Results 1 to 8 of 8
Thread: lilliput eby701 screen corruption
    Jun 2007
    St. Louis
    As the title says...I have an eby 701 that has screen corruption...or no screen at all. The odd thing is that there IS video for a second when you switch the inputs. The display flashes then goes blank. It does this on every input. Now here's more strangeness...if the input is left on PC and it's attached to a computer...when the power saving kicks on via the computer the screen turns blue. When you move the mouse to interrupt the power saving, then lines/stripes (multicolored) appear in the center while the sides stay blue.
    I've re-seated all the ribbon cables, none are kinked and the continuity is good through them.
    Is it the controller on the back of the LCD itself? Or the interface board that the LCD cables plug into? Or do I just need to cuss at it some more
    Thanks,
    Jan 2008
    sometimes different words work better
    at work, we tell each other to pet the defective device-- maybe it's attention deprived..
    though ti sounds like your main controller board is bad..
    Jun 2007
    St. Louis
    as in this board?
    http://www.mo-co-so.com/Replacement-...il-rcb-701.htm
    and thanks for the fast response
    Maximum Bitrate tft_lcd_org's Avatar
    May 2010
    Detroit, MI
    Quote Originally Posted by soundman98 View Post
    Here in the MI, we don't "pet" defective devices, we threaten them.
    Usually, this will provide much better results.
    Plus you don't get that warm fuzzy feeling inside that suddenly makes you feel attached to the device and not wanting to toss it.
    Jun 2007
    St. Louis
    I was raised that if it doesn't work, yell at it. If it still doesn't work, yell louder with more words. When all else fails...it's time to break out the beer and a hammer.
    I'm just about at step 3
    Jan 2008
    ^ after so many unsuccessful attempts at yelling the devices back to life, we decided that the problem must be the tactic's we were using... when in doubt, try the reverse of what you did in the past..
    Jun 2007
    St. Louis
    ok Soundman...so I put it back together all nice and neat, called it sweet and said I loved it dearly and was so sorry about my actions and words I used before. It's behavior didn't improve...it sat there...mocking me. So I called it a selfish no-good dis-respectful POS and I think I saw a tear run down the screen....but alas it was spit from my angered yelling. Come payday a new board will be on order (hopefully)
    disclaimer: tactics used on equipment don't reflect and are not recommended for use on kids
    Jun 2007
    St. Louis
    small update...looked the circuit board over real good...found a couple capacitors that needed replacing...replaced them. After that at least the no-signal message became visible when nothing was attached. It seems to only go blank when a signal is present. Anyone real familiar with the controller board on these? Anyway to bypass all the inputs and go straight to VGA and ignore the rest?
  1. Lockup with screen corruption
    By JackB in forum RR Bug Tracker
    Last Post: 07-21-2009, 06:14 PM
  2. White screen of death - Lilliput EBY701
    By TTeuer in forum LCD/Display
    Last Post: 05-20-2008, 01:05 AM
  3. Lilliput 7" LCD screen corruption
    By silvi4000 in forum LCD/Display
    Last Post: 12-17-2007, 10:55 PM
  4. back light in the screen lilliput EBY701
    By tolassssss in forum LCD/Display
    Last Post: 06-14-2007, 06:57 PM
