Page 99 of 159 FirstFirst ... 498990919293949596979899100101102103104105106107108109149 ... LastLast
Results 981 to 990 of 1581
Like Tree12Likes
Thread: "Transflective" LCD panel with res touch+controler for $101+$36 S+H
  1. #981
    May 2011
    Quote Originally Posted by DigitalVampire View Post
    Yes, a rubber flap cover/plug similar to the one in the below picture would be perfect.
    Attachment 65530
    I know of at least 3 cars where this distance is a problem. If more, it will hit the climate control unit and 2DIN wont fit. But as long it is within 2-4 mm of a 2DIN unit spec, it should be alright.
    That's a good feature. However, if the level of dimming can be configured through the menu, it would be great but even otherwise, it is a well thought out addition.. Thanks Ken Homma!
    BTW, the Engineering Sample looks really nice!
    Regarding the reachability to the screen edges, its not a major problem since most well designed CarPC front-ends have good sized button and they are usually away from the edges. You could include a capacitive touch stylus for purists though but I guess its use would be very limited in a car except when setting up.
    Thanks for your reply
    the bottom distance is about 7.5MM, we are working hard to make it shorter.
    Also, we shorten the case on both sides, now they will be flat, and only the bottom have distance.
    Mic is added. Rubber cover for USB and SD CARD slot added.
    Any questions, please email to derrick.ny@gmail.com :)
  2. #982
    May 2011
    Quote Originally Posted by windraver View Post
    Nice, I wish I waited now for this new screen. Is there a possibility of a single din assembly?
    The double din version will come out first. If this project works good. A single din assembly will come out
  3. #983
    May 2011
    Quote Originally Posted by that_kid View Post
    What color are the backlit buttons? I'm thinking they're probably green. If so can you post information on the smd size of the leds? For my insall i'd like all the lights to be red and I have no problem using my smd solder solder station to change them, i just need to know the physical size of the leds.
    Good questions. We just about to ask, regarding customizable buttons backlit color. Is WHITE works? We plan to put white LED in the back to light them up
  4. #984
    May 2011
    Quote Originally Posted by ninja6o4 View Post
    I would recommend a removable shade. It should be pretty cheap to have a clip-on piece of plastic that can go along the top.
    I personally would not use a stylus in vehicle. It's not practical and you will just lose it...
    The problem is, if you can not reach the edge of the panel, what can you do?
  5. #985
    May 2011
    I made a mistake yesterday. the "button" beside the SD slot, actually it is a HEADPHONE jack. It can not be centered because it already touch the edge of the screen
  6. #986
    May 2011
    New Rev-B bezel, with MIC add and remove the "sides pop"
  7. #987
    Jan 2012
    Why a headphone jack?
    For the LED's can you do a color changing LED so we can make it match our interior lights? red/blue/green/white. Also please don't make them TOO bright! Or at least make it so they dim with the display or something.
  8. #988
    Apr 2009
    Quote Originally Posted by 8838.com View Post
    I quickly scanned through this. But in a response to this question, I would think most people are running a CarPC software that is more finger friends when actually driving. Not being able to reach the corners when running the bare OS shouldn't be a problem if people are using portable keyboard/mouse combo. Cause let's face it, if you are using the bare OS in your car, you are probably developing something for it to work better and you are going to want a keyboard/mouse. A stylus should be used in this design by default.
    I think a flush design would have been better, but I'm sure that was answered somewhere in this monstrous thread.
  9. #989
    May 2011
    here is the new design about the auto dims
    Once the headlight trigger (12V) get signal, it will auto reduce to 60% brightness. When you touch any button, it will temporary increase to full brightness. After your finger left the buttons, 2 secs, it will reduce back to 60%.
    any opinions?
  10. #990
    May 2011
    Quote Originally Posted by Hdale85 View Post
    Got it, let us see what we can do about the LED
    headphone jack is because there is a audio out port on the board. maybe we should change to AUX IN?
  1. FS: 10.2" LCD Touch kit w/transflective enhancement
    By Motorcity in forum Classified Archive
    Last Post: 03-14-2007, 02:20 PM
  2. Replacement 4:3 8" Touch Panel For "Super"
    By gsd_racing in forum Input Devices
    Last Post: 01-25-2006, 05:28 PM
  3. Replies: 146
    Last Post: 08-19-2004, 03:39 AM
  4. Replies: 2
    Last Post: 12-11-2003, 10:36 PM
  5. Can I use an 8" touch panel with a 6" lcd?
    By Odie in forum LCD/Display
    Last Post: 10-29-2002, 11:28 PM
