Results 1 to 2 of 2
Thread: 2011 Nissan Rogue Navi/Backup Cam Stock Screen Input
    Low Bitrate Epon's Avatar
    Oct 2005
    I'm unfamiliar with the model-year changes that Nissan puts out in terms of software, hardware, etc... but I can't find any documentation if it's possible to hack apart the stock LCD screen to accept additional inputs.
    Apparently Infiniti and older Nissan years have some type of RGB+VH input that seems like it can be modded, but it's also for cars that dont have stock backup cams.
    So, I guess my question is this: does anyone know of a way to add additional input into a 2011 Nissan navi unit? I'm assuming all Nissan's use the same system (Altima, Maxima, Rogue, etc). I'm also assuming the easiest way to do this is to see what the backup cam uses (probably composite) and force the screen to use that input when in DRIVE.
    2004 Ford Mustang
    Apr 2008
    Rogue 2011
    hi, i am also in the same boat as you,but i had the 2007 Murano and i had a TVANDNAV2GO module that was plug and play, so i could have see my nav map on the screen with the flick of a switch and then flik back to the original screen, but i returned the Murano and now the connectors at the back of the rogue are totally different,called the people at tvandnav2go and they dont have a solution,so i am still looking around to find a solution.
  1. Nissan GT-R 2011 at Nurburgring
    By crystalq3 in forum Off Topic
    Last Post: 10-09-2010, 08:53 AM
  2. Replies: 12
    Last Post: 10-07-2010, 12:28 PM
  3. Replacing stock nav screen in my Nissan 370Z
    By Paul_S in forum LCD/Display
    Last Post: 07-18-2010, 09:39 AM
  4. Replies: 0
    Last Post: 10-05-2008, 01:18 PM
  5. Using stock navi screen
    By ninjaxryder in forum LCD/Display
    Last Post: 10-30-2006, 10:31 PM
Tags for this Thread
