not by software
    Any questions, please email to derrick.ny@gmail.com :)
  3. #953
    May 2011
    Here are more photos
    All 7 buttons on the left side are all customizable (USB HID).
    On the right side. there are two buttons. One for power switch (holding for switch channel). Another is back-light control, by pressing will reduce, and holding will increase the light.
    Also, we integrated the USB HUB in the new HDMI control board. It will have 3 USB on the board and 1 USB port on the bezel, then only one cable to the computer as Hdale85`s suggestion (thanks!).
    So the Front Bezel will have:
    1* USB port
    1* SD CARD Reader
    7* Customizable buttons
    Resistive or Capacitive Touch Screen.
  4. #954
    Jul 2009
    Looking really good, that USB suggestion was great, it may allow me to remove the powered hub I have up front.
  5. #955
    May 2011
    Looking very nice!! The only thing I can think of that would be usefull is a volume knob rather than buttons - but only if it can be incorporated without increasing the cost.
    You could even incorporate the power button with the volume button - a click after min volume to switch off, or push button on the volume knob to switch on/off.
  6. #956
    Jan 2012
    That's looking great!
    The power button does it control the Screen's power of the PC? If the PC then it wouldn't be able to turn it back on I imagine, would just be for off.
    Any idea's on what the capacitive version will cost yet?
  7. #957
    Jan 2010
    Quote Originally Posted by blafrisch View Post
    Finally got around to testing my backup camera tonight. It worked quite well using 12V on a Radio Shack type H connector. Thank you for the image Derrick!
    Radio Shack doesn't show anything for this connector online. Will this work as well for the 12v reverse input trigger?
    http://www.parts-express.com/pe/show...number=120-088
  8. #958
    Jan 2010
    Also, derrick.. when I use the touch panel a little dot appears where I've clicked/touched. Can this be disabled? I can't find any option for it in the driver settings..
  9. #959
    May 2011
    Quote Originally Posted by avir101 View Post
    Thanks for your opinion
    A knob was consider before but the problem is no space to put it. Since the screen is 7" which almost left no space for double dins.
  10. #960
    May 2011
    The power button only control the LCD, not the PC
    For now, I just know the capacitive version will cost around $60 more than original resistive. We should have both version available.
  1. FS: 10.2" LCD Touch kit w/transflective enhancement
    By Motorcity in forum Classified Archive
    Last Post: 03-14-2007, 02:20 PM
  2. Replacement 4:3 8" Touch Panel For "Super"
    By gsd_racing in forum Input Devices
    Last Post: 01-25-2006, 05:28 PM
  3. Replies: 146
    Last Post: 08-19-2004, 03:39 AM
  4. Replies: 2
    Last Post: 12-11-2003, 10:36 PM
  5. Can I use an 8" touch panel with a 6" lcd?
    By Odie in forum LCD/Display
    Last Post: 10-29-2002, 11:28 PM
